Are the changes from the Titan MOD trial edition having the OSD modification:
https://app.box.com/s/wy66bvpymnx7kkvqc7zdn8txp595dhro
Will they be included in the Omega version skin? I have been testing the Titan MOD release with the OSD change for several weeks, it works without any problems.
Regards
Fuchs2468
I mean Titan MOD trial version with OSD mod works fine on Kodi Nexus. As I wrote, on Nexus the trial skin with OSD works perfectly on Android TV.
Will you also change the OSD in the Titan MOD skin in Omega?
Regards
(2023-12-13, 15:44)Arkady1964 Wrote: [ -> ]@Fuchs2468
Regards
My next update will include all changes for the Nexus version and Omega version.
Fuchs2468
I'm waiting for the announced update of the excellent Titan MOD skin. Respect to you and thanks for your continuous work on the Titan MOD skin.
Regards
Fuchs2468, Thanks for your continuous supports and assistance for the skin.
I have this issues as noted below
Here is the full log :
https://paste.kodi.tv/okikoredel
Any thoughts what could have caused the issue every thing seems to be working fine for Kodi 19
Appreciate your support
Smart short for emby nodes not working
2023-12-18 14:22:15.491 T:1118 info <general>: Skin Helper Backgrounds --> Generated smart shortcuts for emby nodes: [] 2023-12-18 14:22:15.505 T:1118 info <general>: Skin Helper Backgrounds --> Error while processing smart shortcuts for playlist special://profile/playlists/video/emby_movies_Adult.xsp --> This file seems to be corrupted, please remove it from your system to prevent any further errors. 2023-12-18 14:22:15.505 T:1118 info <general>: Skin Helper Backgrounds --> Error while processing smart shortcuts for playlist special://profile/playlists/video/emby_movies_Africa.xsp --> This file seems to be corrupted, please remove it from your system to prevent any further errors. 2023-12-18 14:22:15.506 T:1118 info <general>: Skin Helper Backgrounds --> Error while processing smart shortcuts for playlist special://profile/playlists/video/emby_boxsets_Collections.xsp --> This file seems to be corrupted, please remove it from your system to prevent any further errors. 2023-12-18 14:22:15.506 T:1118 info <general>: Skin Helper Backgrounds --> Error while processing smart shortcuts for playlist special://profile/playlists/video/emby_movies_Foreign.xsp --> This file seems to be corrupted, please remove it from your system to prevent any further errors. 2023-12-18 14:22:15.506 T:1118 info <general>: Skin Helper Backgrounds --> Error while processing smart shortcuts for playlist special://profile/playlists/video/emby_movies_Kids.xsp --> This file seems to be corrupted, please remove it from your system to prevent any further errors. 2023-12-18 14:22:15.506 T:1118 info <general>: Skin Helper Backgrounds --> Error while processing smart shortcuts for playlist special://profile/playlists/video/emby_livetv_Live_TV.xsp --> This file seems to be corrupted, please remove it from your system to prevent any further errors. 2023-12-18 14:22:15.507 T:1118 info <general>: Skin Helper Backgrounds --> Error while processing smart shortcuts for playlist special://profile/playlists/video/emby_movies_Movies.xsp --> This file seems to be corrupted, please remove it from your system to prevent any further errors. 2023-12-18 14:22:15.507 T:1118 info <general>: Skin Helper Backgrounds --> Error while processing smart shortcuts for playlist special://profile/playlists/video/emby_tvshows_TV_shows.xsp --> This file seems to be corrupted, please remove it from your system to prevent any further errors. 2023
(2023-12-18, 22:04)t123thomas Wrote: [ -> ]@Fuchs2468, Thanks for your continuous supports and assistance for the skin.
Here is the full log : okikoredel (paste)
I see several problems, you are using Kodi_21_beta1.
The Kodi version with Titan that I recommend at the moment is Kodi 20 Nexus.
Furthermore, you use skin.titan.mod.beta.matrix v19.1.23, this version is only valid up to Kodi Matrix.
From Kodi 20 onwards the skin is only called “skin.titan.mod”.
The current version is skin.titan.mod v20.1.24.
I see connection problems in your log file, the "<pathsubstitution>" doesn't seem to work.
<http://127.0.0.1:57342/> Failed with code 404
You should go back to Nexus, uninstall skin.titan.mod.beta.matrix v19.1.23 and check your network connections.
dont know if this has been said before but on tv shows when you push up it uses tubed bud that doesnt word always quota exeded ! maybe use normal youtube ?
thnx for al your work !
Happy New Year to Fuchs2468 and all Titan MOD skin fans!
When I enter the info page for an episode it does not show all the actors and guest stars, only the few from the serie info. When I switch back to the kodi skin it works ok so it must be skin related.
All the best for 2024 for everyone.
(2024-01-03, 01:06)Colabacardi Wrote: [ -> ]When I enter the info page for an episode it does not show all the actors and guest stars, only the few from the serie info. When I switch back to the kodi skin it works ok so it must be skin related.
Thanks for the info, I found the error.
The error will be fixed with the next update.
Fantastic skin - appreciate your great work!
Is it possible to show weather details with animated icons for each day at the same time not just for the day in focus ?
(2024-01-04, 01:41)dannyau Wrote: [ -> ]Fantastic skin - appreciate your great work!
I can also display the temperatures.
It will look like that:
Hello Fuchs2468 Consider adding a "more information" button - "i+" to the Titan MOD skin in the OSD, which will give information about the actors in the movie or other additional data related to the movie.
I would like to point out that if the introduction of this proposal would significantly delay the introduction of the announced update, please consider it in the future.
Regards
(2024-01-21, 10:56)Arkady1964 Wrote: [ -> ]Hello Fuchs2468 Consider adding a "more information" button - "i+" to the Titan MOD skin in the OSD, which will give information about the actors in the movie or other additional data related to the movie.
Regards
This function will not come soon.
At the moment I'm preparing my next Nexus update and then I'll continue working on my Omega version.
