(2021-04-30, 06:42)t123thomas Wrote: [ -> ]
I can not do much with this log file.
Which mistake in the skin has occurred with you?
So what did not work for Titan-Mod?
Glad @
mardukL is alive and well. Life has intensified priorities for me as well. I'm going to experiment with the new Matrix version and attempt to get the media flags working as time permits. I've also read about the annoying Youtube popup issue some of you are having. If you have local trailers, it will keep popping up because one or more of your movie trailers are missing in your library. It looks for Youtube to play the trailer that's missing, even though you've disable it. Once you find and add the trailer, the popup notification stops.
Hello friends
"Fuchs Repo" had a mistake yesterday for several hours.
Please check the updates.
look here:
Yesterday I tried subtitles for the first time in Matrix -they worked in Leia.
In Matrix there are no flags for Titan Mod -so, it's pretty hard to get the right sub.
Anyone knows a solution?
(2021-05-09, 09:52)csts Wrote: [ -> ]Yesterday I tried subtitles for the first time in Matrix -they worked in Leia.
Here is the solution to the problem:
https://forum.kodi.tv/showthread.php?tid...pid3026530
(2021-05-09, 10:05)Fuchs2468 Wrote: [ -> ] (2021-05-09, 09:52)csts Wrote: [ -> ]Yesterday I tried subtitles for the first time in Matrix -they worked in Leia.
Thank you that worked perfectly.
Had to start from scratch cause there was just far to many errors and I don't have the time to get through fixing each and everyone of them, but I'm glad to have new version with titan skin.
2 questions I'm hoping to get some help with, setting the widgets to show as small posters on the main screen no longer seem to be centred, is this a bug or still being worked on?
Other question is that every single poster whether tv or movie has either a play icon on it, or 3 little dots, can this be removed so it shows the poster art on its own?
Appreciate all the work it took to get this running!!
I followed your instructions and replaced the DialogSubtitles.xml file ,restarted the kodi build etc. After playing a movie and downloading subs,there was no change in flags ,just the flags before with the numbers.I am on Android box,aby help or maybe a new file will be great thanks.
(2021-03-27, 14:56)Fuchs2468 Wrote: [ -> ] (2021-03-27, 08:41)simtaj Wrote: [ -> ]I use Titan mod 19.1.19 alpha.1 on Matrix. Does anybody have problems with language flags? For me is not working, when I search for subtitles (opensubtitles or addicted7) there is no flags like it was on Leia. On default Estaury skin flags are working for me.
Can anybody help, because it is difficult to download subtitles without flags...
Thank you !
I had overlooked that at the update.
go to:
"\addons\skin.titan.mod.beta.matrix\1080i\"
and replace the file: DialogSubtitles.xml
With this file: DialogSubtitles.xml
This applies to the versions Titan.mod 19.1.19 Alpha.1 and Titan.mod 18.1.19 Alpha.1 .
I replaced the DialogSubtitles.xml as per your instructions,restarted the build and tried downloading subs again,but there was no change in the flags and the results came back with the old flags that has a number interger at the begining of the .srt subtitles.Is there another .xml that can be used or solution,I am using Android box
