Hello
Thank you for all this work
- movie lists
I'm not if it's normal, but I no longer have the clearlogo (top or bottom).
- movieinfo
Trailer (movie) : never worked ;Thanks for the desactivation.
playing youtube trailer start in background, is it possible to start it in a window ?
extended videoinfo: works well.
Is there a way to configure embuary infos to have the same theme (color and shape)?
Thank you for thinking one day about the management of personal moviegenre.
Regards
(2021-09-07, 09:24)Aphykit2006 Wrote: [ -> ]Hello
- movie lists
- movieinfo
Regards
Thanks for the error message.
Error Clearlogo is fixed, new update.
The other things I will try to implement if I have time.
Hi Guys,
Can someone please check in case I'm doing something stupid. When navigating to TV shows the skin will only display Thumb for Season all and not for Season 01 as example in BIG Panel View.
Have checked other skins and still functions fine with v19.
Thanks in advance
(2021-09-12, 21:10)xessive100 Wrote: [ -> ]Hi Guys,
Thanks in advance
I saw, you have asked the same question at Titan Bingie.
Therefore, the question to you first. Which skin do you mean Titan MOD or Titan Bingie?
If you use titan_mod, which version did you install?
With Titan Mod, this view works.
(2021-09-12, 23:00)Fuchs2468 Wrote: [ -> ] (2021-09-12, 21:10)xessive100 Wrote: [ -> ]Hi Guys,
Thanks in advance
Hi Fuchs,
Yeah your right i posted in Bingie until i realised its no longer supported. Yes the issue was with Bingie. I've reverted back to Titan M O D now and your correct - works perfect! Thanks so much, was worried i might have to change away from Titan.
Thanks again
A short info about my next update.
There are still some problems that I have to solve.
I am working on Extended Info (Embuary-Info) to adapt the selected design or the Skin theme.
Here is a small preview:
Hi
Cool
seems like VIP info.
Good work. Respect.
How can I make the main menu stay in place on not hide when moving right to the widgets?
(2021-09-26, 10:59)burekas Wrote: [ -> ]Hi,
Which layout do you use for the main menu?
(2021-09-26, 11:12)Fuchs2468 Wrote: [ -> ] (2021-09-26, 10:59)burekas Wrote: [ -> ]Hi,
Simple confluence-style homescreen vertical
(2021-09-26, 15:21)burekas Wrote: [ -> ] (2021-09-26, 11:12)Fuchs2468 Wrote: [ -> ]
Activate "Titan Default Homescreen Layout".
Then the animation of the main menu is deactivated.
