..some icons for quicknav and home (item layout):
(2012-06-25, 13:51)Swifty Wrote: [ -> ]I just upgraded to the latest Aeon-Nox git release and love it, looks very slick
Can anyone tell me if there is any alternative OSD (or plans to add other options) for video playback?
Currently there seems to be two options :-
One fullscreen OSD which covers the entire video but gives you loads of information.
One OSD with top/bottom bars which give extremely minimal information
Does any middleground OSD exist that is like the minimal one but that gives some more info, and displays art / channel logo etc?
The minimal one just seems a little too spartan to me...
you can toggle between both layouts by pressing enter. think it is a good solution as it is now, one info view still allowin most of the video and another one which gives full info.
Phil - The icons look sick! How do you enable them?
(2012-06-26, 03:46)Balthazar Wrote: [ -> ]Phil - The icons look sick! How do you enable them?
by using GIT version and setting layout to icons in furniture customizer (click on main menu bar there)
(2012-06-25, 23:49)phil65 Wrote: [ -> ]just pushed it. feedback is welcome. (and also someone to try random artists widget would be nice. needed for script update on official repo)
I use the random artist widget. It seems to work perfectly for me. In fact, it's got me to use the music section again. Thanks to you and Big Noid I haven't changed skins since V3 was released, and that's saying a lot since I used to change skins 2-3 a week.
(2012-06-26, 04:07)phil65 Wrote: [ -> ] (2012-06-26, 03:46)Balthazar Wrote: [ -> ]Phil - The icons look sick! How do you enable them?
Thanks Phil, I forgot to try forcing a repo refresh before posting. Seems kind of obvious now
Great job on the skin you guys. It is beautiful!
new feature: option to choose main menu position for custom items.
(2012-06-23, 16:34)leepenny Wrote: [ -> ]just updated to svn version - all going well with customization except for comics I just cant set a path nothing happens clicking the option am I doing something wrong?
it seems like the option has no focus
anybody care to shed some light on this -seems like the button is not working
(2012-06-26, 12:06)leepenny Wrote: [ -> ] (2012-06-23, 16:34)leepenny Wrote: [ -> ]just updated to svn version - all going well with customization except for comics I just cant set a path nothing happens clicking the option am I doing something wrong?
should be fixed now on GIT.
not sure if u saw my question phil....
(2012-06-24, 16:44)Shinu Wrote: [ -> ]is it possible for u to set the infopanel for landscape, dvd case, etc to off? for the logo option for landscapes, it would be nice to just press up to directly access the "play trailer" option instead of seeing the panel first. also can u have it so that the user can set the panel to off in one viewtype and on in another?
(2012-06-26, 17:10)crimsonfury Wrote: [ -> ] (2012-06-25, 19:02)crimsonfury Wrote: [ -> ]I can't seem to bring up the option to create new Movie Sets... I tried this with MQ3 and it works as noted in: http://forum.xbmc.org/showthread.php?tid...pid1065046
But I can't replicate here.
Phil,
Any idea on this?
don´t know what you mean exactly (i don´t use moviesets)
(2012-06-26, 17:06)phil65 Wrote: [ -> ] (2012-06-26, 17:04)Shinu Wrote: [ -> ]not sure if u saw my question phil....
both not possible.
hmmm. would have thought an option to at least turn off the panels would have been possible, but i guess not. thx anyway.
For movieSet he want the manager in context menu or in dialogvideo because if you don't have one set you can't build a other
For exemple you can add a set "africa" with your movie in africa and that's not realy a set
why you don't use fanart with actor born today widget, you have the property for that?
<property name="Fanart">$INFO[Window(Home).Property(peopleborntoday.1.Fanart)]</property>
