Hi guys, thanks very much for all your work with Aeon Nox. I've been through pretty much all the skins you can download, and yours is my favorite! I especially like the way everything just runs smoothly, the coverflow, all the different views and customization.
BUT... I recently reinstalled XBMC and Aeon Nox, and now when I listen to music, it no longer downloads extrafanart and displays as visualization in the background. It only sticks with the (already downloaded) single fanart jpeg. I have it set to the 'Artist fanart (Extrafanart, fanart.jpg, default fanart)' visualization and not the 'Artist Slideshow' one.
This is the excerpt from my debug log:
00:52:35 T:2708 DEBUG: CTextureCache::GetImageHash - unable to stat url
00:52:35 T:5700 DEBUG: CTextureCache::GetImageHash - unable to stat url C:\hetoft-hdd\Music\T\The Beatles - 1 (2000)\cdart.png
00:52:35 T:5256 DEBUG: Building didl for object 'musicdb://2/1109/-1/13256.mp3'
00:52:35 T:6088 DEBUG: script.artistslideshow: script version 1.3.2 started
00:52:35 T:6088 DEBUG: script.artistslideshow: window id is set to 12006
00:52:35 T:6088 DEBUG: script.artistslideshow: artist field is set to
00:52:35 T:6088 DEBUG: script.artistslideshow: daemonizing
00:52:35 T:6088 DEBUG: script.artistslideshow: language = en
00:52:35 T:6088 DEBUG: script.artistslideshow: external call is set to
00:52:35 T:6088 DEBUG: script.artistslideshow: first song started
00:52:36 T:6088 DEBUG: script.artistslideshow: start download
00:52:36 T:6088 DEBUG: script.artistslideshow: cachedir = C:\Program Files\XBMC\portable_data\userdata\addon_data\script.artistslideshow\ArtistSlideshow\213526d2\
00:52:36 T:6088 DEBUG: script.artistslideshow: cached images found
00:52:36 T:6088 DEBUG: script.artistslideshow: asking for images from: http://htbackdrops.com/api/96d681ea0dcb07ad9d27a347e64b652a/searchXML?default_operator=and&fields=title&aid=1&keywords=The+Beatles&dmin_w=1000&dmin_h=700
00:52:36 T:6088 DEBUG: script.artistslideshow: cached artist images info found
00:52:36 T:6088 DEBUG: script.artistslideshow: downloading images
00:52:36 T:6088 DEBUG: script.artistslideshow: no images downloaded
00:52:36 T:4680 INFO: CFileCache::Process - Hit eof.
00:52:37 T:5256 DEBUG: CApplication::OnKey: 213 (d5) pressed, action is FullScreen
00:52:37 T:5256 DEBUG: Activating window ID: 12006
00:52:38 T:5256 DEBUG: ------ Window Deinit (MyMusicNav.xml) ------
00:52:38 T:5256 DEBUG: ------ Window Init (MusicVisualisation.xml) ------
00:52:38 T:5256 INFO: Loading skin file: MusicVisualisation.xml
00:52:38 T:5256 DEBUG: CApplication::ExecuteXBMCAction : Translating Skin.Reset(Nox.vispanelrotate)
00:52:38 T:5256 DEBUG: CApplication::ExecuteXBMCAction : To Skin.Reset(Nox.vispanelrotate)
00:52:38 T:5256 DEBUG: CApplication::ExecuteXBMCAction : Translating AlarmClock(Vis,Skin.ToggleSetting(Nox.vispanelrotate),00:15,silent,loop)
00:52:38 T:5256 DEBUG: CApplication::ExecuteXBMCAction : To AlarmClock(Vis,Skin.ToggleSetting(Nox.vispanelrotate),00:15,silent,loop)
00:52:38 T:5256 DEBUG: started alarm with name: vis
00:52:38 T:5256 DEBUG: CApplication::ExecuteXBMCAction : Translating AlarmClock(Vis3,Control.Move(5222,1),00:04,silent,loop)
00:52:38 T:5256 DEBUG: CApplication::ExecuteXBMCAction : To AlarmClock(Vis3,Control.Move(5222,1),00:04,silent,loop)
00:52:38 T:5256 DEBUG: started alarm with name: vis3
00:52:38 T:5256 DEBUG: CApplication::ExecuteXBMCAction : Translating AlarmClock(Vis4,Control.Move(5223,1),00:04,silent,loop)
00:52:38 T:5256 DEBUG: CApplication::ExecuteXBMCAction : To AlarmClock(Vis4,Control.Move(5223,1),00:04,silent,loop)
00:52:38 T:5256 DEBUG: started alarm with name: vis4
00:52:38 T:5256 DEBUG: msg: PICTURE::LoadImage: Unable to open image: C:\hetoft-hdd\Music\T\The Beatles - 1 (2000)\fanart.jpg Error: (2)
00:52:38 T:5256 ERROR: Texture manager unable to load file: C:\hetoft-hdd\Music\T\The Beatles - 1 (2000)\fanart.jpg
00:52:38 T:5256 DEBUG: msg: PICTURE::LoadImage: Unable to open image: C:\hetoft-hdd\Music\T\The Beatles - 1 (2000)\../fanart.jpg Error: (2)
00:52:38 T:5256 ERROR: Texture manager unable to load file: C:\hetoft-hdd\Music\T\The Beatles - 1 (2000)\../fanart.jpg
00:52:38 T:5256 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\hetoft-hdd\Music\The Beatles/extrafanart\
00:52:38 T:5256 DEBUG: ------ Window Deinit (MusicOverlay.xml) ------
I might be wrong, but I'm pretty sure I had it setup (before I reinstalled XBMC) to automatically download fanart (that available from HTbackdrops.com) and display, without choosing 'Artist slideshow' (one of the reasons why I prefer this visual is that Artist slideshow usually takes a while before it find pictures from the next artist).
As I recall, it downloaded the available fanart from htbackdrops, to a folder unknown to me, as soon as I played some music.
Does the fanart HAVE to be stored locally (next to your music files) in order for the 'Artist fanart (Extrafanart, fanart.jpg, default fanart)' visualization to display it properly - or can it be set to auto download the available fanart and display, seemlessly, without me knowing and saving jpegs next to my mp3's?
