Big_Noid Wrote:
@fional: This is possible of course, but the skin now makes use of variables, so it's a bit different. But the basis is the same. You make the changes in Viewtype_LowList.xml and then look the variable up in variables.xml to see what infolabel should be shown on what content.
I reinstated the show info option so the labels are all present already.
I'm making a mess of this - not sure what to do next. This is a bit beyond me I think, I've been toying with this for the past 12 hours...which is a sad commentary on my ability.
I've been looking in variable.xml and Viewtype_Lowlist.xml - for instance I was looking for premiered as a reference point and was going to move "previous" to the right of "premiered", sort of like how I had moved director next to writer, in the past. Then with the gap left over, I'd shift Network and Episodes up one, and beneath that put the filepath of the file.
Then in episode view replace the banner.jpg in the left with the clearart.png, sort of like how you used to have it.
Then with movies, I was going to do the same as before and put the "writer" next to director, shift everything up one notch and then put the filepath under MPAA.
My attempts have actually yielded little. When I was tinkering with premiered, it's as if nothing would move or show at all. I even replaced it with random nonsense characters, and it was as if I was replacing it in the wrong place, as there was no change!
This is what I would search for before in Viewtype_Lowlist.xml:
I would look for banner.jpg, the first one by 'tv glass' and I'd replace it with
<control type="image">
<posx>10</posx>
<posy>110</posy>
<width>250</width>
<height>250</height>
<aspectratio scalediffuse="true">keep</aspectratio>
<fadetime>400</fadetime>
<texture diffuse="thumbs/banner_mask.png" background="true">$INFO[ListItem.Path,,../clearart.png]</texture>
<visible>!Skin.HasSetting(highlist)</visible>
</control>
The banner.jpg which had pos 950,658 would remain untouched. There's a banner.jpg in the current Viewtype_Lowlist.xml
Then I would search for:
<control type="label">
<posx>850</posx>
<posy>625</posy>
<height>13</height>
<width>105</width>
<font>Font_Reg18</font>
<textcolor>abFFFFFF</textcolor>
<scroll>true</scroll>
<label>$LOCALIZE[2050]:</label>
</control>
<posx>960</posx>
<posy>625</posy>
<height>13</height>
<width>280</width>
<textcolor>white</textcolor>
<label fallback="312577">$INFO[ListItem.Duration,, $LOCALIZE[12391]]</label>
</control>
and I'd replace it with this:
<posx>1070</posx>
<posy>525</posy>
<height>13</height>
<width>430</width>
<font>Font_Info</font>
<label>$LOCALIZE[20339]:</label>
</control>
<posx>1142</posx>
<posy>525</posy>
<height>13</height>
<width>150</width>
<label fallback="312577">$INFO[ListItem.Director]</label>
</control>
<posx>850</posx>
<posy>525</posy>
<height>13</height>
<width>430</width>
<label>$LOCALIZE[20417]:</label>
</control>
<posx>910</posx>
<posy>525</posy>
<height>13</height>
<width>150</width>
<label fallback="312577">$INFO[ListItem.Writer]</label>
</control>
<posx>850</posx>
<posy>550</posy>
<height>13</height>
<width>430</width>
<label>$LOCALIZE[572]:</label>
</control>
<posx>910</posx>
<posy>550</posy>
<height>13</height>
<width>400</width>
<label fallback="312577">$INFO[ListItem.Studio]</label>
</control>
<posx>850</posx>
<posy>575</posy>
<height>13</height>
<width>430</width>
<label>MPAA:</label>
</control>
<posx>910</posx>
<posy>575</posy>
<height>13</height>
<width>400</width>
<label fallback="Not Rated">$INFO[ListItem.Mpaa]</label>
</control>
<posx>850</posx>
<posy>600</posy>
<height>13</height>
<width>430</width>
<label>Time:</label>
</control>
<posx>910</posx>
<posy>600</posy>
<height>13</height>
<width>299</width>
</control>
<posx>850</posx>
<posy>625</posy>
<height>13</height>
<width>430</width>
<label>Drive:</label>
</control>
<posx>910</posx>
<posy>625</posy>
<height>13</height>
<width>1730</width>
<haspath>true</haspath>
<label fallback="Outer Space">$INFO[ListItem.Foldername]$INFO[ListItem.FileName]</label>
</control>
I'm trying to get things to look relatively like this (though I like the premiered, show status, network, and previous columns under the new tv show lowlist):
http://forum.xbmc.org/showpost.php?p=995...count=4736
