(2023-02-18, 16:22)Lessram Wrote: [ -> ] (2023-01-18, 18:50)Fuchs2468 Wrote: [ -> ]@Aphykit2006.
On the Kodi repo there is version 2.0.1.
I (also) can not find 2.0.1
Once I downloaded the 1.0.0 version. But updating doesn't make it 2.0.x
How do I go from 1.0.0 to 2.0.x ?
Hi.
That was a mistake on my part.
Repo is Version 1.0.x
Sorry
I opened an issue on Kodi's GitHub about colors replaced with white ones after last 2 updates in Arch linux, and someone suggested to post here instead.
But this happened after a Kodi Nexus update so I'm not so sure:
https://github.com/xbmc/xbmc/issues/22863
(2023-02-25, 21:35)csts Wrote: [ -> ]I opened an issue on Kodi's GitHub about colors replaced with white ones after last 2 updates in Arch linux, and someone suggested to post here instead.
I cannot reproduce this behaviour with Windows.
Unfortunately I can't test with linux.
Switch off Kodi and delete "\userdata\addon_data\skin.titan.mod.beta.matrix\".
And then restart kodi.
See if you still have the wrong colours.
(2023-02-25, 22:08)Fuchs2468 Wrote: [ -> ]Switch off Kodi and delete "\userdata\addon_data\skin.titan.mod.beta.matrix\".
I did that and posted new pics and a video along with info that give further information about the issue:
https://github.com/xbmc/xbmc/issues/2286...1445228549
(2023-02-25, 22:08)Fuchs2468 Wrote: [ -> ] (2023-02-25, 21:35)csts Wrote: [ -> ]I opened an issue on Kodi's GitHub about colors replaced with white ones after last 2 updates in Arch linux, and someone suggested to post here instead.
Install the latest nightly version and you'll see what it looks like when all the colors white.
(2023-02-26, 01:49)csts Wrote: [ -> ] (2023-02-25, 22:08)Fuchs2468 Wrote: [ -> ]Switch off Kodi and delete "\userdata\addon_data\skin.titan.mod.beta.matrix\".
It was a Kodi issue after all, after the PR was merged it took a day for the next Kodi update -kodi-nexus-git in Arch- to be available and all is fine again.
Details on the github issue mentioned above.
On the home screen how do you get rid of the background overlay so that the background image shows clear? I've gone into the settings and set all the background overlays to none and there is still something over the image.
(2023-03-14, 03:54)MrGenius1 Wrote: [ -> ]On the home screen how do you get rid of the background overlay so that the background image shows clear? I've gone into the settings and set all the background overlays to none and there is still something over the image.
I believe what you are talking about is the diffuse image. I'm not sure if there is a setting for that... It's located inside the texture.xbt that would need to be decompiled and compiled again.. You would need to remove it.
Open "IncludesBackgroundBuilding.xml" with an editor
search for:
xml:
<texture fallback="diffuse/background.png">$VAR[BackgroundOverlayTexture]</texture>
change this line to:
xml:
<texture>$VAR[BackgroundOverlayTexture]</texture>
(2023-03-14, 20:23)Fuchs2468 Wrote: [ -> ] (2023-03-14, 03:54)MrGenius1 Wrote: [ -> ]On the home screen how do you get rid of the background overlay so that the background image shows clear? I've gone into the settings and set all the background overlays to none and there is still something over the image.
search for:
xml:
xml:
I didn't even think about changing the xml. My mind went straight into the texture.xbt. lol
This worked perfectly! Thank you!
Switched to 20.1 the other day, and noticed subtitles are white. I had them set to yellow because too many times white subtitles don't show up as well against white backgrounds like clothing, walls or snow. I went to the area to customize subtitles, and found no way to change the color of subtitles. I found an xml file in Kodi and tried to change the color there, but Kodi ignored the change. I was told to switch to Estuary skin, make changes there, then go back to this skin. That works until I shut down Kodi, which sets everything back when I start Kodi the next time. How to I get subtitle color customization back with Titan MOD? In the screen capture below, you can see that the subtitle font color selector is gone.
(2023-03-15, 23:30)mitgarand Wrote: [ -> ]Switched to 20.1 the other day, and noticed subtitles are white. I had them set to yellow because too many times white subtitles don't show up as well against white backgrounds like clothing, walls or snow. I went to the area to customize subtitles, and found no way to change the color of subtitles. I found an xml file in Kodi and tried to change the color there, but Kodi ignored the change. I was told to switch to Estuary skin, make changes there, then go back to this skin. That works until I shut down Kodi, which sets everything back when I start Kodi the next time. How to I get subtitle color customization back with Titan MOD? In the screen capture below, you can see that the subtitle font color selector is gone.
I'm still working on the Nexus update.
You will be able to set the subtitle colour in Titan Mod when I am done with my update.
Here is a preview:
(2023-03-17, 23:54)Fuchs2468 Wrote: [ -> ]I'm still working on the Nexus update.
I did find a workaround for now, but it's a long-winded explanation. Can't wait for your update, as it is my favorite skin.
