2021-02-20, 12:20
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
2021-02-20, 12:20
2021-02-20, 12:49
it won't let me install on Leia first at all, so thus I cannot update to Matrix
2021-02-20, 15:10
If you want to test the skin on the Kodi matrix version, here are brief instructions.
First unzip zip
Open "addon.xml" with editor.
search line:
change for matrix in
then pack everything back into a zip file.
Now you only need all matrix compatible "skin.helper.service" files.
look here:
https://github.com/kodi-community-addons
Install Titan-Mod on Leia.
Define your own themes if desired.
Who uses widgets via "Skinhelper Service Widgets" also specify.
If the skin is configured on Leia according to your wishes go to:
"\ userdata \ addon_data \ skin.titan.mod.beta.leia \"
Copy content "settings.xml" and "themes"
Files then in the matrix version in
insert again.
Start Kodi matrix with titan-mod.
Views must be specified with Force Views.
Now the skin should work with matrix.
First unzip zip
search line:
<import addon = "xbmc.gui" version = "5.14.0" />
<import addon = "xbmc.gui" version = "5.15.0" />
look here:
insert again.
2021-02-20, 22:02
(2021-02-20, 12:14)Fuchs2468 Wrote: [ -> ]I discovered a little bug in my new version if you already downloaded it, please update it again.1. I use the enhanced all in one home screen. After I the update, the color borders are no longer around the widgets. I can no longer see which home widget I am selecting. In settings you can't change those colors anymore.
Here again the link with the updated version: skin.titan.mod.beta.leia-18.1.19~alpha.zip
2. The new screen shots you posted. Is that only for the home screen? Is that layout possible for Netflix media views(movies/TV/music)?
3. I use the Netflix view in the music section. After the update, the Netflix view for music looks and responds different from the others(Movies/TV). Artist selection is stuck in non fixed focus mode I guess. If I move to the next artist the widget remains on the left side of the screen. Before update the artist is selected from the center of the screen, now focus is on the left. Also the color border is missing.
Thanks for any help
2021-02-20, 22:21
Hi.
Sorry, for the moment, i don't see any difference.
May be french language.
More test tomorrow.
More test tomorrow.
2021-02-21, 05:03
(2021-02-20, 22:02)teedo42 Wrote: [ -> ](2021-02-20, 12:14)Fuchs2468 Wrote: [ -> ]I discovered a little bug in my new version if you already downloaded it, please update it again.1. I use the enhanced all in one home screen. After I the update, the color borders are no longer around the widgets. I can no longer see which home widget I am selecting. In settings you can't change those colors anymore.
Thanks for any help
1.
i have just tested with a new clean kodi installation.
skin installed.
database for new installation copied so that I have content.
and switched to the expanded all-in-one home screen.
Otherwise nothing changed in the standard setting of the skin.
result everything is displayed as it should be and border color is also available.
2.
this works for all netflix views in this skin for Movie and TV.
3.
As the name suggests "Netflix" view is intended and optimized for movies and TV.
This view does not call up all information about the music.
i will lock this view for music in a later update.
I just forgot that in this update.
addition to 1.
The border color and width can easily be changed in the settings.
I quickly tested it.
2021-02-21, 07:19
(2021-02-21, 05:03)Fuchs2468 Wrote: [ -> ]OK, somewhere I screwed up. I was hoping I didn't have to start over. So many custom settings to set.(2021-02-20, 22:02)teedo42 Wrote: [ -> ](2021-02-20, 12:14)Fuchs2468 Wrote: [ -> ]I discovered a little bug in my new version if you already downloaded it, please update it again.1. I use the enhanced all in one home screen. After I the update, the color borders are no longer around the widgets. I can no longer see which home widget I am selecting. In settings you can't change those colors anymore.
Thanks for any help
1.
skin installed.
2.
3.
addition to 1.
I forgot to mention earlier; I like your resizing and addition of logos for language and resolution. Nice work.
Thanks again.
2021-02-21, 17:42
(2021-02-20, 15:10)Fuchs2468 Wrote: [ -> ]If you want to test the skin on the Kodi matrix version, here are brief instructions.
First unzip zip
search line:
Code:<import addon = "xbmc.gui" version = "5.14.0" />
Code:<import addon = "xbmc.gui" version = "5.15.0" />
look here:
insert again.
Hey thanks for the instructions. I follow your steps but when I try to installed the newly pack zip file, it said "ERROR <general>: CAddonInstallJob[skin.titan.mod.beta.leia]: The dependency on xbmc.python version 2.13.0 could not be satisfied."
I made sure to change the xbmc.gui version to 5.15.0 so I'm confused why it will ask for python version 2.13.0
2021-02-21, 18:42
So I tried downloading from this link and I'm getting an error about not being able to find CherryPy 17.0.0... but the latest version I can find for Kodi is 12.0.1. Can you just install the tarball version from the main CherryPy site, and does it still support Python 2? Running Kodi 18.9 on AndroidTV.
Never mind. Found a site with 17.4.2 (https://files.xbmcbrasil.net/Kodi/repo/s....cherrypy/) that seems to work. Quick FYI, however, doing a bit of looking, it seems CherryPy 17.x.x was the last one to support Python 2, so make sure not to update to v18 or later until on Matrix.
2021-02-21, 19:58
(2021-02-21, 17:42)Shinobi_Wan Wrote: [ -> ]
I was getting the same issue. Some addon is still out of date. Grab the zip file from this thread (https://forum.kodi.tv/showthread.php?tid...6&page=283) and just go through and make sure to update everything.
Hopefully Fuchs2468 can figure out the issue with Kodi 19 since it just hit stable yesterday.
2021-02-22, 07:54
(2021-02-21, 19:58)aerogems Wrote: [ -> ](2021-02-21, 17:42)Shinobi_Wan Wrote: [ -> ]
Thanks for the link, going to give this a go now. Hopefully this will help me here
EDIT: Got it all working now by downloading the files from the link. Thank you again for the help!
2021-02-22, 08:47
@Fuchs2468, Thanks for your support, as mentioned previous in this thread, it appear that Titan Skin does not recognized the new emby for Kodi addon, there another revised version which more efficient that previous the one is titled emby-next-gen. I add the log link for your interest.
Kodi Log
1, Kodi (18.9 (18.9.0)
2, ADDON: skin.titan.mod.beta.leia v18.1.19~alpha.1 installed
3, ADDON: plugin.video.emby-next-gen v5.1.17 installed
Thanks for taken a look, let me know when to test.
Kodi Log
2021-02-23, 02:09
(2021-02-22, 08:47)t123thomas Wrote: [ -> ]@Fuchs2468, Thanks for your support, as mentioned previous in this thread, it appear that Titan Skin does not recognized the new emby for Kodi addon, there another revised version which more efficient that previous the one is titled emby-next-gen. I add the log link for your interest.
Kodi Log
I fixed the issue of new emby not been recognized by titan as you can see these missing info appears a Emby-Next-Gen
2021-02-23, 04:47
(2021-02-23, 02:09)t123thomas Wrote: [ -> ]Today I wanted to write to you that you simply replace "plugin.video.emby" with "plugin.video.emby-next-gen" in the skin and also in the SHS add-ons.(2021-02-22, 08:47)t123thomas Wrote: [ -> ]I fixed the issue of new emby not been recognized by titan as you can see these missing info appears a Emby-Next-Gen
I tested it yesterday with jellyfin.
2021-02-23, 05:18
Hello friends from Titan-Mod Skin !!
I have very good news for you guys!
I have now got the skin on Matrix running so that it now works without any tricks.
I will be creating a matrix version for Titan-Mod in the next few days, but I have to test a bit first.
