Thank you so much for this skin. I just discovered it and installed it on Kodi 19. Finally a clean Titan skin for Kodi Matrix.
I was able to setup everything as I like but there is one thing left. I'm in Netflix layout and the widget rows have too much vertical space between them.
If you keep the spotlight space on the top you see only one row of widget per screen. In other Titan skins the rows are close to each other.
Is it possible to make the rows of widgets close to each other?
(2021-08-29, 03:42)Zodler Wrote: [ -> ]Thank you so much for this skin. I just discovered it and installed it on Kodi 19. Finally a clean Titan skin for Kodi Matrix.
It is so wanted that only 1 widget is visible, it looks unclean when a part of the next widget is visible.
(2021-08-29, 21:03)Fuchs2468 Wrote: [ -> ]It is so wanted that only 1 widget is visible, it looks unclean when a part of the next widget is visible.
I understand. Maybe make it an option? It has its advantages.
When I go to the Videos menu in the left, or some other times, it asks me to install the Youtube Addon. I don't want it. How to avoid installing it and not receiving messages?
(2021-08-30, 21:57)Zodler Wrote: [ -> ]When I go to the Videos menu in the left, or some other times, it asks me to install the Youtube Addon. I don't want it. How to avoid installing it and not receiving messages?
There will be a Youtube switch in my next update. I already work on it.
Until the update there is the following solution.
Install YouTube and then deactivate.
Ok, thanks. Does it actually use YouTube for something?
(2021-08-30, 23:42)Zodler Wrote: [ -> ]Ok, thanks. Does it actually use YouTube for something?
Yes for video info "Use Enhanced (WIP) Info",
and in the search option in Titan.
This mod seems really impressive,
but a few years ago I already try Titan Skin and I have a big problem with it cause when I came back to my initial skin all my settings on my initial skin are gone and if I well remember I must reinstall
my skin. At this time it's seems to be a knowed problem with Titan Skin.
Is this problem already exist today with a KODI 18 installation?
I don't know but you can always backup. You can backup and restore only the skin settings.
Update came through today, and changelogs ?
Fuchs2468
Hello
Thank you for this update.
I have au question :
Have these files been modified from the previous one?
Because I had modified them and I would like to know if I could take them back as they are
- IncludesBackgroundBuilding.xml: single fanart in the information menus instead of a black background (without skin helper service)
- View_529_NetflixSeasons.xml: to have a less dark fanart
- MusicVisualization.xml: For the Artistslideshow extension
- resource.language.fr_fr => to have some genres compatible with TBDB.
For more information, see this post :
https://forum.kodi.tv/showthread.php?tid...pid3043573
Regards
(2021-09-06, 09:21)Aphykit2006 Wrote: [ -> ]@Fuchs2468
Hello
Regards
"View_529_NetflixSeasons.xml" you have to edit.
You can use your other modified files.
