@Fuchs2468 Sorry, the skin works fine.
I unplugged the power supply and that helped...
I don't know what caused the Android TV hardware failure, but both versions of the skin now work very well.
Regards
(2023-09-16, 14:28)Arkady1964 Wrote: [ -> ]Sorry, the skin works fine.
Thanks for the feedback.
I'm glad to hear that everything works.
hey Fuchs2468 ... any idea when you'll be able to look at/fix the ratings view ? The tvdbhelper didn't fix it for me .. so I'm still running the previous version, but I would like to upgrade of course. If I come over as pushy, I apologize .. I Know how much time & effort you already put it in here for everybody.
(2023-09-23, 10:37)aneurysm- Wrote: [ -> ]hey Fuchs2468 ... any idea when you'll be able to look at/fix the ratings view ? The tvdbhelper didn't fix it for me .. so I'm still running the previous version, but I would like to upgrade of course. If I come over as pushy, I apologize .. I Know how much time & effort you already put it in here for everybody.
Yes, I'm working on it.
You use NFO files as you wrote.
What if you don't use an NFO file?
Here's a test for you:
- you have Kodi 20 installed
- you have an empty "MyVideos121.db" (just delete if not)
- if present, "MyVideos119.db" or "MyVideos116.db" must be deleted
- you have installed Titan MOD 20.0.24
- you have installed “TheMovieDb Helper”
- you have installed and set up "The Movie Database Python" scraper
- you entered the OMDB apikey in "TheMovieDb Helper" and in "Metadata and Artwork module"
- create a test folder with 4-5 known movies
- add the folder to the database (use "The Movie Database Python" scraper)
Done!
If you did everything correctly you should now see all the reviews.
Please let me know the result.
Since I don't know what your NFO files look like, send me one to test.
Google Translate may be having problems translating my post above this post.
That's the case for me at the moment. Part of my contribution is missing.
(2023-09-24, 01:26)Fuchs2468 Wrote: [ -> ] (2023-09-23, 10:37)aneurysm- Wrote: [ -> ]hey Fuchs2468 ... any idea when you'll be able to look at/fix the ratings view ? The tvdbhelper didn't fix it for me .. so I'm still running the previous version, but I would like to upgrade of course. If I come over as pushy, I apologize .. I Know how much time & effort you already put it in here for everybody.
Done!
Hey .. I sent you a pm with a nfo file.
Also did exactly what you said here, no difference. I'm seeing ratings when I go into the "info" view of the movie. But on the main view, nothing except tmdb rating (and imdb top250) is showing up. Tried with both settings in the skin settings as well (with or without skinhelper help).
(2023-09-24, 10:50)aneurysm- Wrote: [ -> ] (2023-09-24, 01:26)Fuchs2468 Wrote: [ -> ] (2023-09-23, 10:37)aneurysm- Wrote: [ -> ]hey Fuchs2468 ... any idea when you'll be able to look at/fix the ratings view ? The tvdbhelper didn't fix it for me .. so I'm still running the previous version, but I would like to upgrade of course. If I come over as pushy, I apologize .. I Know how much time & effort you already put it in here for everybody.
Done!
Just a question but how do you get your .nfo file? Do you scrape through Kodi or use a program like TinyMediaManager?
(2023-09-24, 12:31)AchillesPunks Wrote: [ -> ] (2023-09-24, 10:50)aneurysm- Wrote: [ -> ] (2023-09-24, 01:26)Fuchs2468 Wrote: [ -> ]Yes, I'm working on it.
Done!
I have been using mediaelch the last few years.
(2023-09-24, 13:23)aneurysm- Wrote: [ -> ] (2023-09-24, 12:31)AchillesPunks Wrote: [ -> ] (2023-09-24, 10:50)aneurysm- Wrote: [ -> ]Hey .. I sent you a pm with a nfo file.
Are you using it to add all the ratings into the .nfo? If so this is just something to try I had the same issue about 1 year ago. Try and just get mediaelch to only get the ratings for the TMDB only no other ratings. Then add the movie into Kodi and see if you get the ratings.
(2023-09-24, 20:07)AchillesPunks Wrote: [ -> ] (2023-09-24, 13:23)aneurysm- Wrote: [ -> ] (2023-09-24, 12:31)AchillesPunks Wrote: [ -> ]Just a question but how do you get your .nfo file? Do you scrape through Kodi or use a program like TinyMediaManager?
tried that. doesn't work. it's really something that has changed with this version of the skin.
kodi v20.2 with skin v19 every rating shows.
it's with skin v20 that the problem comes.
I didn't have much time to test today.
My first quick test with your nfo file, with "TheMovieDb Helper" installed.
My first result is that everything that is in your nfo file is displayed.
But I'll take a closer look at it again.
Here Home menu and Video menu:
Indeed. Question is if themoviedbhelper overwrote values yes or no. Metacritic isn't in my nfo, so it downloaded that extra. To verify that, you should edit a value in the nfo file (for instance put the critics value at 70% instead of 57%) and see if it overwrites that.
But nevertheless, it's weird that your previous build had it working without themoviedbhelper and now it would be needed.
tnx again already for taking the time to investigate
Fuchs2468 My favorite skin has always been Titan. I'm glad that the skin has a sequel in the form of Titan MOD. The skin also has fans on the Polish Forum Kodiwpigulce:
mod edit, foreign URL deleted]
In Poland, the main devices for using Kodi are devices based on the Android TV system (boxes, TV sets). Titan MOD for Android TV works very well on Kodi 20 Nexus. However, installing from a zip file on Android TV may be tedious for some Titan MOD (Android TV) users.
Fuchs2468 please add a test version of the skin (with full functionality) of Titan MOD for Android TV to the repository, next to the stable version, before the next new skin update is ready. For easier and faster installation of the Titan MOD skin in the test version directly from the repository.
Regards
Fuchs2468
Hi.
I understand that you may not have time to upload the Titan MOD skin version with full functionality for Android TV users to the repository.
Thank you once again for your contribution to the development of the Titan MOD skin so far. This skin is popular with thousands of users who have always loved Titan.
Regards
(2023-10-06, 15:35)Arkady1964 Wrote: [ -> ]@Fuchs2468
Hi.
Regards
I don't update every time there's a change in the skin. That's why they received a trial version from me.
I'm currently working on an alternative frame for all views.
When I'm finished there will be an update.
Also with the change to the OSD.
I'm making good progress, I think it won't be too long until the update.
