Hi @
Fuchs2468 is there a way to load widgets more faster, to have a skin more responsive ?
I use Kodi on my Shield 2019 and with Titan MOD skin, Kodi is really slow.
If i switch to another skin, like SWAN for example, Kodi is definitly more faster and responsive.
(2021-04-09, 23:39)kokoplex Wrote: [ -> ]Hi @Fuchs2468 is there a way to load widgets more faster, to have a skin more responsive ?
The skin is heavy already and it's also relying on shs, so the faster the system the better. Disable views you don't use.
My views are already optimized for me.
I think shs became heavier because on SWAN shs is disabled, it's a pity
About Skin.Helper.Widgets or Plugins loaded widgets have a longer loading time.
Widgets that are loaded directly via the library to load immediately.
Example slow:
Recently added Movies
plugin://script.skin.helper.widgets/?action=recent&mediatype=movies&tag=&reload=$INFO[Window(Home).Property(widgetreload-movies)]
Example fast:
library://video/movies/recentlyaddedmovies.xml
Fuchs2468
Hi.
Very good work.
Just rest some details.
Is it the moment for some request/ evolutions about Titan Matrix mod ?
Or you prefer later ?
Regards
Hi Guys I am not sure which of the Titan addons that is causing the cpu to run high and loud, before I installed the Titan skin the cpu was runing very low and quiet (pic1), shortly after installing Titan the cpu runs high and even when I switch back to confluence (pic2). The cpu returns to normal after I restated Librelec with confluence skin, please advise which addon to turned off in order to use Titan without cpu running high
(2021-04-13, 04:14)t123thomas Wrote: [ -> ]Hi Guys I am not sure which of the Titan addons that is causing the cpu to run high and loud, before I installed the Titan skin the cpu was runing very low and quiet (pic1), shortly after installing Titan the cpu runs high and even when I switch back to confluence (pic2). The cpu returns to normal after I restated Librelec with confluence skin, please advise which addon to turned off in order to use Titan without cpu running high
I believe this had to do with skin helper as well.
(2021-03-30, 02:54)t123thomas Wrote: [ -> ]@Fuchs2468,
@AchillesPunks
Please dont forget to add these changes to the skin this is to ensure Matrix Titan Skins are compatible Matrix- Emby Next gen plugin
IncludesSkinSetings.xml
<selected>Skin.HasSetting(SmartShortcuts.emby) + System.HasAddon(plugin.video.emby)</selected>
<enable>System.HasAddon(plugin.video.emby)</enable>
should be:
<selected>Skin.HasSetting(SmartShortcuts.emby) + System.HasAddon(plugin.video.emby-next-gen)</selected>
<enable>System.HasAddon(plugin.video.emby-next-gen)</enable>
and here:
<param name="addon" value="plugin.video.emby" />
should be:
<param name="addon" value="plugin.video.emby-next-gen" />
Fuchs2468,
AchillesPunks
I am wondering if these changes have taken, effect as it apears not in the latest Fuchs MOD, I was able to make the changes in windows, but I searched through Libreelec folders I couldn't find where the Titan MOD and helper to make changes myself. Appreciate if can point me to the files I am using WINSCP to connect to Libreelec root folders
As you can see emby addon is not active, because the name has not changed to plugin.video.emby-next-gen from plugin.video.emby
Unfortunately, I can not tell you why that's the case with you, I have a Raspiberry 3+ and there is no Kodi 19 version of Libreelec yet.
You have to wait a while.
In general, however, I can tell you that the Skin Helper needs after a new installation, for a while until he has all the information he needs.
Of course, this can mean that your Raspberry 4 has a high CPU load for this time.
(2021-04-14, 01:13)t123thomas Wrote: [ -> ] (2021-03-30, 02:54)t123thomas Wrote: [ -> ]
Not only the change in the skin is required for this purpose.
Of course, it must also be changed "script.module.metadatautils", "script.skin.helper.backgrounds" and "script.skin.helper.widgets".
(2021-04-14, 01:35)Fuchs2468 Wrote: [ -> ] (2021-04-14, 01:13)t123thomas Wrote: [ -> ] (2021-03-30, 02:54)t123thomas Wrote: [ -> ]
I can make the chages myself as temp solution until the skinhelper and widgets is fixed from source.
Please direct me to the folder which contain this info in libreelec
(2021-04-12, 16:39)Aphykit2006 Wrote: [ -> ]@Fuchs2468
Hi.
Very good work.
Regards
It depends on what it is, whether it is time-consuming or can be realized quickly.
(2021-04-14, 01:20)Fuchs2468 Wrote: [ -> ] (2021-04-13, 04:14)t123thomas Wrote: [ -> ]Hi Guys I am not sure which of the Titan addons that is causing the cpu to run high and loud, before I installed the Titan skin the cpu was runing very low and quiet (pic1), shortly after installing Titan the cpu runs high and even when I switch back to confluence (pic2). The cpu returns to normal after I restated Librelec with confluence skin, please advise which addon to turned off in order to use Titan without cpu running high
Thanks, the noise and usage have returned to normal, I am guessing that the the initial installation caused the unusual demand for cpu resource, after several reboot the system is quient
