That doesn't install for me on Kodi 19.4 on Windows, it seems that most of the dependencies fail to install.
(2022-07-18, 11:20)allanp81 Wrote: [ -> ]That doesn't install for me on Kodi 19.4 on Windows, it seems that most of the dependencies fail to install.
Then you have made a mistake.
I have just tested it. All the dependencies were installed properly.
(2022-07-18, 11:53)Fuchs2468 Wrote: [ -> ] (2022-07-18, 11:20)allanp81 Wrote: [ -> ]That doesn't install for me on Kodi 19.4 on Windows, it seems that most of the dependencies fail to install.
I added the repository from the link a few posts previously and I choose the option the to install the skin but it fails so not sure what else I can do?
I see this for instance in the kodi.log:
2022-07-18 11:01:56.583 T:19568 ERROR <general>: Add-on 'script.module.unidecode' is not compatible with Kodi
2022-07-18 11:01:56.583 T:19568 ERROR <general>: Add-on 'script.module.simplejson' is not compatible with Kodi
2022-07-18 11:01:56.583 T:19568 ERROR <general>: Add-on 'script.skinshortcuts' is not compatible with Kodi
2022-07-18 11:01:56.583 T:19568 ERROR <general>: CAddonInstallJob[skin.titan.mod.beta.matrix]: The dependency on xbmc.python version 2.20.0 could not be satisfied.
(2022-07-18, 12:03)allanp81 Wrote: [ -> ]I see this for instance in the kodi.log:
It looks like they've updated from Leia to Matrix.
But it is necessary to use a clean matrix installation.
Otherwise you will get errors.
No way to fix without reinstalling it entirely from scratch?
That would be very difficult.
And much too time-consuming. You are better off with a reinstallation.
(2022-07-18, 13:18)Fuchs2468 Wrote: [ -> ]That would be very difficult.
thanks for your help, I renamed my appdata\kodi directory and started again and it installed fine.
(2022-07-18, 03:06)accacc5 Wrote: [ -> ] (2021-06-07, 19:42)odanion Wrote: [ -> ] (2021-06-07, 17:17)Aphykit2006 Wrote: [ -> ]Hi
Try , in skin settings
Playback / OSD
There are some timers.
Perfect, that was it! the osd auto close was on and it would technically close, but the bar was still there and you could change it, but because the osd was closed it didnt update
@Fuchs2468 Hello there. Is there a solution for this old issue? In brief, when adjusting the subtitles offset, even if the adjustment slider is visible and working, the changes don't register after 2-3 seconds. Seems the closing of the infopanel (after the set time in settings) causes this. It wasn't like that in original Titan. Would you kindly advice on a solution? Thanks mate. Cheers.
Hi guys, any ideas to solve this?
Why isn't working like the contrast or brightness slider? Any help would be much appreciated.
In /userdata/addon_data/skin.titan.mod.beta.matrix/custom_images/ I have about 487 images (I've been using Titan M O D for a long time) like CustomBackgroundSetting20210515115014.jpg etc.
I tried just putting them in the trash some time ago, and my menus etc came up empty, so I restored them.
Now I just use lossy compression for all.
Is there a way to see which of these images aren't being used so I can safely remove?
(2022-07-18, 18:34)accacc5 Wrote: [ -> ] (2022-07-18, 03:06)accacc5 Wrote: [ -> ] (2021-06-07, 19:42)odanion Wrote: [ -> ]Perfect, that was it! the osd auto close was on and it would technically close, but the bar was still there and you could change it, but because the osd was closed it didnt update
I cannot reproduce your problem.
Subtitle offset works for me.
I have just tested it again.
(2022-07-18, 19:51)csts Wrote: [ -> ]In /userdata/addon_data/skin.titan.mod.beta.matrix/custom_images/ I have about 487 images (I've been using Titan M O D for a long time) like CustomBackgroundSetting20210515115014.jpg etc.
You should see this in Titan's settings.xml.
Search for "CustomBackgroundSetting".
(2022-07-18, 20:17)Fuchs2468 Wrote: [ -> ] (2022-07-18, 19:51)csts Wrote: [ -> ]In /userdata/addon_data/skin.titan.mod.beta.matrix/custom_images/ I have about 487 images (I've been using Titan M O D for a long time) like CustomBackgroundSetting20210515115014.jpg etc.
That doesn't help, it finds 9 lines with "CustomBackgroundSetting" and the only other change besides Titan's default lines are my wallpaper folder additions -not those images.
I'll just delete all images in custom_images, relink missing pics via skin settings, and see that folder contents afterwards.
(2022-07-18, 20:34)csts Wrote: [ -> ] (2022-07-18, 20:17)Fuchs2468 Wrote: [ -> ]
That's a reasonable solution.
Fuchs2468 Thanks for getting back to me.
The offset slider works but if you stop for an amount of time equal the time to auto hide the osd infopanel in skin settings, it will keep on working but will not register the extra changes after the stoppage.
i.e. move slider for example 1 sec ahead, stop for 3 seconds (my setting to auto close infopanel), continue moving the slider, it will move but only the first 1 sec before stopping will take effect.
I am not the only one with this issue, the post I quoted is for the same issue.
Sorry for bothering you man but it is kind of difficult to use the subtitle offset. Aslo I tested with the audio offset and it has the same issue.
Cheers.
