(2012-05-25, 21:27)Big_Noid Wrote: [ -> ] (2012-05-25, 21:21)jukster Wrote: [ -> ]I am looking for a way to show my 3D Movies in the default Movies section. I have read that if you add 3D or 3dbd to the filename it will show a 3D icon somewhere but I cannot get this to work with Aeon Nox 3.0. I know i can create a smart playlist and have it filter out the 3D movies but I do not care for this. I'd like all movies to show in the same movies section and the ones that are 3D to have a little 3D icon perhaps beside the 1080p logo or beside the dts logo at the bottom right.
Anybody know if this can be done in Aeon Nox 3.0?
Thanks in advance.
You have to have either bluray, blu-ray, bdrip or brrip and .3D. in the filename for this to work.
Got it to work. Thanks. Any way to make a 3D flag (where the Watched/New flags are or in the left upper corner). I think a lot of people would appreciate that.
(2012-05-25, 22:15)jukster Wrote: [ -> ] (2012-05-25, 21:27)Big_Noid Wrote: [ -> ] (2012-05-25, 21:21)jukster Wrote: [ -> ]I am looking for a way to show my 3D Movies in the default Movies section. I have read that if you add 3D or 3dbd to the filename it will show a 3D icon somewhere but I cannot get this to work with Aeon Nox 3.0. I know i can create a smart playlist and have it filter out the 3D movies but I do not care for this. I'd like all movies to show in the same movies section and the ones that are 3D to have a little 3D icon perhaps beside the 1080p logo or beside the dts logo at the bottom right.
Thanks in advance.
Would be too busy imo.
Any chance of logos making a return in the "Low List" viewtype? I liked having it at the top of the bar at the bottom, it looked cool. Reverted to 2.0 for the time being since I'm used to "info list" for my TV episodes. Also, something weird happens with 3.0 that doesn't happen with any other skin, when I launch XBMC it shows the logo and then shows the a spinning loading icon for 5-15 seconds then loads up the main menu. That was the biggest deterrent for me from 3.0.
(2012-05-25, 22:54)LukeS7 Wrote: [ -> ]Any chance of logos making a return in the "Low List" viewtype? I liked having it at the top of the bar at the bottom, it looked cool. Reverted to 2.0 for the time being since I'm used to "info list" for my TV episodes.
They should work
Quote:Also, something weird happens with 3.0 that doesn't happen with any other skin, when I launch XBMC it shows the logo and then shows the a spinning loading icon for 5-15 seconds then loads up the main menu. That was the biggest deterrent for me from 3.0.
actually reading something in this thread would have given you that answer
First i was shocked of the spontanious update, because i get a minute of a black screen and i noticed that all my settings are gone. 10 Minutes later: I have set all my settings and i like it. Now im playing with all these new features :-)
One question: The artist slideshow during music playback was fullscreen before. Now the pictures are in original size and ratio. How can i change it to fit the pictures to my full screen.
Hey guys,
Nice work with 3.0! Couple of questions though. One, how do you enable animated weather widget icons? Had this working in 2.0 but can't seem to find the option to point to my icon folder. Have been able to setup conditional weather wallpapers though.
Two, adding a samba path for multi image backgrounds don't seem to display. The images from the samba share seem to display correctly when still in the 'Main menu item customizer' but once back on the home screen just displays the single default image?
Disclaimer: I admit that I was too lazy to go through the 20 pages of this thread to see if the following issue has already been reported:
When I'm in Movies or Tv Shows library view and I change from "All Videos" to "Unwatched" everything works as expected. But when I switch from "Unwatched" to "Watched" it shows me 0 items and from there on I can switch back to "All Videos" etc I always get 0 items. I can also go back to Home etc it stays at 0 items until I quit XBMC and restart it.
I know frodo isn't supported, but I would like to bring this to your attention, and maybe find a solution. In nox every video or music addon gets stuck at retreving 0 items. Doesn't get past that, most of the time cancelling ends it fine, sometimes xbmc locks up.
If I switch over to confluence, addons work fine loads content right away. Then switching back to nox, addons now showing content.
Is there some sort of weird script that nox is calling on that confluence doesn't that is causing the addons to break? here is my topic in support about it:
http://forum.xbmc.org/showthread.php?tid...pid1111882
(2012-05-25, 23:04)aTTilaz Wrote: [ -> ]Hey guys,
Will have a look at that.
(2012-05-25, 23:05)Montellese Wrote: [ -> ]Disclaimer: I admit that I was too lazy to go through the 20 pages of this thread to see if the following issue has already been reported:
Cant reproduce this on my system. That functionality is just calling a built in control though. Which version of XBMC are you using?
EDIT: I see its a bug on frodo. Thats a XBMC bug then. That is button 10 from MyVideoNav.xml
(2012-05-25, 23:08)Death-Axe Wrote: [ -> ]I know frodo isn't supported, but I would like to bring this to your attention, and maybe find a solution. In nox every video or music addon gets stuck at retreving 0 items. Doesn't get past that, most of the time cancelling ends it fine, sometimes xbmc locks up.
Is there some sort of weird script that nox is calling on that confluence doesn't that is causing the addons to break? here is my topic in support about it: http://forum.xbmc.org/showthread.php?tid...pid1111882
I'll grab a nightly build and see if I can find anything.
EDIT: not reproducable. Maybe post your skinsettings from your guisettings.xml so I can test with that.
(2012-05-25, 22:57)Martijn Wrote: [ -> ] (2012-05-25, 22:54)LukeS7 Wrote: [ -> ]Any chance of logos making a return in the "Low List" viewtype? I liked having it at the top of the bar at the bottom, it looked cool. Reverted to 2.0 for the time being since I'm used to "info list" for my TV episodes.
They should work
Just re-read all 19 pages prior to my original post. The only response in regards to my 2nd issue was in response to another user: "For your second question see the thread in this forum about that for an explanation." I looked and was unable to locate said thread.
Also, the logos do not work in the Low List viewtype, I'm looking at it right now and they aren't there. Don't get me wrong it's a great skin, it's just that some of the features have been removed it appears going from 2.0 to 3.0.
(2012-05-25, 23:49)LukeS7 Wrote: [ -> ] (2012-05-25, 22:57)Martijn Wrote: [ -> ] (2012-05-25, 22:54)LukeS7 Wrote: [ -> ]Any chance of logos making a return in the "Low List" viewtype? I liked having it at the top of the bar at the bottom, it looked cool. Reverted to 2.0 for the time being since I'm used to "info list" for my TV episodes.
They should work
http://forum.xbmc.org/showthread.php?tid=132363
Logos should work fine in Lowlist on movies and tvshow level.
There was not so much removed. Most of which was removed is placed elsewhere. We wanted to have a consistent look & feel throughout the whole skin and for that some features had to go. Once the dust clears I'm sure everybody will be happy with the update.
Excellent, thanks for this awesome release.
(2012-05-25, 20:36)Big_Noid Wrote: [ -> ] (2012-05-25, 20:29)hikaricore Wrote: [ -> ]I really like the layout of the mixed setting for both tv and movie widgets, however the addon section in the middle is entirely useless to me. Would it be possible to add an option to replace it with Recommended / In Progress obviously based on the widget in question and its available items? It doesn't have to become rectangular or anything to fit the fanart because the wide boxes look great on the sides, posters or logos would work just fine. ^_^
You dont have to put add-ons there, you can put anything you want there. But I agree, an in progress/recommend option would fit nicely there. Will be added for next release.
(2012-05-25, 20:29)thrak76 Wrote: [ -> ] (2012-05-24, 22:21)thrak76 Wrote: [ -> ]Seeing the screenshots in the OP inspired me to try some new viewtypes for tvshows.
In doing so, I noticed what appears to be a bug:
When using the episode view for tvshows, the last item in the list is obscured by the bottom of the screen. This happens when using banners and logos for the list, but not when using text in the viewtype settings. Here are some screens:
Thanks for reading!
Quoting myself because this received no response.
Will be fixed for next release, thx.
Thanks for the attention guys.
Again... such an awesome skin!
(2012-05-25, 23:49)LukeS7 Wrote: [ -> ]Also, the logos do not work in the Low List viewtype, I'm looking at it right now and they aren't there. Don't get me wrong it's a great skin, it's just that some of the features have been removed it appears going from 2.0 to 3.0.
They do work. Just checked again myself.
Check you log and see if it has something about failed images
(2012-05-25, 11:00)phil65 Wrote: [ -> ] (2012-05-25, 05:03)spartacus51 Wrote: [ -> ]I apologize from the outset because I know I'm complaining about something given to me for free. I hope I can be at least marginally constructive.
I've rolled back to 2.0. My foremost reason is I loved Panel view for TV series list. I didn't like any of the options in 3.0.
One of my biggest complaints about many skins now is the included glaringly ugly "WARNING Mouse not supported please disable" pointer. I understand the mouse is not supported, but with my gyration remote I like to be able to tell where my mouse is from across the room on my multi-monitor setup and it is occasionally useful for using the top bar controls while watching video. I had previously made a replacement custom pointer, but that seems to have been lost in the update. I feel that there is a disconnect in the thought process which assumes that people will know enough to turn auto-update off (a feature I never knew existed) and yet not know enough to see that using their mouse doesn't seem to be working very well. Better said: why idiot proof a totally benign annoyance while doing nothing to prevent what has turned out to be a least a somewhat significant inconvenience to many people?
XBMC may well be my favorite program ever, and Windows may be my least favorite program ever, but at least Windows asks me if I would like to update and warns me that doing so may cause me to lose settings and customizations. In all my experience with IT professionals and the computer savvy one of the biggest pet peeves has always been forced unwanted changes. Might I suggest the implementation of a pop-up that informs of an update, warns against customization losses and then ASKS whether to upgrade.
I truly appreciate all the hard work from everyone involved in this amazing project. I hope any criticisms are taken in a constructive manner and I'll have made some tiny contribution rather than taken for insult and dismissed outright. Constructive criticisms may not always feel great, but when heeded almost always lead to doing better work. Thank you all once again.
1) We just do not support that. Period. IF some want to use it, then they should mod it. we want all those noob users to use remotes / keyboards.
2) people who are afraid of change should disable auto-update
3) you can still rollback and have everything the way it was before. so no customization losses. already explained x times in the thread here.
1) I still consider it a bullshit excuse for adding something ugly annoying and overall ridiculous. Average users that know what they want have to go to the trouble of modding something just because you hate noobs? If noobs can come to the forum and complain about it and apparently ruin your life then they can also come here and be told mouse use isn't supported and then railed at by you for not reading previous threads. I can see no advantage in going to the trouble of making something ugly when something plain and acceptable is actually easier.
2) If you are so afraid of noobs then why would you assume they will know to DISABLE auto-update? Shouldn't it be disabled by default and allow advanced users the option to ENABLE it? Where's the giant ugly red warning label that says auto-update is enabled? Your thought process is totally flawed and you're only trying to justify wrong thinking rather than correcting it.
3) I have rolled back and I'm still looking at this ugly ass red WARNING. Perhaps I should have said mods instead of customizations, Either way, if you read my post and gave it any thought you should have known exactly what I was talking about. If you're under the impression that my replaced mouse cursor wasn't lost after rolling back, then your assumption is wrong. It's definitely gone.
I may appreciate your work, but your attitude is lousy. Honestly I think it probably takes less time to answer most questions over and over and over than it does to be completely unhelpful and say "if you would read the 20 pages before this you would have your answer," over and over and over. Good on you for perpetuating the stereotype of the antisocial basement-dweller. You ought to be so proud of your superiority.
