Hey, any chance the banner wall view from the library views can be added to the file views for videos? Or perhaps point me in the direction of doing it myself...?
Cheers! Crackin skin!
Thiele Wrote:BN, I recently switched to Stripshow view for movies. Maybe not the fanciest view, but I think it's significantly faster on ATV2 than other views, and it's a good combination between covers and fanart. The thing is, I'm not really happy with the Info panel and I think there is some room for improvement there. The panel is too small to show the complete movie plot, and I think it doesn't make sense to have the exact same poster in the panel because it's shown just a few centimeters below the panel as well. Aslo, it would be nice to show the IMDb rating in the bar below the posters, just like you do with other views. Or that you can customize the logo's you see there, because they are not all important to me. I trust on your great eye for graphics and program skills to make this view better
Okay, I looked at this. I think you are overlooking some settings, because they take care of your issues.
If you don't like the poster on the panel you can switch them with extrathumbs.
If you disable the panel, the imdb rating is already shown on the floorlabel, no need to display it twice when the panel is active.
You can disable studio and rating flags if you don't like them.
I don't know if my last post was ignored but I'd love if someone could help me get the old info wall back in the eden version. I can't seem to find the option for the classic one. I'm using the latest git version
Elixxen Wrote:I don't know if my last post was ignored but I'd love if someone could help me get the old info wall back in the eden version. I can't seem to find the option for the classic one. I'm using the latest git version
There is no option for it. i made a separate branch classic_wall for it. But I'm having difficulties keeping that one up to date, so it's best to make the changes in your own fork.
To see what needs to be done check out these commits:
https://github.com/BigNoid/Aeon-Nox/comm...6aa7d11333
https://github.com/BigNoid/Aeon-Nox/comm...dfb237034b
nistuf Wrote:Is there an aeon nox specific faq? or is just a bug/change of the widget that you just implement in the skin..? Thnx!
Why don't the recent added widgets hide the watched items anymore?
In XBMC Eden the script recently added has been moved to XBMC core functionality. The devs did not want to have an option for skinners to hide the watched items like there was in the script because a better solution is in the works. See
this thread for an explanation.
I'm making the plunge to the Eden Beta 2, though I'm nervous since I was able to get Dharma almost exactly how I like. But weather keeps having issues on my Dharma build and I figure this is maybe the best way to get rid of the many script errors. Shouldn't resist change, should I?
My biggest concern is that Big Noid helped me make the below changes to my settings of Nox. With the Eden version of Nox, can I do the same thing? I highlighted it with a redish box and an arrow.
Primarily, just adding the path and the scrolling. And then in one instance, having the clearart show up.
Would the adjustments required to do the below be similar?
^^ You can see I have it show the plot thing, the total episodes, and then the path.
^^ You can see that I have it show The writer and director on one line, they scroll. I also have it show the studio, rating, and time. Most importantly, the file path. Below that, I have it show the banner.jpg between a couple other bits of data.
^^ You can see that I have it show The writer and director on one line, they scroll. I also have it show the studio, rating, and time. Most importantly, the file path. Also, on the left side, you can see I have it placing the clearart there.
I used thumbs, hopefully that isn't so inconvenient to click - but I didn't want to blast the thread with 3 images
Thanks so much!
vicmanpergar Wrote:U made me all wet
lol
Oops, i mean, i'm drooling
lmao
@fional: This is possible of course, but the skin now makes use of variables, so it's a bit different. But the basis is the same. You make the changes in Viewtype_LowList.xml and then look the variable up in variables.xml to see what infolabel should be shown on what content.
I reinstated the show info option so the labels are all present already.
Ok thank you.
I will give it a try and report back if I make a pig's breakfast of everything!
I'm excited for all the new features, I think it'll be grand. Once I get my server setup, I won't need the path anyway. But I do like that clearart logo in the lower left!
Wait, did I miss something? When was Beta 2 released? I've seen multiple posts mentioning it but I don't see it anywhere.
fional Wrote:Ok thank you.
I've been quite busy with some new features that are not on official 2.0.0 version of the skin. Since your already going beta, you might want to check out the git version of the skin
htpc guy Wrote:Wait, did I miss something? When was Beta 2 released? I've seen multiple posts mentioning it but I don't see it anywhere.
Get it
here
Server is pretty loaded so it may take a few tries.
