(2012-07-19, 02:45)phil65 Wrote: [ -> ] (2012-07-19, 02:41)Elixxen Wrote: [ -> ] (2012-07-19, 02:01)phil65 Wrote: [ -> ]bit more specific, please. where exactly?
In both info wall and regular wall view. Maybe it shouldn't work in those views but wouldn't that option be removed/greyed out if that was the case? I seem to remember being able to darken the fanart even further in those views, I might be wrong though.
just looked at at it, the option is hidden here for wall and infowall and automatically on. that´s how it´s intended. you´re in movies or where?
Hmm that's weird. Yes in movies. I downloaded the latest GIT version 10 minutes ago and the option is there in both views but whatever it's not a biggie, it just got me wondering
(2012-07-19, 02:48)Elixxen Wrote: [ -> ] (2012-07-19, 02:45)phil65 Wrote: [ -> ] (2012-07-19, 02:41)Elixxen Wrote: [ -> ]In both info wall and regular wall view. Maybe it shouldn't work in those views but wouldn't that option be removed/greyed out if that was the case? I seem to remember being able to darken the fanart even further in those views, I might be wrong though.
screenshot, please.
EDIT: i see, i had glow mode set to on, then it isn´t available. it´s workin here though. i can toggle the dark overlay on / off when glow mode is set to off.
(2012-07-19, 03:03)phil65 Wrote: [ -> ] (2012-07-19, 02:48)Elixxen Wrote: [ -> ] (2012-07-19, 02:45)phil65 Wrote: [ -> ]just looked at at it, the option is hidden here for wall and infowall and automatically on. that´s how it´s intended. you´re in movies or where?
screenshot, please.
Yup you're right, the option disappears when glow mode is activated. Doesn't work either way for me though. I'll try a fresh update later. Maybe I did something wrong
Maybe I missed it somewhere, or it's just not fully implemented yet, but I'd like to sort the games in my Rom Collection Browser by system. So instead of the thousands of games all showing up in 1 huge collection, I can choose a platform, then the game. Does Aeon Nox do this (yet)?
(2012-07-19, 02:08)phil65 Wrote: [ -> ] (2012-07-19, 02:03)Greg. Wrote: [ -> ] (2012-07-18, 09:42)phil65 Wrote: [ -> ]why do you want to do that by editing guisettings? just change them from inside the skin.
might need some help Phil, i have quite a few that go 2 a specific directory that are not in library
and several more that just call favorites which are originally playlists
still don´t get what the problem is.
it's ok, just being lazy!, doing the playlists ez enough, just for some reason i 'missed' seeing the two folder choices, thanks anyhow, case closed, peace. out...
(2012-07-18, 04:15)JohnVee Wrote: [ -> ]Yeah, I understand. It does the same thing in the Now Playing screen too. What about just using the fanart that's in the root of the artist folder, instead of the fanart + extrafanart?
Just come up against the same problem. What seems to happen is the default fanart comes up as well as the extrafanart on top of that
(2012-07-19, 08:33)defluo Wrote: [ -> ] (2012-07-18, 04:15)JohnVee Wrote: [ -> ]Yeah, I understand. It does the same thing in the Now Playing screen too. What about just using the fanart that's in the root of the artist folder, instead of the fanart + extrafanart?
I already explained that it is WIP.
you´re using GIT version or Passion Repo version?
(2012-07-19, 08:34)phil65 Wrote: [ -> ] (2012-07-19, 08:33)defluo Wrote: [ -> ] (2012-07-18, 04:15)JohnVee Wrote: [ -> ]Yeah, I understand. It does the same thing in the Now Playing screen too. What about just using the fanart that's in the root of the artist folder, instead of the fanart + extrafanart?
My apologies. I hadn't seen that reply. I'm using GIT
There is a bug in the rss widget. I press on play but nothing happens.
Also I keep getting script error Randomitems.py
Is there no view for photo's anymore?
There was a view before called "stipshow" if I remember correctly
This was the only view that could show photo thumbs in their normal format, eg widescreen.
(2012-07-19, 20:19)bigbodiehard Wrote: [ -> ]There is a bug in the rss widget. I press on play but nothing happens.
thx, will be fixed.
concerning script error: is one of your libraries empty? script will get a fix for that in the next days.
(2012-07-19, 20:19)Marcel Wrote: [ -> ]Is there no view for photo's anymore?
stripshow should still be there.
which version are you using?
Hello,
With last git version, music visualisation (OpenGL spectrum) is under cd-wall, it's normal ?
No my libraries are not empty I updated the random script to 3.1.2 which should have fixed it. Is there a way to disable the error message showing?
(2012-07-19, 20:50)bigbodiehard Wrote: [ -> ]No my libraries are not empty I updated the random script to 3.1.2 which should have fixed it. Is there a way to disable the error message showing?
a full
Debug Log is needed. Paste the contents on xbmclogs.com and give us the link
