Full Version: Amber for Leia/Matrix/Nexus
(2021-10-05, 23:36)bsoriano Wrote: [ -> ]@Input1963 , it appears that you are using the GitHub version of Amber, correct? If so, then there was an issue with showing the Information Popup option when you have enabled "Show Information for Shelves" for the menu item.  I just fixed this on GitHub, you should be able to see the option again.
Bart,
It works fine now, no more double information with the popup and in the shelves.
Thx
H.
(2021-09-28, 21:48)G0mez Wrote: [ -> ]Forgot to mention this happends with big panel view and album covers been set to be shown small @bsoriano
@G0mez , I just fixed this issue on GitHub.  If you are able to download/test from GitHub, please do so and confirm that the issue is indeed fixed.  Thanks.
Regards,
Bart
Hi Bart,
             I noticed a few warnings / errors in my log and thought they might be of interest to you.   Oh I don't use shelves at all but I do have a PVR..
2021-10-07 12:20:07.232 T:9928 INFO <general>: initializing python engine. 2021-10-07 12:20:07.232 T:9720 INFO <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2021-10-07 12:20:07.254 T:9720 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup2shelvesbackground
2021-10-07 12:20:07.254 T:9720 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup3shelvesbackground
2021-10-07 12:20:07.254 T:9720 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup1
2021-10-07 12:20:07.254 T:9720 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup4
2021-10-07 12:20:07.255 T:9720 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup5
2021-10-07 12:20:07.255 T:9720 WARNING <general>: Skin has invalid include: skinshortcuts-template-shelfgroup6
2021-10-07 12:20:07.255 T:9720 WARNING <general>: Skin has invalid include: skinshortcuts-template-ShelfIndicator
2021-10-07 12:20:07.258 T:9720 WARNING <general>: Skin has invalid include: skinshortcuts-template-ShelfOnUpMainMenu
2021-10-07 12:20:07.309 T:9720 ERROR <general>: Control has invalid animation type (no condition or no type)
Also this one might be a typo
2021-10-07 12:37:28.760 T:9720 INFO <general>: Loading skin file: MyPVRGuide.xml, load type: KEEP_IN_MEMORY
2021-10-07 12:37:28.781 T:9720 ERROR <general>: Unmatched [
2021-10-07 12:37:28.781 T:9720 ERROR <general>: Error parsing boolean expression [!controlgroup(9000).hasfocus() + !control.hasfocus(909090)
The full log is at http://paste.kodi.tv/qofipapebe
cheers
John
(2021-10-07, 08:34)dawsonjw Wrote: [ -> ]Also this one might be a typo
@dawsonjw , yes, that one is a typo, which I just fixed on GitHub (Matrix only).  The other warnings you can just safely ignore, they are there because you are not using any shelves.   Thanks for pointing out the other warning.
Regards,
Bart
(2021-10-06, 18:21)bsoriano Wrote: [ -> ]
Regards,
Bart
Yes now it's showing correctly
3.4.29 is the latest?
(2021-10-10, 16:24)manthes Wrote: [ -> ]3.4.29 is the latest?
It is the latest in the Amber repo. Github is always the latest overall, I just have not changed the version number yet.
Regards,
Bart
Thanks. I installed from github and the widgets with the movie information looks amazing.
Maybe you can use the full width for plot summary but that's only my personal taste
(2021-10-10, 17:21)bsoriano Wrote: [ -> ]
Regards,
Bart
Leia version, I installed from Github 29/09/21 version 3.2.149, I assume there have been updates on Github since!
I did not have a repository and if I try to manually update it only shows Kodi add-on repository 3.2.123 .
Do I manually download and install?
(2021-10-10, 22:13)fsurfer Wrote: [ -> ]Do I manually download and install?
Yes.
(2021-10-10, 23:16)shedrock Wrote: [ -> ]
Yes.
Thanks, changelogs are identical 29/09/21 skin.amber-Leia.zip and 10/10/21 skin.amber-Leia (1).zip so it hasn't been updated
@bsoriano
greetings, do you intend to update the `Leia` branch to be consistent with `master` anytime soon, or should i start thinking about updating Kodi? haha
thanks
(2021-10-14, 11:52)BriceysCousin Wrote: [ -> ]@bsoriano
thanks
Hello!
Yes, I will be updating it this weekend (hopefully). I do encourage you to upgrade, unless you are using add-ons that do not work in Matrix yet. Please let me know if you have any questions about upgrading. Thanks.
Regards,
Bart
(2021-10-14, 13:34)bsoriano Wrote: [ -> ]
thanks
Hello!
Regards,
Bart
awesome! thank you!
yea i've been thinking it's about time to upgrade now that most of my addons seem to be leaving Leia in the dust
thanks
Hello!
Regards,
Bart
still on crossroads, as the updates per se are tweaks as Leia Amber and its required add-ons are rock solid, as is Estuary without question.
Whilst I see the differences between Python 2 and 3, plus the product support point of view. Scraping still takes ages in Matrix even though I have TMM as a front-end and have been through all of nfo's, when I compare with Leia.
I have many years of data migration experience behind me and have several clients test environments set up, so I know its not my equipment.
Its down to personal requirements, the equipment I use is for business and pleasure, so I have basic demands for my media player GUI not into bells&whistles purely access and the skilled hands of Bart have created the ideal package, with Kodi at the core
