2021-11-15, 23:57
(2021-11-15, 04:59)sampercy Wrote: [ -> ]Thanks for that, it worked. Looks like an excellent skin. I've tried about a dozen now. Seems my old skin of choice - Andromeda - is no longer going to be viable.
Is there any sort of guide for setting it up? I am getting there but don't want to ask a bunch of noob questions on here. For example, it keeps asking me to install a YouTube add-on, which I'd rather not do. Or is it harmless? And there is an inaccessible power button at the bottom of the screen. I can't get to it with a remote control. Can I remove it?
Plus about a dozen more...
Unfortunately, there are no direct instructions for this skin.
The skin is very extensive, just test the settings a little.
You can install the youtube addon without risk. If you don't need it just deactivate it.
If you are in the standard layout, just press down button on your remote, then you can use the functions of the power button.
You can also hide the symbol for this in the settings.
Here are just four layouts as an example, there are even more possibilities.
