Big_Noid Wrote:I changed the file banner_shadow.png because I was not happy with it. What you have now is a cached image of banner_shadow.png. Please revert the change you made and delete the following file while XBMC is closed:
userdata/Database/Textures.db
and restart XBMC. It should look like my screenshot then. Also make sure there's no textures.xbt in your media folder because it will load the files from that first.
ok thanx. guess i went through all that trouble for nothing
i'm still keeping my hopes up for a bannerplex view someday. here's the link to the original mod....
http://forum.xbmc.org/showthread.php?tid...bannerplex
there's a download there and everything, to make things even easier. i'll make a better mockup soon. can u tell how much i want this?
Definitely +1 for bannerplex view across tv shows/seasons and episodes.
+1 also for the "New" overlay! Great idea to keep the overlays to a minimum.
+2 for Bannerplex
I've also notice that XBMC abbreviated the date in the latest build, so you may want to shrink the overlay for a bit.
Big_Noid Wrote:How about this:
Fantastic. Yes please!!
The "New" overlays are also a great idea!
I love this skin. Thanks to BigNoid for all the great work. I'm using it on the apple tv2 and it is very fast across all the menus apart from the transition from home screen into tv show library or movie library. There is a pause of about 8sec before it launches those video libraries. BigNoid is there any options or any developments coming that might improve the speed of moving into the video libraries?
kealan Wrote:I love this skin. Thanks to BigNoid for all the great work. I'm using it on the apple tv2 and it is very fast across all the menus apart from the transition from home screen into tv show library or movie library. There is a pause of about 8sec before it launches those video libraries. BigNoid is there any options or any developments coming that might improve the speed of moving into the video libraries?
Disabling views should eliminate this problem. I measured with debug on and fps drop when entering library is significantly less when you have only 3 views enabled for example. You can disable the views in Sytem-->Skin-->Enable Viewtypes.
@ Big_Noid YEEESSSS!!!! That looks great!!! i know it's asking for much, but is it at all possible to have this view switch between banner and landscapes? like the mockup i made earlier? Maybe just name the view "Plex"? the MQ2 skin has a similar option to switch between the 2. here how their landscape view looks....
no biggie if it's not possible. just sharing ideas.
PS. i like the new overlays. and option to toggle them on or off would be ideal.
First of all thanks for this great skin. It is runs very smooth and looks great. I have one question however. In the showcase view, could it be possible to show the full plot in the info panel instead of just the outline? That would be really great.
kealan
in the aeon mq2 thread someone posted that with the latest nightly build the entering of a library was faster then with the last final release.
Greets
Eisi
Eisi2005 Wrote:@kealan
Greets
Eisi
I switched my htpc to linux two weeks ago and if you think it's smooth on windows you really should check out XBMC live. Everything is so much snappier.
Yeah, it's a pain getting everything to work (harmony, imon lcd mainly) but when it's done it really is worth the effort.
Big_Noid Wrote:Disabling views should eliminate this problem. I measured with debug on and fps drop when entering library is significantly less when you have only 3 views enabled for example. You can disable the views in Sytem-->Skin-->Enable Viewtypes.
Wow. That made a huge difference. Thanks again!
Big_Noid Wrote:I switched my htpc to linux two weeks ago and if you think it's smooth on windows you really should check out XBMC live. Everything is so much snappier.
Linux makes all the difference in the world. Don't forget to use DDS Fanart, if your graphic card supports it, for a truly fast experience. XBMCFreak also has a build of live with updated video drivers and some extras for anyone that's interested.
http://www.xbmcfreak.nl
@Big_Noid
Where can I find the settings for Bannerwall? I want to increase the space between the two rows but don;t know where to look. Thanks in advance.
Sorry for the lame question but could someone tell me a step by step guide to installing the latest build from svn? I'm using mac os with xbmc on the apple tv 2. Thanks in advance.
