Yep... will keep my main box on Nexus with Amber until there is either a good alternative (Arctic Horizon or Arctic Fuse seem OK and are "Omega ready" + actively developed but I'm too fond of Amber to switch for now).
Really hope Amber will be updated and maintained further.
(2024-01-10, 20:01)RyFeR Wrote: [ -> ]Installed it on the latest nightly (so after Omega beta 2)...
It will not install by default but after changing the following in addon.xml (in the Amber zip file):
<import addon="xbmc.gui" version="5.15.0"/>
to
<import addon="xbmc.gui" version="5.17.0"/>
it installed and I could use it. Not sure yet if it's stable and of course new functions are not implemented.
Thank you for this, Amber stopped working when I moved from 21beta2 to 21beta3 and your workaround fixed it. I don't use any of the things that folks say are broken so for me perfect solution. Will be a sad day when this skin dies, have tried all of them and the only other one that comes close to be able to make look like I want is Embuary, but Amber does everything and all how I want it.
Wow big mistake I just updated to Omega! I like Amber and don't want to lose it.
Me too. Any idea whether this skin will be updated to support Kodi v21?
