(2022-08-18, 21:35)grappi Wrote: [ -> ] (2022-08-10, 15:02)grappi Wrote: [ -> ]
Thank you for your help regarding my problem, but I can't get Kodi 19 to work with Titan MOD.
I tried several databases on a Synology DS and Ubuntu Server with MariaDB and MySQL (older and new version), and started always with a new clean database, but the problem always returns.
After 2-3 days Kodi is not useable, because it constantly freezes after 30-40 min.
I am now back at Kodi 18 with my Titan Vanilla Skin, hoping to find a new Skin that is similar to Titan.
I'm sorry to hear that. I would like to help you, but unfortunately I don't use Ubuntu.
I can't test it.
But you can use the standard Kodi database.
It should definitely work with the kodi database. And for data comparison you can use "Trakt und "The Moviedb Helper".
That's how i do it.
I have a few kodi installations, they are all up-to-date without me having to worry about it.
grappi.
I just had an idea.
But you would have to test Kodi 19 again.
And you would have to change 4 files in "script.module.metadatautils".
Since kodi freezes after 2-3 days, this could be a possible cause.
Because "script.module.metadatautils" queries the Top250 and the "Metacritic status" and the series status after 2 days online.
It would be nice if you could test it.
But it's no big deal.
You only have to change 4 numerical values.
search in:
\addons\script.module.metadatautils\lib\metadatautils.py
\addons\script.module.metadatautils\lib\helpers\imdb.py
\addons\script.module.metadatautils\lib\helpers\metacritic.py
\addons\script.module.metadatautils\lib\helpers\tunes.py
search for:
change to:
The numerical values are the days when the next online query takes place.
If one of the files is the cause, kodi should freeze after 7 days.
And we know where the error is.
(2022-08-18, 06:23)Projectzero Wrote: [ -> ]I'm running the 18.1.19 alpha.1 skin / Kodi 18.9 and have an issue/question: can the Youtube plugin be disabled? I keep getting prompted to install the plugin and the only thing I can find related to anything Youtube is regarding trailers. There's an option in the skin (Media library views > Trailer Settings > Just play locally. . . WIP) but toggling it doesn't seem to do anything. If I want a trailer for a movie, I have a copy downloaded in the movie folder. Updating to Kodi 19 and the newer skin isn't an option (*any* version of 19 doesn't play nice with my ShieldTV on 8.2.3 or any 9.xx).
Install the Youtube addon then you can deactivate it immediately.
Deactivating only works via the context menu, not via the addon settings.
After that you will have no more warnings.
Yes I have to be honest I have never really tested local trailers.
I always watch trailers via the Youtube addon.
I think I have found a solution to this problem.
I just did a quick test with local trailers and it looks good.
This solution might even solve another problem that exists with auto play trailers.
I think I will post a test version here this weekend.
(2022-08-19, 00:08)Fuchs2468 Wrote: [ -> ]@grappi.
I just had an idea.
search in:
search for:
change to:
Hello @
Fuchs2468, thank you so much for making such a big effort. I go back to Kodi 19, make the changes and start the next attempt this weekend.
I will report back at next weeks end.
(2022-08-06, 01:10)UbuntuUser Wrote: [ -> ]I just did a clean install of Kodi Matrix 19.4 on a Ubuntu 22.04 (also clean install) and when using this skin it freezes up and becomes unresponsive, and the only way to get it working again is to kill Kodi and restart it, anyone else having this issue?
Thanks, UbuntuUser
I always had crashes with Kodi Matrix in Arch linux, and especially the last few crashed on start due to mainly python version differences and addons (like PVR IPTV Simple Client) using deprecated python commands or methods, compared to latest Arch python versions.
The only solution so far for Matrix is Flatpak Kodi, that has few crashes.
https://flathub.org/apps/details/tv.kodi.Kodi
Kodi Nexus works fine with Titan MOD, and only a few addons fail, hopefully Kodi devs will implement the fix from Nexus to Kodi v19.5.
Flatpak Kodi uses python v3.9 in a container -Kodi v19.4 uses python v3.8-, that's why it's working.
Thanks Fuchs2468 for keeping this skin up to date. Just wondering whether you will be updating it to Kodi Nexus.
Also, 1 view which I like from the other Titan mods (eg. Titan Bingie v1) is the Netflix poster where it has 2 rows of posters (bottom row is half hidden), compared to the current poster view here where there is only 1 row. I do note there is the Netflix view with 2 rows of landscape. Titan Bingie is no longer updated and AchillesPunks Bingie Mod 1 is excellent but only has 1 main menu option.
Any chance you can add the option of a Netflix poster view with 2 rows (bottom row is half hidden) or advice how to achieve this.
(2022-08-26, 12:55)satelly Wrote: [ -> ]
If all addons that are required for Titan-Mod support Nexus, then there will also be a Nexus update.
To your second question, no, I will not change it.
The amount of work would be far too great, as I wouldn't have to change just 2 or 3 numerical values.
As you have already noticed, Titan-Mod does not only have a home layout, and the layouts would all have to be checked and adapted in the event of a change.
With Titan-Mod you have the choice between 2 home layouts in Netflix style.
Choose a layout, that's all i can offer you.
Info about Titan-Mod with Nexus !!!
"kodi-20.0-Nexus_alpha1" works with Titan-Mod.
"kodi-20.0-Nexus_alpha2" does not work with Titan-Mod.
If you want to test Nexus, please use a current nightly version.
All nightly versions after 07.08.2022 work with Titan-Mod.
Tested with windows 10/ 64 bit.
(2022-08-27, 03:37)Fuchs2468 Wrote: [ -> ]Info about Titan-Mod with Nexus !!!
Thanks Fuchs2468. Thanks for explaining the Netflix views
I just had an idea.
search in:
search for:
change to:
Fuchs2468, I want to report back.
I made the changes and actually the problems now started after 7 days.
grappi
Just extend the numeric values out longer.
Sorry didn't read all the comments
(2022-08-28, 19:12)grappi Wrote: [ -> ]I made the changes and actually the problems now started after 7 days.
First of all, it's good to know that my assumption was correct.
I don't know if you want to test further?
I can't test it because I don't use the same system setup (mysql,hardware,software) as you.
If you want to test further, we would now have to find out which of the 4 files is causing the error.
To do this, reset all values and test each file individually.
with:
Test it in this order:
Fuchs2468
instead of
@use_cache(7)
use
@use_cache(1)
That way you don't have to wait 7 days? Wouldn't this be fast?
(2022-08-30, 22:04)AchillesPunks Wrote: [ -> ]That way you don't have to wait 7 days? Wouldn't this be fast?
Yes, that's right.
That's how I would do it too.
But since I don't know whether grappi uses kodi every day or how often he looks at this test, that's why I chose these values.
So that he also keeps track and doesn't get confused with this test.
