I switched to the new skin for Nexus this morning. I also finished ripping my Futurama discs so I can watch them through Kodi. I scraped the information for the show using TVDB through tinyMediaManager. Normally, I don't get any information for the season folders, but now I am getting this:
Each season has some weird information. This particular one is from Club Friday Season 15. Season 2 uses Love Starts from Marriage Season 2. Season 3 uses Check the Store Next Door: The Next Chapter Season 1. I tried scraping through Kodi using Local Information Only, deleting all the downloaded NFO files and scraping through Kodi using TVDB version 4 and TMDB, but I can't get rid of this. Any idea how I can get rid of these season descriptions from other TV show's seasons? I posted this issue on another forum, and was asked if this appeared with other skins. It doesn't. Not even with the Matrix skin. It is a behavior I am only seeing with the new Nexus version of this skin.
Going through other folders, I am seeing this behavior depending upon the folder icon used. If the folder icon looks like this:
I get the weird info for each season. If the folder icon looks like this:
I don't get anything showing up.
Thanks again @
Fuchs2468 for your work, update went fast and smooth as silk, been also able to recover my main settings from a previous v19.1.23 backup without any major issue.
Only little hiccup is with Tv Shows - NextAired which refuse to update to your latest version (so far v8.0.1 still working great on my end)
(2023-09-14, 22:03)mitgarand Wrote: [ -> ]Going through other folders, I am seeing this behavior depending upon the folder icon used. If the folder icon looks like this:
Apparently the folder icon chosen depends upon whether or not you have the show scanned into your library. The former folder icon with the weird season information appears if the show has not been scanned into your library. The latter icon appears if you have the show scanned into your library. I had deleted my MyVideos121.db file hoping that would cleat everything up, and after scanning the shows again using TVDB v4, all season folder icons look like the second image, and no text is appearing with weird season information. This was also only happening with "Files view" of my TV shows folder.
(2023-09-15, 12:23)FlashOne Wrote: [ -> ]Only little hiccup is with Tv Shows - NextAired which refuse to update to your latest version (so far v8.0.1 still working great on my end)
Thanks for the info.
There was a small error in my repo.
The error is fixed in the update of "TV Show - Next Aired"
should work now.
(2023-09-15, 15:29)mitgarand Wrote: [ -> ]Apparently the folder icon chosen depends upon whether or not you have the show scanned into your library. The former folder icon with the weird season information appears if the show has not been scanned into your library. The latter icon appears if you have the show scanned into your library.
You recognized that correctly, this is how the symbols should behave.
The text just shouldn't be there.
This may have something to do with the NFO file generated by tinyMediaManager.
But I can't judge that because I've never used this program.
Glad you were able to solve your problem.
But you should rather use the library view, it just looks better.
(2023-09-15, 20:17)Fuchs2468 Wrote: [ -> ] (2023-09-15, 15:29)mitgarand Wrote: [ -> ]Apparently the folder icon chosen depends upon whether or not you have the show scanned into your library. The former folder icon with the weird season information appears if the show has not been scanned into your library. The latter icon appears if you have the show scanned into your library.
My movies folder is doing the same thing. If I set the folder to Movies, I get movie info showing up when I used to only see that when I went into the folder and highlighted the movie itself. I don't use tinyMediaManager for movies unless the movie won't scan properly. So to get around this, I left the main movie folder set to files view, but went to each individual movie subfolder and set the content to Movies and then scanned it with TMDB. I use subfolders in my movie folder because I have grouped some movies together for better organization or to find them quicker. For example, I have all my Clint Eastwood or my wife's Thin Man movies in one folder.
Odd, though, how this issue never appeared until I switched to the Nexus version of your skin. I am very happy with this skin, by the way. Kodi crashed frequently upon starting when I used the Matrix skin in Matrix and Nexus. Sometimes I had to start Kodi multiple times before it finally ran. There is no other skin out there that works for me like Titan M O D. It is so easy for me to customize, and the horizontal home menu can easily be set at the very bottom of the screen which is right where I want it.
(2023-09-15, 20:57)mitgarand Wrote: [ -> ]Odd, though, how this issue never appeared until I switched to the Nexus version of your skin.
I just thought of something that could be causing this behavior for you.
If you have "TheMovieDb Helper" installed, deactivate "TheMovieDb Helper" as a test, then go to the file view and see if the behavior has changed.
(2023-09-15, 22:07)Fuchs2468 Wrote: [ -> ] (2023-09-15, 20:57)mitgarand Wrote: [ -> ]Odd, though, how this issue never appeared until I switched to the Nexus version of your skin.
That seems to have fixed the issue. I set the content to Movies, which showed nothing, so I set it back to None which cleared out the library, set it back to Movies, and it is scanning now without the problem resurfacing! Thank you!
(2023-09-15, 22:36)mitgarand Wrote: [ -> ]That seems to have fixed the issue. I set the content to Movies, which showed nothing, so I set it back to None which cleared out the library, set it back to Movies, and it is scanning now without the problem resurfacing! Thank you!
Have you activated “TheMovieDb Helper” again?
(2023-09-15, 22:48)Fuchs2468 Wrote: [ -> ] (2023-09-15, 22:36)mitgarand Wrote: [ -> ]That seems to have fixed the issue. I set the content to Movies, which showed nothing, so I set it back to None which cleared out the library, set it back to Movies, and it is scanning now without the problem resurfacing! Thank you!
Yes. That is the culprit. Currently running version 4.10.14. Updated to 5.1.36 after resolving a dependency issue, and the problem is gone.
@Fuchs2468 The slider feature in the search bar works perfectly in the Titan MOD skin for Android TV (Xiaomi Mi Box S). However, after the recent changes in your repo, there is a black image and no sound in the videos. Tested on a fresh installation (new Kodi 20.2 Nexus installation). Installing the skin from the repo first is a problem.
Then install the skin with the function from the zip file, the function works great, the video starts, but there is no image or sound...
Regards
Fuchs2468 I'm very sorry, but it was the Android TV crash that caused the problem. Turning the device back on after turning off the power solved the problem (restarting Xiaomi Mi Box)...
From this test version of the Titan MOD skin (Android TV) installed from a zip file:
https://app.box.com/s/wy66bvpymnx7kkvqc7zdn8txp595dhro
I've been testing the slider in the search bar for over a week now, it works great in the Titan MOD skin (Android TV).
Thank you again for your work on the Titan MOD skin. The test version of the Android TV skin works great and can be added to your repository. Everything about Titan MOD works very well.
Regards
(2023-09-16, 11:32)Arkady1964 Wrote: [ -> ]@Fuchs2468 The slider feature in the search bar works perfectly in the Titan MOD skin for Android TV (Xiaomi Mi Box S). However, after the recent changes in your repo, there is a black image and no sound in the videos. Tested on a fresh installation (new Kodi 20.2 Nexus installation). Installing the skin from the repo first is a problem.
Regards
Which version does you have a black picture and no sound?
With the version from the repo, or with the version that I sent you for testing.
Image and sound actually have nothing to do with the skin.
Fuchs2468 Everything is OK... The problem was caused by an Android TV failure. Turning the device back on after powering down solved the problem (restarting Xiaomi Mi Box S). After restarting the hardware, the Titan MOD skin worked properly. The problem was due to my equipment.
It was enough to restart the Android TV device and the problem was fixed...
Both versions of the skin work great, the version from the repository and the test version of the Titan MOD (Android TV) skin installed from a zip file:
Regards
