(2012-07-02, 17:42)bigbodiehard Wrote: [ -> ]I have a bug when I'm on the bottom widget I try pressing up to get to menu but it don't work especially when the menu has a sub menu.
screenshot, please (or a more detailed description)
I can't press up from here.
I had a similar issue with the daily babe widget. I had it placed so it is located above the main menu. When I click up once, I get to the widget (and can select babes...lol), but if I press up again at that point the widget appears to flip around and then nothing happens (so I'm stuck because I can't get back to the main menu either).
(2012-07-02, 20:05)Peligrozo Wrote: [ -> ]I had a similar issue with the daily babe widget. I had it placed so it is located above the main menu. When I click up once, I get to the widget (and can select babes...lol), but if I press up again at that point the widget appears to flip around and then nothing happens (so I'm stuck because I can't get back to the main menu either).
known. will be fixed.
another new option: clearart for movies/tvshows in lowlist:
i can't see clearart in lowlist, yet... also, can't find TVShowClearArtVar defined/explained anywhere else but in lowlist. can anyone else replicate this?
(2012-07-02, 21:06)sergiocos Wrote: [ -> ]i can't see clearart in lowlist, yet... also, can't find TVShowClearArtVar defined/explained anywhere else but in lowlist. can anyone else replicate this?
sorry, forgot to push that file. fixed.
one request here to all users here who feel it´s worth contributing something:
my idea is to have access to a demo video (or several) which show how to set up the skin.
would someone here be that nice and create some nice video stuff?
it would become a seperate settings menu item including credits to video author with links to the videos which i would put on my webspace,
thx
to give you some motivation, bignoid extended the bg system to also be used in music vis + a new option to show faded fanart above vis for milkdrop and projectm vis:
(2012-07-02, 22:34)phil65 Wrote: [ -> ]to give you some motivation, bignoid extended the bg system to also be used in music vis + a new option to show faded fanart above vis for milkdrop and projectm vis:
You guys are Incredible
Very, very nice and thank you!
(2012-07-02, 20:13)phil65 Wrote: [ -> ] (2012-07-02, 20:05)Peligrozo Wrote: [ -> ]I had a similar issue with the daily babe widget. I had it placed so it is located above the main menu. When I click up once, I get to the widget (and can select babes...lol), but if I press up again at that point the widget appears to flip around and then nothing happens (so I'm stuck because I can't get back to the main menu either).
Is it possible to have it display the logo when the clearart isn't available? Even if itsn't not a Nox feature, just curious if that be possible!
Also, is it possible to have it display that in season/episode view? Though maybe that was removed.
(2012-07-03, 01:18)fional Wrote: [ -> ]Is it possible to have it display the logo when the clearart isn't available? Even if itsn't not a Nox feature, just curious if that be possible!
It already displayed the logo in lowlist previously. It would be cool to have the clearart in season/episode view too!
Getting used to the new main menu icon bar now. Although (surprise) I'd like to change it up a little. Only two minor changes though, namely the icon size and gap between them. Maybe even single icon to unify the views?
new feature: QuickList
also extended the icon database, we´re now at approx 300 icons.
plus....
live cover system extended to artists, latest/random pictures and babes
