bsoriano - Hey Bart,
I noticed on the Music Video widget, the "Label on Shelf" text does not scroll with long titles. It seems to be truncated. Also, on the Music widget, is it possible to add an option to turn on/off the "Label on Shelf" option, even on other configured widgets. For example my "self created" addon widgets don't have this on/off feature, or maybe that was by design? I've provided pics to show you exactly what I am referring to.
Regards,
Shedrock
(2020-07-10, 13:05)shedrock Wrote: [ -> ]@bsoriano - Hey Bart,
Regards,
Shedrock
shedrock, I will look into making the label scroll. For the square artwork, by design the textbox below the art is shown. To be clear, you would like the textbox to be optional for square? Please confirm. Thanks.
Regards,
Bart
(2020-07-10, 13:10)bsoriano Wrote: [ -> ] (2020-07-10, 13:05)shedrock Wrote: [ -> ]
@shedrock, I will look into making the label scroll. For the square artwork, by design the textbox below the art is shown. To be clear, you would like the textbox to be optional for square? Please confirm. Thanks.
Regards,
Bart
Sorry I wasn't specific in my post.
That's what I meat. To have option to turn it on/off.
Also, I am receiving a skin variables error. I am not sure if I should post the log here, or on the author's addon thread.
Logfile: https://paste.kodi.tv/epekagiwag.kodi
Cheers,
Shedrock
Hi again Bart,
I don't think it's necessary to add the scrolling text as I show in the image below. It is hardly likely to think that a Movie or TV Show title + Year & Time could be longer than the width of what is currently available. Maybe just increase the width a bit more? I can do it locally, but it would get overwritten on each update. Just a thought.
Regards,
Shedrock
(2020-07-10, 14:26)shedrock Wrote: [ -> ] (2020-07-10, 13:10)bsoriano Wrote: [ -> ] (2020-07-10, 13:05)shedrock Wrote: [ -> ]
Regards,
Bart
Sorry I wasn't specific in my post. That's what I meat. To have option to turn it on/off.
Cheers,
Shedrock
shedrock , I think you should post that error on the skinvariables thread. I don't know what can be causing that, and I am not getting that error.
As for the option to show/hide the textbox underneath the artwork for Square widgets (dynamic), I have added that just now on GitHub. You now will find a new option when configuring the widgets:
That will hide the textbox, and increase the size of the artwork accordingly. So the result from the screenshot above for me is:
As opposed to this, when the textbox is shown:
This is only on GitHub for now. Please download, test, and let me know if this is what you were looking for. Thanks.
Regards,
Bart
(2020-07-10, 17:34)shedrock Wrote: [ -> ]Hi again Bart,
Regards,
Shedrock
shedrock , while it is true that there is additional space as you point out, I am not planning on widening that label, since it would interfere with the label for the widget type (what appears on the right).
I went ahead and added on GitHub the option to have the label scroll. You can find the new option when you configure a widget that is Poster, Thumb or Fanart, and you enable the option to Show Label on Shelf:
Please download, test, and let me know what you think. Thanks.
Regards,
Bart
(2020-07-10, 18:27)bsoriano Wrote: [ -> ] (2020-07-10, 17:34)shedrock Wrote: [ -> ]
@shedrock , while it is true that there is additional space as you point out, I am not planning on widening that label, since it would interfere with the label for the widget type (what appears on the right).
Regards,
Bart
Thanks Bart. I am going to test it out in a few minutes and report back. As for the skin variables issue. This I believe only started when I decided to add another "User Profile". I have a backup installation before I created the second profile, and I will test that out and report back on the skin variables thread.
Thanks again for your hard work.
Shedrock
bsoriano - Hi Bart,
That option to Enable label scrolling is not working for me. It doesn't matter if I have it on or off, it still scrolls. The one for my music works as it should.
UPDATE: It partially works Bart. For example, if I add a playlist as one of my widgets, then it still scrolls regardless of the switch setting. If you want, I can post a video to show you what I am referring to.
Regards,
Shedrock
(2020-07-10, 20:02)shedrock Wrote: [ -> ]@bsoriano - Hi Bart,
Shedrock
shedrock , that's strange. I have tested the scrolling and it works as expected on my setup. In the screenshot below you can see I have three music video shelves, the bottom 1 (shelf 1) does not have label scrolling active, so you can see the ... after labels that are long and the labels do not scroll, while the other two have label scrolling active, and the labels do scroll.
If you would like, please post or PM your script-skinshortcuts-includes.xml file so I can see in more detail what Amber is generating for you. Thanks.
Regards,
Bart
bsoriano - Hi again Bart,
I had to toggle every one of the switches from on/off in order for it to work as intended, so now it seems to be just fine. I will let you now later on. I am just heading back to work.
Thank you so much. I also posted in the skin variables thread regarding that error. Hopefully @
jurialmunkey gets back to me on it.
Regards,
Shedrock
(2020-07-09, 23:33)bsoriano Wrote: [ -> ] (2020-07-05, 21:15)Cyberdom Wrote: [ -> ]With version 3.2.97 of Amber, I just noticed a defect in using the PVR with the logos of TV channels in the shelf of TV recordings.
Before, the logo of a TV channel was displayed correctly :
Now, the logo is cropped even when choosing the display in square mode :
@bsoriano can you rectify this in the next update so that the TV channel logos are displayed correctly in the shelf of TV recordings ?
Thanks in advance.
@Cyberdom , please test version 3.2.98. This should be fixed. Please confirm that it is indeed fixed. Thanks.
Regards,
Bart
Thank you @
bsoriano.
The TV channel logos are displayed correctly again in the TV recordings shelf.
bsoriano - Hi Bart,
Here is a link to a small video example of the issue as discussed in my last post. The issue with the scrolling text is still there unfortunately.
https://youtu.be/mG2kdaNjuN4
Regards,
Sehdrock
(2020-07-11, 00:26)shedrock Wrote: [ -> ]@bsoriano - Hi Bart,
Regards,
Sehdrock
shedrock, thank you for the video. It seems I misunderstood what label you wanted to scroll. The new option affects the label that appears on the poster itself, not the label at the top. So, I see that the label scrolls, which is standard behavior that I have not changed. Do you want an option for that top label to not scroll? Please confirm. Thanks.
Regards,
Bart
(2020-07-11, 01:48)bsoriano Wrote: [ -> ] (2020-07-11, 00:26)shedrock Wrote: [ -> ]
@shedrock, thank you for the video. It seems I misunderstood what label you wanted to scroll. The new option affects the label that appears on the poster itself, not the label at the top. So, I see that the label scrolls, which is standard behavior that I have not changed. Do you want an option for that top label to not scroll? Please confirm. Thanks.
Regards,
Bart
Hi Bart,
If it's not too much trouble to do, then that's fine. If it is, then I am okay with that also. I really feel bad that you had to add all that code for that feature. I apologize for that.
Thank you so much,
Shedrock
