Big Noid,
Is it posible to create a kind of extrathumb slideshow in the infopanel?
Maybe one future request: one extra view for pictures. Maybe lowlist.
Hi Noid. Thanks for the guess! I tried changing the value you specified but it didn't seem to work (also tried changing all locations for Control.IsVisible(512) in the files involved).
I keep having the same issue where the new Viewtype is shown in the Viewtype selector but when I select it the viewtype reverts to List.
Great skin. I've been having a great time setting up xbmc as a first time user.
I've created some smart playlists (that are placed within the menu) and the wallpaper background for the SD/HD Movies smart playlists are the same.
Is it possible to change the wallpaper backgrounds of one of these smart playlists to another background that is provided within this skin? If so, how do I do this?
E.g. at the moment both of the smart playlist backgrounds are heath ledger from batman, is it possible to make one of them the avatar background for example?
Cheers.
Is there a way for the "movie" and "tv show" backgrounds to random choose a fanart picture from my movie/tv show library?
evilsync Wrote:Great skin. I've been having a great time setting up xbmc as a first time user.
Cheers.
lapino Wrote:Is there a way for the "movie" and "tv show" backgrounds to random choose a fanart picture from my movie/tv show library?
You can customize the backgrounds in the skin settings.
For each main menu item you can select seperate background. Not for submenus
For seperate backgrounds movie/tv show you first have to extract those. There's an add-on that extract the fanart from the thumbnails and puts it in seperate folders. So you can point to those folders for background. Just can't recall it's name at the moment. Will look it up when i'm at home.
Ok, so there's no way to let it pick a fanart from my library (essentialy a share on my NAS with subfolders for each movie) ?
lapino Wrote:Ok, so there's no way to let it pick a fanart from my library (essentialy a share on my NAS with subfolders for each movie) ?
You could create a folder that has a copy of all your movie fanarts in it, then point the skin to that folder. They can't be in individual folders IIRC. There is an addon that will put a copy of fanarts into a folder named movies as well as the normal Thumbnails folder that has been created exactly for what I think you want to achieve.
This is the addon IIRC:
http://forum.xbmc.org/showthread.php?tid...vie+fanart
No way to use a network folder?
smiffy1989 Wrote:This is the addon IIRC: http://forum.xbmc.org/showthread.php?tid...vie+fanart
Yeah that was the one
lapino Wrote:No way to use a network folder?
Yes you can. You can chose where you export the fanart and where Nox gets its fanart from. So also from network drives.
It gets mine from smb://
But to make it clear what you want:
Do you want random movie / tv show fanart when you are on main screen when that menu is selected?
OR
Do you want random fanart when you have one movie/tvshow selected, so in the library itself?
No I just want a random movie/tv show fanart when I select the movie/tv show menu choice (in the main menu). Now it's always a picture from Tron and House. I have no problem needing to export the fanart to a separate folder, but I don't want to keep that folder on my xbmc (ssd, low on space) but in a folder inside my NAS.
But when I go to the background settings in the skin menu, I seem to be unable to select a SMB drive, only "C" and "Home" show up.
Would is be possible to make lowlist view universal? I prefer this over the other list view and would use is in more areas if possible.
You're network drive has to be mapped in your OS so xbmc thinks it's local. Though it should be possible as add-ons like cdartmanager can point to smb:// folder. Maybe Big Noid can check if this is even possible to do this for skins as well.
'Show timepanel' broken in latest git
sergiocos Wrote:'Show timepanel' broken in latest git
Works fine here.
There where some changes in code so i think you should upgrade to a newer nightly (from aug 30th and up)
ouch! i'm using dsplayer branch, but thanks for the info, you're right!
