Fuchs2468
Ah! I see what your talking about... I don't think about things like that when I talk to people on Kodi.
Would it be possible in the next update maybe, to add what's up next in PVR OSD, and to show season and episode info? Thanks
(2022-09-11, 14:50)psbguy Wrote: [ -> ]Would it be possible in the next update maybe, to add what's up next in PVR OSD, and to show season and episode info? Thanks
Yes, No problem. I can do this.
psbguy .
At your request, I have now combined nextup and now playing.
First the title of the next programme appears and then the title of the programme with extra info (episode info).
I hope this is what you had in mind.
Here is a preview:
Fuchs2468 Sounds good, but will the season and episode numbers show for the now playing or for next up program? as currently it's not showing for the now playing.
Thanks again for looking into this!
(2022-09-14, 01:42)psbguy Wrote: [ -> ]Sounds good, but will the season and episode numbers show for the now playing or for next up program? as currently it's not showing for the now playing.
This information depends on the EPG info of your PVR server. I can only test it with TVheadend with German channels. It also depends on your country and the EPG info of the channel. And another limitation is the info labels available to me from kodi.
I will upload a test version in the next few days so you can test it.
(2022-09-14, 02:56)Fuchs2468 Wrote: [ -> ] (2022-09-14, 01:42)psbguy Wrote: [ -> ]Sounds good, but will the season and episode numbers show for the now playing or for next up program? as currently it's not showing for the now playing.
Thanks! My EPG shows all the information most of the times, so I'll be able to test if there is anything missing, looking forward for the test version.
(2022-09-17, 19:04)psbguy Wrote: [ -> ]Thanks! My EPG shows all the information most of the times, so I'll be able to test if there is anything missing, looking forward for the test version.
Replace your old Custom_1120_PVR_NextUp.xml with this file.
Have fun testing.
Custom_1120_PVR_NextUp.zip
(2022-09-17, 19:24)Fuchs2468 Wrote: [ -> ] (2022-09-17, 19:04)psbguy Wrote: [ -> ]Thanks! My EPG shows all the information most of the times, so I'll be able to test if there is anything missing, looking forward for the test version.
Have fun testing.
I have forgotten another file IncludesVariables.xml please also replace.
IncludesVariables.zip
Have fun testing.
This is a nice improvement to the Nextup pop up, where it's now showing the now playing when the next program starts, but it didn't work as your earlier screenshots, as it didn't show program info or artwork, just the name.
But this is not what I had in mind, I was thinking of the information on the OSD panel when you hit enter, it's currently only showing the now playing info (with some extra info missing, like season and episode numbers), but it doesn't show what program is next, can those be added to the OSD panel?
Thanks and sorry for the misunderstanding!
(2022-09-17, 20:21)psbguy Wrote: [ -> ] (2022-09-17, 19:24)Fuchs2468 Wrote: [ -> ]
Do you also have "IncludesVariables.xml"
replace, then it displays a graphic like in my screenshot.
The osd menu shows next title you just have to press info or press pause.
Ah, good to know, thanks!
Would it be possible to add progress indicator to PVR widgets (last played, channels ...)?
(2022-10-04, 06:12)psbguy Wrote: [ -> ]Would it be possible to add progress indicator to PVR widgets (last played, channels ...)?
Yes, that would be possible.
I will make a note of it for a later update.
