2011-02-24, 22:38
Victim Wrote:+2 for Shinu's case style. Looks great. I have a very minor question. The 480p flag for the Fullscreen Info view is missing the "p" at the end. I know it insignificant, but I always keep wandering if my video is 480p or 480i because of it.I should probably get rid of the 480i flag and just change it also to 480, cause there is no difference in database between 480p and 480i, same goes for 576p. Maybe just change it to SD altogether.
Eisi2005 Wrote:@big_noidDone
take a look at this screenshot. could you put the text a little bit more to the right ?
http://www.mediafire.com/?3r474y374z44tzz
Greets
Eisi
Shinu Wrote:how do i see the changes? should uninstall and re-download the skin?If you want to check out the changes you could download the svn (see first post). Here is a screenshot:
