Hack_kid Wrote:two questions
1 how do i go about and get extrafanart working
2 is the cdartmanager script still not picking up anything?
and i found a bug
the recomended settings script it sets the default glowbar color to white isnt it suppose to be blue like the glow spot?
Install the extrafanartdownloader add-on for movies/tv shows and cdart manager for music. Be sure to seth the same path in both viewtype options as in the cdartmanager for logo's and extrafanrt for music to work.
That is not a bug, but a feature. I personally think the skin looks best with the white glowbar
Big_Noid Wrote:Install the extrafanartdownloader add-on for movies/tv shows
The pre-eden stable is in the xbmc-repo under programs.
This is the dev version
0.3.9 which should work under Dharma/Eden. Dharma does
not yet support smb:// shares.
Because there won't be any more updates of the Aeon Nox for Dharma10.1
I made patch for the fanart downloader. If you're interested just PM me.
Quote:That is not a bug, but a feature. I personally think the skin looks best with the white glowbar
True
white is the way to go
Machine-Sanctum Wrote:@Big Noid
The logo in the left upper corner falls under the glowbar.
If "tvshow/<tvshow>-fanart.jpg" is used the fanart doesn't show. Don't know if this is fixable.
Yeah I'm gonna leave the logo like that. I don't want them to be any smaller and it really barely touches the glowbar.
I don't pull any fanart other than fanart.jpg in season folder.
mmmm blue is labeled as default
Dumb question: I have a fairly recent daily build of Eden and I've installed Aeon Nox through the add-on manager. Is this the newest version? If not, what's the best (least goofing about) way to get a newer version of Aeon Nox?
Also: my thanks to Aeon Nox's creator(s), it's excellent.
evilspoons Wrote:Dumb question: I have a fairly recent daily build of Eden and I've installed Aeon Nox through the add-on manager. Is this the newest version? If not, what's the best (least goofing about) way to get a newer version of Aeon Nox?
Chech the first post of this thread.
The easiest way is to install the passion-xbmc repo.
I am using the InfoWall view within Advanced Launcher with Nox.
The description say "Hidden to prevent spoilers" just like in Movies & TV. Is there something I can do to have the description shown within Programs (Advanced Launcher)? I still want it to be hidden in Movies & TV.
I can't find a way to mark the emulators as "Watched"
Thanks,
Banditt
Hi Big Noid.
Aeon Nox is most advanced skin for XBMC. I'm using it for three months now. Thank you.
I've got the latest tv next aired from the xbmc repository and the most recent passion repo version of nox, running an openelec Eden build from 10-01-11 and my tv guide is now just a blank grid, it's the new style it seems but nothing is populating, is there anything I can do or should check to get it working?
ibixat Wrote:I've got the latest tv next aired from the xbmc repository and the most recent passion repo version of nox, running an openelec Eden build from 10-01-11 and my tv guide is now just a blank grid, it's the new style it seems but nothing is populating, is there anything I can do or should check to get it working?
Try deleting canceled.db and next_aired.db in userdata/addon_data/script.tv.show.next.aired.
It's possible to show a "new" tag like the "watched" tag? also can you add a "ended" tag to TV Shows? thank you
Cannot add an ended tag right now, the script doesn't support it.
francovilar Wrote:It's possible to show a "new" tag like the "watched" tag? also can you add a "ended" tag to TV Shows? thank you
It's right there underneath the watched tag option. In git version you can even choose what the new status does, show only for recent items or for all unwatched items
Maxoo Wrote:Cannot add an ended tag right now, the script doesn't support it.
I'm working on that
PatOso Wrote:Again Spanish strings Update.15.10.2011
http://www.megaupload.com/?d=VRX5NKLJ
Careful with the conversion
Thanks. Big Noid
Will do :p Thx for the update and sorry for adding new string id's all the time
