(2012-12-20, 00:55)Vaikin Wrote: [ -> ]Since it was in Aeon Nox 2.0 forums, Ill assume it was Aeon Nox 2.0...a LONG since depreciated skin.
That view is still there in 4.0
It was a nice skin, before I started to have random crash with it. Too bad its deprecated.
I now use the Transparency! skin, there's a lot of features that I liked in Aeon Nox.
Uh, Aeon Nox is still around and in further development for the new XBMC release. You can go
here for the current version or
here for the Frodo version.
(2012-12-20, 04:26)Marsupial Wrote: [ -> ]It was a nice skin, before I started to have random crash with it. Too bad its deprecated.
Anyone know why extrafanart is not working? I just upgraded to Frodo (using apt-get), renamed my Userdata folder, re-scanned my entire library. It just uses one fanart and will not rotate between them (worked fine on Eden). I have tested multiple artists where I have a local "extrafanart" folder. I'm on Ubunutu if that matters.
(2013-02-05, 02:03)xbmc17 Wrote: [ -> ]I just upgraded to Frodo
There's your problem, Aeon Nox 2.0 was designed for Eden (or Dharma, I'm not sure). You'll have to upgrade the skin to 4.0.9 for it to work on Frodo. But be prepared for some major changes if you do.
I see you posted this on the 4.0 thread, so, I'm guessing you already have 4.0.9.
