This was my favorite skin in Leia, and it still is my favorite in Matrix, besides one glitch.
I use Arch Linux, and a friend using windows 10 had the same issue.
The only working way I found to have multiple backgrounds is to use "Configure conditional backgrounds".
After restarting Kodi, the screen is black, but if I go to Skin settings and just click once on "Configure conditional backgrounds", then press ESC, the backgrounds start appearing.
https://ibb.co/5c5b2FK
(2021-04-07, 00:39)Fuchs2468 Wrote: [ -> ]Hi Guys.
I have created a new repo for you so Titan Mod Matrix can be automatically installed with all dependencies.
Here is the link to the repo: repository.fuchs246-1.0.0.zip
- Install Kodi Matrix
- Go to "Settings / System / Add-ons"
- Choose "Unknown Soures"
- Update Official add-ons from => "Any Resositories"
- Go to "Install Form Zip File"
- "repository.fuchs246-1.0.0.zip" install
- Go to "Install from Repository"
- Choose "Fuchs Repo"
"Look and feel" => "Skin" => "Titan - Mod"
- Click Install
- Done!
Have fun with testing
I've been trying to install the v19 version of this skin for a while now and keep coming across the same error with the skin helper service. I'm on macOS 11.2.3 doing a fresh install of Kodi v19.
https://paste.kodi.tv/gefoyufaha.kodi
(2021-04-07, 02:21)csts Wrote: [ -> ]This was my favorite skin in Leia, and it still is my favorite in Matrix, besides one glitch.
It seems after restarting I just had to wait 10 seconds, and backgrounds appear fine.
Fuchs2468
Il'l try this afternoon.
Note : on MaduckL repositorie is another Titan Mod 19..19… but install failed.
question about ArtworkDump : necessary or not ?
[Edit ]
Repository : perfect . 😁
No error.
(2021-04-07, 08:25)Aphykit2006 Wrote: [ -> ]@Fuchs2468
[Edit ]
No error.
The version on Mardukl's Repo is the same Titan Mod version.
Artworkdump should not be necessary.
Thank you @
Fuchs2468. I tried your mod over the already working version. And it still works.
Tried this, because I hope you make some updates once in a while.
(2021-04-07, 14:49)Lessram Wrote: [ -> ]Thank you @Fuchs2468. I tried your mod over the already working version. And it still works.
The secure variant is a reinstallation of Kodi.
Kodi Matrix only makes automatic updates from the Repo of which the add-on was installed or from the Kodi Repo.
Everything that has been installed manually will not automatically update.
This is new to Kodi Matrix.
Got Titan up and running finally on matrix.
I have noticed It lists all the widgets on Every menu item.
(Other 2 had nothing to do with Titan, so I removed them)
Thank and keep up the great work. Looking forward to a stable release!
(2021-04-09, 00:06)thyttel Wrote: [ -> ]I keep getting python mismatch xxxxx when trying to install from the repo on latest matrix? Am I doing something wrong. The erro is when trying to install dependencies and installation stops and skin is not being installed.
Without an error log, I can not help you.
The repo works, otherwise everyone else would have the same problem.
Please send a log file.
(2021-04-08, 02:10)JasonMonette Wrote: [ -> ]Got Titan up and running finally on matrix.
I suspect you use Homescreen Layout Netflix or Homescreen Layout Vertical?
Go to:
SKIN SETTINGS => Homescren layout => "Show all widgets (detach from main menu focus)"
switch off
