(2012-07-26, 10:07)jimmyave Wrote: [ -> ] (2012-07-26, 09:55)phil65 Wrote: [ -> ] (2012-07-26, 09:51)jimmyave Wrote: [ -> ]Okey, thanks for the reminder currently using 1920x1080, tried others, same problem... It just the clock, strange
using official 3.0.1 or 3.5 git version?
3.0.1! Tried English languague as suggested above, same problem :/
Had exactly the same problem when I had a Frodo nightly installed. Are you sure you have Eden 11? Please check it again.
I actually have the same issue with the clock as jimmyave, and I'm running Eden 11.
It's a smal small small small issue in an otherwise terrrrific skin. i got 15 other clocks in my house
tried 3.5? and post debug log, please.
does anyone know what code to edit in wall view mode to get the highlighted movie thumb not to cover the surrounding thumbs. This would be my favourite view if this was fixed
Big Noid / Phil65 / Any User : a few niggles
1- How many times can one use the "icon panel 1 & 2 " widgets . I have used them once each on 2 VPL's. Now If am creating another custom home menu ( for e.g RSS ) then the icon panel widget shows the settings I had created for the other menu, if I alter then then the original gets changed as well ?
2- Custom RSS--- eventually got it working ( have all the corresponding scripts )( apparently the custom feeds structure was not right.I then used another users modified feeds which have a few " amp .. & amps etc "in it . Now that is being correctly picked up and I can open via the RSS Client addon. BUT there is no way to exit or ESC out of it. I have to Close xbmc altogether. Surely all the people using the custom RSS would have figured this out but silly Ol' me.. I just cannot for the love of God figure this out .
3- Where is the RSS news Widget ? when I go into cutomisation and add RSS Client as a program addon and then try & customise with widgets .. it just opens the usual GUI which has no option for feeds? if i try using the icon panel widget then I run into issue #1
If I get sorted with this I will definitely write it all down as a tutorial so that hopefully others could figure this out easily.
(2012-07-27, 12:15)phil65 Wrote: [ -> ] (2012-07-26, 20:03)jimmyave Wrote: [ -> ] (2012-07-26, 14:31)phil65 Wrote: [ -> ]tried 3.5? and post debug log, please.
Will do that, heres my debug log:
http://xbmclogs.com/show.php?id=5631
in advancedsettings.xml:
<window>
<width>1024</width>
<height>768</height>
</window>
Must have been from before..
Removed that line, problem persist. Also tried to reinstall - didn't help. Installed 3.5 GIT version, and now it works
Thanks for all the help.
When is 3.5 going to be officially released?
(2012-07-26, 08:03)phil65 Wrote: [ -> ] (2012-07-26, 07:38)Hack_kid Wrote: [ -> ]ok i know eden is only supported at the moment but is there plans to support frodo. i really wanna update for AE etc but using latest master aeon nox locks up loading certain fanart images for artists. specifically ones from HTbackdrops it freezes for 10 secs then displays it. a dev said in the musicdatabase update pull reqest it has to do with multiimage or transisions or something. ive been trying to fix it but i can only get it to work if it just do a single image. anyone care to test and help me out? confluence and git master do not exhibit this issue. Big_Noid you remember me? wanna help?
https://github.com/jmarshallnz/xbmc/comm...a828cd4a91
https://github.com/BigNoid/Aeon-Nox/comm...2f09a7eff4
on its way.
cool thanks man. I dont know if your aware but there is one other bug when using Frodo. when playing music the current time of track is displayed like HH:MM:SS instead of MM:SS. other then that i dont know of any issues
Since AeonNox 3.5 is coming in the near future I thought it would be a good idea to summarize the supported addons a bit more.
Most info´s are hidden somewhere in this thread or in the depths of the internet.
Phil65/BigNoid feel free to change the post to your liking or delete it if you don´t like it at all.
- script.color.picker - Support Thread - Download(Passion Repo) - Credit: FrostBox - Screenshot
choose color and transparency level for your skin
- script.watchlist - Support Thread - Download(XBMC repo/gets installed automatically) - Credit: Ronie, Hitcher, Martijn - Screenshot
lists the next, unwatched episode of a TV show you're currently watching
- script.tvtunes - Support Thread - Download(XBMC Repo) - Credit: ppic, Ronie - Screenshot
will automatically play tv tunes when entering the show in library mode
- script.widget.weatherworld - Support Thread - Download(Passion Repo) - Credit: FrostBox - Screenshot
new bg option, new button in weather area
- script.metadata.actors - Support Thread - Download(Passion Repo) - Credit: FrostBox - Screenshot
backend support for tripanel, new buttons in movie info dialog, extra widget
- weather.google - Support Thread - Download(Passion Repo) - Credit: FrostBox - Screenshot
new widget
- script.artistslideshow - Support Thread - Download(XBMC Repo) - Credit: Ronie - Screenshot
addon option "download additional info" to get rotating nowplaying widgets
- script.tv.show.next.aired - Support Thread - Download(XBMC Repo) - Credit: ppic, Ronie - Screenshot
shows an overview for all coming episodes of your shows
- script.rssclient - Support Thread - Download(Passion Repo) - Credit: pieh - Screenshot
Standalone RSS Client. Provides dedicated GUI for browsing through RSS Feeds. Allow user to open attached media (Images and Videos)
- weather.fanart.pda.style - Support Thread - Download(Passion Repo) - Credit: FrostBox - Screenshot
extra widget
- plugin.image.mypicsdb - Support Thread - Download(Passion Repo) - Credit: solexalex, Xycl, MikeBZH44 - Screenshot
new background option, new widgets
- script.ExtraMusicInfo - Support Thread - Download(Passion Repo) - Credit: pieh - Screenshot
extra widget and extra item in "area selection" for custom items
- script.cinema.experience - Support Thread - Download(github) - Credit: giftie - Screenshot
new pre-defined function, submenu entry for movies, new button in movie info dialog
- script.randommovie - Support Thread - Download(github) - Credit: el_Paraguayo - Screenshot
- script.randomlastitems - Support Thread - Download(XBMC Repo/gets installed automatically) - Credit: mikebzh44 - Screenshot
scans library and shows random or recently added items
- script.moviesets - Support Thread - Download(Passion Repo) - Credit: FrostBox - Screenshot
add-on library for showing details of Movie Sets.
- script.song-to-musicvideo - Support Thread - Download(GoogleCode) - Credit: Ronie - Screenshot
button in mediamenu when there´s a music video of focussed song available
- script.rssfeeds - Support Thread - Download(Passion Repo) - Credit: Team-Passion - Screenshot
manage RSS-Feeds
If there are errors or improvements please pm them to me and don´t let the thread go off topic.
Edit:
- script.rssfeeds added (thx fmronan) | Zip-File Updated
- zip-file removed (thx Martijn)
Well done solidsatras. Thank you.
