Beta 4 for Matrix is available on
GitHub. This update brings back Radio A-Z. It has not been tested extensively, so Radio users are invited to try and report any issues.
(2021-03-13, 11:30)CaptainT Wrote: [ -> ]Beta 4 for Matrix is available on GitHub. This update brings back Radio A-Z. It has not been tested extensively, so Radio users are invited to try and report any issues.
Thanks for the update, the improvements seem to work. I tried to tweak some inputstream.adaptive parameters, but sadly Radio 1 Live crashes Kodi. Your work is appreciated
Thank you, What about red button streams ?
Beta5 is available on
GitHub and brings back Radio Search. Unfortunately, there is no way to determine if these programmes are available or not. So if you search for a term, some of the results may play, and others may not. I am considering to add a dedicated error message just for that.
(2021-03-13, 17:15)unkrocks Wrote: [ -> ]Thanks for the update, the improvements seem to work. I tried to tweak some inputstream.adaptive parameters, but sadly Radio 1 Live crashes Kodi. Your work is appreciated
Thanks for the feedback. I am aware of this issue, which is caused by inputstream.adaptive as far as I can see. Let's hope they get that sorted out soon.
(2021-03-14, 09:21)drapero Wrote: [ -> ]Thank you, What about red button streams ?
No luck on that end, I am afraid. They will remain broken for the time being. In fact, I consider removing them for now.
(2021-03-14, 10:18)CaptainT Wrote: [ -> ] (2021-03-14, 09:21)drapero Wrote: [ -> ]Thank you, What about red button streams ?
Thanks for all the work you do CaptainT.
How do I go about installing the beta from GitHub? Is there a way to point Kodi to download the zip straight from there and install it directly?
Also, is there any chance of you making an ITV add-on on in the future? Kodi 19 made the old add-on by LittleWiz stop working and I miss that and your iPlayer the most.
(2021-03-17, 04:55)MackinsVII Wrote: [ -> ] (2021-03-14, 10:18)CaptainT Wrote: [ -> ] (2021-03-14, 09:21)drapero Wrote: [ -> ]Thank you, What about red button streams ?
Just follow the link posted above, download the zip file from GitHub, and install it manually in Kodi. Go to settings, add-ons, install from zip file to do that. There is no way to add tho as a repository in Kodi directly. However, once the first release hits the official Kodi repo, it should auto-update.
I am sorry, but I barely find the time to keep this add-on up and running. For example, Radio was broken for months now. So I will not start another add-on on top of that.
I hadn’t realised ITV had gone. I have it on an old 17.6 fork but it still won’t populate. Any news from Littlewiz or is there a separate thread on this forum ?
UPDATE The ‘shows’ section is still working and is up to date. Live tv has been down for a while
Hi I am running;
LibreELEC (community): nightly-20210318-c5d7822 (RPi4.arm)I have tried to install latest iPlayer WWW 4.0.0~beta5 but get errors on install?
Quote: ERROR <general>: Unable to find plugin
2021-03-18 13:40:05.643 T:945 ERROR <general>: GetDirectory - Error getting plugin://
2021-03-18 13:40:05.643 T:745 ERROR <general>: CGUIMediaWindow::GetDirectory(plugin://) failed
2021-03-18 13:41:08.469 T:745 INFO <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2021-03-18 13:41:16.764 T:960 ERROR <general>: CAddonInstallJob[plugin.video.iplayerwww]: failed to find dependency inputstream.adaptive
2021-03-18 13:41:31.569 T:745 INFO <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2021-03-18 13:41:53.177 T:745 INFO <general>: Log level changed to "TRACE"
2021-03-18 13:41:53.177 T:745 INFO <general>: Enabled debug logging due to GUI setting. Level 2.
I tried to follow page 1 of this forum, but on LE 10.0 I dont see anywhere of how to install or activate inputstream.adaptive?
(2021-03-18, 16:02)evanspae Wrote: [ -> ]Hi I am running;
Fixed!! I finally managed to track down inputstream.adaptive in a previous Kodi repository and now all installed and working!
Thanks CaptainT !! great plugin
4.0.0 has just been merged to the official Matrix add-on repo.
- Everyone who currently uses a beta should see an automatic update over the next days. In case you don't, or if you experience any issues with the update, please uninstall the add-on completely, and then reinstall from the official repo.
- Everyone who upgrades from Leia to Matrix from now on should see no more ill effects, the add-on should auto-update.
I will also push an update to Krypton bringing back Radio in Leia and Krypton. This will take another couple of days.
Any reason that I suddenly cannot watch certain channels. It's telling me I need to be based in the UK. Which I am. I haven't moved or changed ISP's and have a UK IP address
(2021-03-27, 11:02)wormvortex Wrote: [ -> ]Any reason that I suddenly cannot watch certain channels. It's telling me I need to be based in the UK. Which I am. I haven't moved or changed ISP's and have a UK IP address
If you really are in the UK, it could be that the bug in inputstream.adaptive that previously only affected BBC 2 now affects more channels. In this case the error message would be misleading.
I've just given it a quick try, and all I can play is BBC Parliament and BBC News Channel.
The others just say "loading" and then don't start, but don't give me any other message that I can see.
The log is
here if it's any use (debug isn't enabled, if needed let me know and I can redo).
Matrix 19.0 under Win10 using the repo version of the addon.
