(2012-07-17, 20:15)shaktoo Wrote: [ -> ]bigbodiehard did you go through fional's videos. they show you exactly how & what to do , As for git use mcborzu's guide and just adapt for nox
http://forum.xbmc.org/showthread.php?tid=75774------- scroll down to the end where post #2 is and that shows how to use git
Used the faq you suggested. Thanks took me less than 5 minutes to set up.
(2012-07-17, 23:41)bigbodiehard Wrote: [ -> ] (2012-07-17, 20:15)shaktoo Wrote: [ -> ]bigbodiehard did you go through fional's videos. they show you exactly how & what to do , As for git use mcborzu's guide and just adapt for nox
So.... What do you have to do to update the GIT? Does it update automatically without having to close XBMC?
you enter git pull in the git bash program. You can automate it but I can't be bothered looking in to that.
(2012-07-18, 00:54)bigbodiehard Wrote: [ -> ]you enter git pull in the git bash program. You can automate it but I can't be bothered looking in to that.
See to me that seems like more of a hassle. Someone should make an addon for GIT Pull in xbmc... Until then I'll stick with the one day late Passion Auto Update setup. Easy Peasy!
(2012-07-18, 00:59)bigbodiehard Wrote: [ -> ]How do I add this http://pipes.yahoo.com/pipes/pipe.info?_...9f58fb12fd to the rss widget I typed it out in custom but it just keeps show alarm.
what do you mean with alarm? you´re using script.rss.editor? if that add-on is installed Custom RSS feeds work differently (both ways should work though)
(2012-07-18, 00:58)crimsonfury Wrote: [ -> ] (2012-07-18, 00:54)bigbodiehard Wrote: [ -> ]you enter git pull in the git bash program. You can automate it but I can't be bothered looking in to that.
why an add-on when you can set it up in 2 minutes? cronjobs or scheduled tasks both do the job.
Yeah I have the custom rss feed addon when I select it this happens.
doesn´t the rss editor dialog appear? if not, then your local install is not up-to-date/broken.
Yes it appears and after I click ok then I get the alarm dialog.
(2012-07-18, 01:19)bigbodiehard Wrote: [ -> ]Yes it appears and after I click ok then I get the alarm dialog.
not anymore. just fixed that. all rss sets you create there should appear in the list then.
Hey guys, are there random and repeat buttons anywhere in the skin for the music section? Can't seem to find them.
Also, when playing music with extrafanart enabled for background, it doesn't show the fanart from the root of the artist folder. Seems as though it should cycle through that one as well.
This is while viewing music from the main menu screen.
(2012-07-18, 01:57)bigbodiehard Wrote: [ -> ]Now the Alarm is gone but once I press OK
I get back to this menu
Is it the rss feed try adding http://pipes.yahoo.com/pipes/pipe.info?_...9f58fb12fd to your set up to check if it works on your computer
it works here. do you have the script script.rssfeeds? that one is needed to get the stuff from rss editor into the rss feed list.
(2012-07-18, 01:42)JohnVee Wrote: [ -> ]Hey guys, are there random and repeat buttons anywhere in the skin for the music section? Can't seem to find them.
press in in music vis.
for backgrounds... i made some changes concerning that today. you´re using GIT version? or passion xbmc?
