(2012-07-11, 15:30)Raytestrak Wrote: [ -> ]It would be better if the dimensions of the cases weren't all screwed up, but I'm with Phil on this one.
I agree detracts from the cover artwork (imo)
Yes,for image cacher "True" is better, you load pictures just one time
(2012-07-11, 17:42)fmronan Wrote: [ -> ]Yes,for image cacher "True" is better, you load pictures just one time
if it would be that easy then pieh probably wouldn´t have integrated the ability to use that parameter. i know what caching is.
and better to comment on github instead of here without any reference. (oh i forgot, you don´t want to use github)
extended the widget a bit: you can now choose 3 different rss feeds with onclicks to video:
i only need some good rss video links... anyone?
esp. yahoo pipes are very powerful.
http://pipes.yahoo.com/pipes/
I know but I work only with ubuntu
I want to remove "Videos" from the main menu and place it in the "Movies" and "TV Shows" sub menu.
How do i do this? I can't figure it out!
edit: sods law, posted this and then i figured it out lol!
For anyone who wants to do with just type "ActivateWindow(Videos,root)" as the function of your custom submenu item, it will launch Videos.
What happened to the widgets in the latest version? All I see is a small box with "Show Widgets" and an arrow pointing to the left. I don't get it. I tried searching the thread but didn't have any luck finding an answer. Please help
(2012-07-11, 23:23)Martijn Wrote: [ -> ] (2012-07-11, 23:15)Elixxen Wrote: [ -> ]What happened to the widgets in the latest version? All I see is a small box with "Show Widgets" and an arrow pointing to the left. I don't get it. I tried searching the thread but didn't have any luck finding an answer. Please help
Press BACKSPACE
LOL I'm so stupid. Thanks! : )
