(2021-03-30, 17:18)allanp81 Wrote: [ -> ] (2021-03-30, 17:11)allanp81 Wrote: [ -> ] (2021-03-30, 12:04)Fuchs2468 Wrote: [ -> ]It will soon be working automatically again if you have lucky it works today.
Please install repository: repository.marcelveldt-1.0.3.zip
Then install "skin.titan.mod.beta.matrix-19.1.19 ~ alpha.1"
Awesome, that's worked!
Spoke too soon, I just get a blank screen after accepting the skin change.
That can sometimes happen.
Just finish Kodi and restart if this happens.
Then it should display the Home Screen.
Yes, it seems that my imac it did the blank screen whereas on Windows it worked fine. I have coreelec on some other devices so will try it on there as well.
iwas able to install titan mod beta matrix from zip on marduk github but not from repo and had to manually install skin helper stuff first
(2021-04-01, 07:57)kow1234 Wrote: [ -> ]iwas able to install titan mod beta matrix from zip on marduk github but not from repo and had to manually install skin helper stuff first
You're right it does not work with the installation of "skin.titan.mod.beta.matrix" via the repo of MardukL, is a mistake of the file name
still needs to be changed.
But I have already informed MarkukL.
Yes, finally, it worked in this order of installation
1) Kodi - Matrix
2) Marcel Veldt's 1.0.3
3) Skin Helper items
4) titan mod beta matrix from zip
There's a specific installation order of the helper items (?).
Some don't want to install at first attempt, but doing the others first and retrying the problem ones again made them work.
Thanks All !!
BTW: Isn't it possible (or allowed) to include Marcel Veldt's 1.0.3 and all those Skin Helper items into the Titan Mod?
Hello we could have the links of each step :
1) Kodi - Matrix OK
2) Marcel Veldt's 1.0.3 ?
3) Skin Helper items ?
4) titan mod beta matrix from zip ?
Please THANX.
I went back to kodi 18.9 version due to playback stuttering issues on shield and skin titan problems in matrix.
But now i can only install titan 18 alpha version, witch is not as good as previous version.
Can i get a previous version somewhere?
(2021-04-03, 17:49)bacardicola Wrote: [ -> ]I went back to kodi 18.9 version due to playback stuttering issues on shield and skin titan problems in matrix.
i have the problem, since i have titan matrix the picture is stuttering every few seconds...
any help for this?
(2021-04-02, 11:23)Lessram Wrote: [ -> ]Yes, finally, it worked in this order of installation
1) Kodi - Matrix
Thanks All !!
Thanks Lessram,
Worked like a charm.
The latest alpha failed to installed, any suggestions
2021-04-05 01:42:39.254 T:4140 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting zip://C%3a%5cUsers%5cAdmin%5cDesktop%5cKodi%5cskin.titan.mod.beta.matrix-19.1.19%7ealpha-.zip/
2021-04-05 01:43:06.165 T:4140 INFO <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2021-04-05 01:43:26.377 T:7336 ERROR <general>: CAddonInstallJob[skin.titan.mod.beta.matrix]: The dependency on script.skin.helper.backgrounds version 1.0.0 could not be satisfied.
2021-04-05 01:44:39.181 T:3368 INFO <general>: CActiveAESink::OpenSink - initialize sink
Deleted.
Sorry, post was for skin "SWAN", which I test parallel. However, Titan MOD currently still is my favorite since it supports everthing I need. Keep up the good work!
Ah OK For me Titan is the best
I still can't get it to work well with Matrix, but I'm still testing.
It is especially the choice of wallpapers, thumbnails and the format of widgets that does not work.
Then i have to see the replacement of ArtworkDownloader
Regards
[Edit]
Work with a fresh install ( Thubnails and co)
By
Hi Guys.
I have created a new repo for you so Titan Mod Matrix can be automatically installed with all dependencies.
Here is the link to the repo:
repository.fuchs246-1.0.0.zip
- Install Kodi Matrix
- Go to "Settings / System / Add-ons"
- Choose "Unknown Soures"
- Update Official add-ons from => "Any Resositories"
- Go to "Install Form Zip File"
- "repository.fuchs246-1.0.0.zip" install
- Go to "Install from Repository"
- Choose "Fuchs Repo"
"Look and feel" => "Skin" => "Titan - Mod"
- Click Install
- Done!
Have fun with testing
