An update on how everything is running with Titan Mod and also Vanilla
This is mostly for Vanilla, but I think some of it is related to Titan Mod as well, so I will post here as well... especially the RAM usage.
malvinas2
I am using Android 11 on a zidoo Z20 box.
BTW, using a zipped version of Vanilla, I opened it up and changed the "xbmc.gui" version to 5.17.0 in the XML.
It started to install fine (as a zip) on Omega RC1 then I got a skin.shortcut error (I forget the exact wording).
I installed AchillesPunks Repo, opened the repo and a few updates happened, one of them was the skin.shortcut addon.
Now I have Vanilla vers 19 running on Omega RC1 plus the nightly kodi updates, and Titan Mod on the same system.
Binge is not installed, just the AchillesPunks Repo.
Using your latest Repo, I can not see the skin listed to update Vanilla from vers 19.
I have Vanilla vers 24 (I think it is, I can check if needed, but I think its the latest version) running on a Crew fork build of Omega.
That build I also installed Titan Bingie, I think it is the Titan Bingie installation that is allowing Vanilla's latest version to run rather than all the addons installed on the Crew build.
I installed Vanilla v19 here the same way via a zipped build, I forget the procedure exactly that I did, but on the Crew build and using your newest Repo, I can see Vanilla skin listed and can install/update it.
I then zipped the version 24 of Vanilla from the Crew fork and tried to install it on the kodi nightly build, but I am getting an 'unknown dependency' error.
I am pretty sure though that if I installed Bingie, then Vanilla zipped version would install like on the Crew fork
Everything seems to be working fine except 2 things..
1. The Favorites seems to get mixed up between Titan Mod and Vanilla. I need to look at it more, possibly turning off 'share menu with compatible skins' needs to be turned off in 'skin shortcuts' addon in settings.
2. I dont know how this happens, but I think it may be Vanilla or the combination of Vanilla and Titan Mod on the same system.
None of the playlists I created get listed in the playlist folders when creating links/widgets on the homescreen.
The playlists were listed correctly when I just had Titan Mod on the system, when I installed Vanilla, they disappeared.
To find your playlists you need to go several steps into 'shin helper service widgets' > > then eventually to "Recommended in Playlist"
Each step takes about 5-10 seconds to load... Gets really annoying if you have many playlists to set up.
On a side note, but I think it is related..
On the Titan Mod thread I was asking about high RAM usage (not disk space).
Nothing I could do was lowering the RAM usage other than removing widgets on the homescreen.
After AchillesPunks Repo did its updating (3 or 4 files I think were updated), The RAM usage on my system went from 80% down to 50%.
A huge savings, I am not sure but maybe its possible one of the updates fixed a memory leak somewhere... my guess.
I'll post this same thing over on the Titan Mod thread as well, they seem to be all related.
