I did try several Icons, even the one used for TV Shows by default. When I select the icon it doesn't show up in the customizer window.
workin here...
you´re definitely using the untouched newest GIT version?
Same problem here. Custom icons work just fine, but the default alternatives don't show up.
(2012-06-29, 07:09)phil65 Wrote: [ -> ] (2012-06-29, 06:38)crimsonfury Wrote: [ -> ]Does anyone else have xbmc crash more with movie sets on?
I seem to have it crash now with it on...
also happens here on occasion. nothing we can do about that on our end.
another approach. what about this?
Hi Phil,
Thanks for this great view, I love it but I have a problem with some movies. If you take a look to the screenshot, some abstract isn't shown but I have it... Do you have an idea about that problem?
Thanks in advance.
I don't undestand what is plot "Full" or "Outline" because no one is working
(2012-07-01, 19:22)Hellnino18 Wrote: [ -> ]I don't undestand what is plot "Full" or "Outline" because no one is working
In the .nfo for each movie, you should have a full plot (story of the movie) or an outline (brief summary of the movie)? If the outline is missing, the info will appear blank in this view. You can add it back manually for each movie, or maybe refreshing some of them will put them right.
Oh okay. But it's weird because in this view we can choose Outline or Full, it's not applicable for the moment so
(2012-07-01, 19:35)Hellnino18 Wrote: [ -> ]Oh okay. But it's weird because in this view we can choose Outline or Full, it's not applicable for the moment so
Re-read Phil's answer to you again. He just told you why the option isn't working.
Quote:we´re using plotoutline there, not plot. will be changed perhaps to be adjustable.
The option apparently doesn't do anything yet
Anybody noticed a recent increase in flashing artifacts on the thumbs in views with coverflow? Could be my hardware or a different non-skin issue, but I never noticed until fairly recently. Disabling coverflow fixes things right up.
(2012-07-01, 20:32)antisuck Wrote: [ -> ]Anybody noticed a recent increase in flashing artifacts on the thumbs in views with coverflow? Could be my hardware or a different non-skin issue, but I never noticed until fairly recently. Disabling coverflow fixes things right up.
what do you mean with flashing artifacts? screenshot would be nice.
I'm seeing it too. Will investigate
EDIT: Fixed
Don't know. That should work. I was wrong about rollback probably. I dont know if that could work. The packages folder is located inside the addon folder.
(2012-07-01, 20:34)phil65 Wrote: [ -> ] (2012-07-01, 20:32)antisuck Wrote: [ -> ]Anybody noticed a recent increase in flashing artifacts on the thumbs in views with coverflow? Could be my hardware or a different non-skin issue, but I never noticed until fairly recently. Disabling coverflow fixes things right up.
It's a transitory redrawing thing that won't be visible in a screenshot, it's almost like various alpha layers are taking longer to sort and composite properly or the thumbs are lagging behind the case masks. Sorry I can't describe it better, and yeah I know it doesn't sound like a skin issue but it's not showing up on the repository version.
EDIT: Thankfully BN was seeing it too, so I can stop trying to describe it. Thanks for taking the time to ask about it.
(2012-07-01, 20:45)Big_Noid Wrote: [ -> ] (2012-07-01, 20:32)antisuck Wrote: [ -> ]Anybody noticed a recent increase in flashing artifacts on the thumbs in views with coverflow? Could be my hardware or a different non-skin issue, but I never noticed until fairly recently. Disabling coverflow fixes things right up.
EDIT: Fixed
Thanks BN, glad it wasn't a) just me, or b) a huge deal to fix.
