...and they look nice in quicknav, too
hey can someone link me to the aeon nox 3.01 zip? For some reason when trying to install from xbmc it says it's still 2.0
a) right-click on xbmc.org repo --> force refresh
b) media menu in addonbrowser --> Update Addon Repos
(2012-06-25, 04:56)phil65 Wrote: [ -> ]a) right-click on xbmc.org repo --> force refresh
I can't find the media menu, i forced refresh on xbmc repo
you think my repository is old? what's the version of the latest xbmc repo?
ok so i have a few problems id like to try and fix
my old aeon nox v2 was working fine and then it auto updated to v3
no biggie edited all my settings again but....
-i lost my firefox menu in the home screen - im sure i could fic but i rarely used it anyway so not going to bother
- every time the program loads it opens to the tv guide home screen yet in v2 i had it set to open to the TV shows home screen (how do i fix this?)
- had massive amounts of errors with yahoo music addon that im sure i never installed every startup id get errors about it, it was already disabled but i re disabled it and dont have a problem anymore
- in the tv guide menu the quick nav bar wont disappear and even when i rescan the tv data its not showing anything anymore...?
the other thing is if i roll back the next time i open xbmc all the addons auto update so i cant just roll back to the older version
im happy with this new version just want to fix the tv guide problem and the tv shows as the main homescreen on every restart
I just upgraded to the latest Aeon-Nox git release and love it, looks very slick
Can anyone tell me if there is any alternative OSD (or plans to add other options) for video playback?
Currently there seems to be two options :-
One fullscreen OSD which covers the entire video but gives you loads of information.
One OSD with top/bottom bars which give extremely minimal information
Does any middleground OSD exist that is like the minimal one but that gives some more info, and displays art / channel logo etc?
The minimal one just seems a little too spartan to me...
In nox 2.0 I used to be able to have both the Recommended and the latest episodes widgets on-screen simultaneously. I really miss that, is there a way it can be done in 3?
(2012-06-25, 18:51)Rumik Wrote: [ -> ]In nox 2.0 I used to be able to have both the Recommended and the latest episodes widgets on-screen simultaneously. I really miss that, is there a way it can be done in 3?
only when using GIT version. 2 widgets are possible there.
Okay I have the widgets setup but they won't show on the min menu. I see an icon that says Show Widgets but I not see my way of showing hem by default.
Cheers
Ah, backspace! Got it
Love having both widgets at the same time, but I was wondering if you'd considered fitting them both into the centre area of the screen, rather than 1 in the centre and the other in the corner above it? Just doesn't look that neat is all
