(2021-06-04, 11:21)Lessram Wrote: [ -> ]What is the latest version of the Kodi Skin?
Is there already a complete pack, or is it still needed to download and install all the depenencies first?
Only "Fuchs repo" install and select Titan mod, rest goes automatically.
Here is the link to the repo:
repository.fuchs246-1.0.0.zip
(2021-06-05, 02:06)Fuchs2468 Wrote: [ -> ]Only "Fuchs repo" install and select Titan mod, rest goes automatically.
Here is the link to the repo: repository.fuchs246-1.0.0.zip
Thank you. This works perfect.
The earlier way with installing all dependencies seperately slowed my system enormously, and caused crashes.
Now it finally works as before.
(Sadly you didn't include the Uni font yet that includes Thai, Chinese, Greek and alike caracters)
Fuchs2468 Is it a known issue that poster artwork for TV seasons doesn't work? Specifically the Big Panel view, all I get are black boxes. If I switch to Estuary, the artwork shows up, but if I go back to your Titan MOD, black boxes again. I'm using the PlexKodiConnect addon to download all the metadata from my Plex server. I know this wasn't an issue back with 18.9. It's more of an annoyance than anything, but if you could fix it, you would be my favorite person for the day.
(2021-06-04, 00:17)Fuchs2468 Wrote: [ -> ]@t123thomas
I am not very familiar with Python but so much I know, no hyphen should be used in a name at Pyhton. (emby-next-gen)
As a test, I also rewritten "plugin.video.emby-next-gen-5.3.1" in "plugin.video.emby_next_gen-5.3.1". (exactly 142 changes)
So I was able to integrate it without error in SHS.
Result:
Smart Shortcut does not work with "plugin.video.emby-next-gen", no idea what has been changed in this addon.
Fuchs2468, I relayed your comment and even share this link with developer of emby-next-gen, in his response it appear that logic have been deleted from the his addon hence to repair the codes,
could you please provide the locations specific areas in the Titan skin which drives the SMARTSHORTCUT and SUBMENU so I can have the developer to troubleshoot where his logic have missed these codes.
Is anyones database slow to refresh for new content since the change to newer version of Kodi and this skin ??
Is there a setting where I can disable the black border around the cover art for CD's in the left corner.
I'd esspecially want to remove the black faded corners, but I don't know where to find the setting for this.
(2021-06-06, 11:16)Lessram Wrote: [ -> ]Is there a setting where I can disable the black border around the cover art for CD's in the left corner.
Hi
It's in playback & OSD.
You use Default OSD. Try a change :
PVR channel osd bar no signal tvheadend, signal, etc.
Can it be improved in an update?.
Thank you, Great Skin.
(2021-06-06, 01:09)t123thomas Wrote: [ -> ] (2021-06-04, 00:17)Fuchs2468 Wrote: [ -> ]
@Fuchs2468, I relayed your comment and even share this link with developer of emby-next-gen, in his response it appear that logic have been deleted from the his addon hence to repair the codes,
Since there are now "EMBY" and "Jellyfin", I decided for the free Jellyfin server variant.
I will soon suggest the changes for SHS.
Pro "EMBY":
- "plugin.video.emby" was already integrated in this skin, and works until Kodi 18.
Contra "EMBY":
- "plugin.video.emby" was renamed in "plugin.video.emby-Next-Gen"
- Working effort at SHS is high, code needs to be rewritten.
(This can not be easily renamed in SHS because hyphens are present in the name.)
- For "plugin.video.emby-Next gene", the required code for "Smart Shortcut" was removed.
Pro "Jellyfin":
- Server is free
- The Jellyfin Addon also works with Emby
- Working effort at SHS is small ("emby" only has to be replaced by "jellyfin")
Contra "Jellyfin"
Now please write me your Pro and Contra.
(2021-06-07, 00:09)Friend Wrote: [ -> ]PVR channel osd bar no signal tvheadend, signal, etc.
No, that's not the skin.
This function must be supported by the tvheadend-server.
No signal at tvheadend, no signal on Kodi.
(2021-06-05, 15:38)aerogems Wrote: [ -> ]@Fuchs2468 Is it a known issue that poster artwork for TV seasons doesn't work? Specifically the Big Panel view, all I get are black boxes. If I switch to Estuary, the artwork shows up, but if I go back to your Titan MOD, black boxes again. I'm using the PlexKodiConnect addon to download all the metadata from my Plex server. I know this wasn't an issue back with 18.9. It's more of an annoyance than anything, but if you could fix it, you would be my favorite person for the day.
The problem should be fixed with the next update. You do not have to wait a long time.
(2021-06-06, 03:38)ThatSlimGuy Wrote: [ -> ]Is anyones database slow to refresh for new content since the change to newer version of Kodi and this skin ??
For your database this skin is not responsible.
This work does your Movie Scraper OR TvShow Scraper.
Since from Kodi 19 the Scraper also takes over the work of Artwork-Beef, it could take the scan longer.
(2021-06-07, 01:38)Fuchs2468 Wrote: [ -> ] (2021-06-07, 00:09)Friend Wrote: [ -> ]PVR channel osd bar no signal tvheadend, signal, etc.
Information in the OSD bar the television channels of The MovieDB Helper?. Would it be possible this skin?. Thank you.
