(2021-06-22, 15:11)Sei4eto Wrote: [ -> ] (2021-06-21, 19:33)Fuchs2468 Wrote: [ -> ] (2021-06-21, 18:29)Sei4eto Wrote: [ -> ]Hello!
I try to install the skin, but the repo link from the first post is not working.
Could someone share working repo link?
Here is the link to the "Fuchs-Repo".
repository.fuchs246.zip
Thanks for the repo.
I Just wondered if could provide TITAN MOD for KODI 18 repo as well?
You'll get it in the MardukL's repo.
Checkout the OP of this thread.
(2021-06-30, 13:07)VikramSandhu Wrote: [ -> ] (2021-06-22, 15:11)Sei4eto Wrote: [ -> ] (2021-06-21, 19:33)Fuchs2468 Wrote: [ -> ]Here is the link to the "Fuchs-Repo".
Thanks for the replay.
Unfortunately MardukL's repo is not found on GitHub page
(At least the link in the first post doesn't work for me)
(2021-06-30, 13:36)Sei4eto Wrote: [ -> ] (2021-06-30, 13:07)VikramSandhu Wrote: [ -> ] (2021-06-22, 15:11)Sei4eto Wrote: [ -> ]Thanks for the repo.
Unfortunately MardukL's repo is not found on GitHub page (At least the link in the first post doesn't work for me)
A recent version of Titan-Mod for Leia is located on Mardukl's repo.
The repo link from Thread # 1 is unfortunately no longer up to date, must be changed by @
mardukL .
Here are the required repos for Titan-Mod Leia:
repository.marduk-1.0.5.zip
repository.marcelveldt-1.0.3.zip
MardukL is currently working on its new skin "Swan", I currently only work on Titan-Mod for Matrix, so Titan-Mod for Leia is a bit in the background.
Is it possible to make the metadata in the left corner of the footerbar a little bigger, now its very small and hard to read.
Also why does it take so long to show the tomaten and metric ratings to show (almost 30 secondes and is included in the nfo ), while IMDb rating show right away.
thx.
(2021-07-03, 18:28)bacardicola Wrote: [ -> ]Is it possible to make the metadata in the left corner of the footerbar a little bigger, now its very small and hard to read.
thx.
It is not enough space to make the symbols larger, otherwise it would come to overlays with other display elements.
I wear a glasses and can still see everything very well.
In addition, 2 symbols have been added.
I suspect you searched for your movies with "The Movie Database", he searches only IMDB reviews and TMDB reviews (if you have set it).
Tomato and metric ratings will be sought in your case only by SkinHelper as they are not in the database.
Please use "Universal Movie Scraper" and take the time to set it correctly, then you get all the reviews immediately displayed.
If you want to use Locale Info, you should of course use the corresponding scraper for it.
Fuchs2468, I have a question in the version of this skin for Kodi 18, when you hit info on say a movie, there was a button for artwork beef. But with the Kodi 19 version, the button is not there. I see in IncludesDialogVideoInfo.xml it still shows in there. So I am wondering if I am missing something or if there is a way to make this work. I use this a lot and am really going to miss it if there is no way to make it work in 19.
Thanks in advance for any help, UbuntuUser
(2021-07-09, 01:02)UbuntuUser Wrote: [ -> ]@Fuchs2468, I have a question in the version of this skin for Kodi 18, when you hit info on say a movie, there was a button for artwork beef. But with the Kodi 19 version, the button is not there. I see in IncludesDialogVideoInfo.xml it still shows in there. So I am wondering if I am missing something or if there is a way to make this work. I use this a lot and am really going to miss it if there is no way to make it work in 19.
Yes, the function is still available in the Skin but only displayed when Artwork Beef is installed.
Use at Kodi 19 "Choose Art".
This has the same function as Artwork Beef at Kodi 18.
(2021-07-09, 11:44)Aphykit2006 Wrote: [ -> ] (2021-07-09, 05:49)AchillesPunks Wrote: [ -> ] (2021-07-09, 01:02)UbuntuUser Wrote: [ -> ]@Fuchs2468, I have a question in the version of this skin for Kodi 18, when you hit info on say a movie, there was a button for artwork beef. But with the Kodi 19 version, the button is not there. I see in IncludesDialogVideoInfo.xml it still shows in there. So I am wondering if I am missing something or if there is a way to make this work. I use this a lot and am really going to miss it if there is no way to make it work in 19.
Try artwork beef matrix
https://github.com/henryjfry/fryhenryj/b...p?raw=true
Hi
Artwork Dump
https://forum.kodi.tv/showthread.php?tid...twork+dump
Yes artwork dump is nice but if you liked artwork beef then artwork dump will not cut it. I much prefer artwork beef.
(2021-07-09, 02:35)Fuchs2468 Wrote: [ -> ] (2021-07-09, 01:02)UbuntuUser Wrote: [ -> ]@Fuchs2468, I have a question in the version of this skin for Kodi 18, when you hit info on say a movie, there was a button for artwork beef. But with the Kodi 19 version, the button is not there. I see in IncludesDialogVideoInfo.xml it still shows in there. So I am wondering if I am missing something or if there is a way to make this work. I use this a lot and am really going to miss it if there is no way to make it work in 19.
Thanks, in the past I was able to replace all instances of "script.artwork.beef" with "script.artwork.downloader" and it worked I was still able to use artwork downloader. But in this version when I do that I get the button, but it does not work. Everytime I try to run it I get this error in the log...
ERROR <general>: Keymapping error: no such action 'xbmc.runscript(script.artwork.downloader, mode=gui, mediatype=movie, dbid=4582)' defined
There is a new version of artwork downloader for matrix and that is what I am using. Any help would be greatly appreciated.
Thanks, UbuntuUser
