(2012-05-27, 16:01)Big_Noid Wrote: [ -> ] (2012-05-27, 15:26)yazgar Wrote: [ -> ]First off, fantastic job guys, tri-panel with aeon style home screen is all I ever wanted! Really appreciate all of the time and effort you've put into this.
Wondering if someone can help me though, I have a freezing on start-up problem that only seems to happen with new nox 3. Worked fine to start with until I did god knows what (maybe tried to access TV schedule from home screen?..maybe), XBMC froze, so I force quit, but then when I tried to restart xbmc, I get the busy spinning circle from nox then a freeze everytime. I've deleted nox3 from .....\AppData\Roaming\XBMC\addons to get back to confluence, I've disabled just about every service and addon with no luck. I'll do a complete reinstall of xbmc if there's no luck here, just hoping someone who knows a lot more than me can check out my debug log before I start fresh again. cheers
http://pastebin.com/Vug1UUZ3
While frodo is not yet supported, I can tell you that deleting script.randomitems will solve your problem.
Deleted the script.randomitems folder in ....\AppData\Roaming\XBMC\addons but still froze. All ok though, rolled back to Eden and Nox3 is loading fine. Thank you for the great work on the skin.
(2012-05-27, 13:05)phil65 Wrote: [ -> ] (2012-05-27, 13:02)leepenny Wrote: [ -> ]I can confirm that I had the remote stops working problem (so rolled back).But after reading the thread this morning forced refresh and updated and have found no issues as of yet with the remote not playing sd,divx,xvid,bluray files (fingers crossed)
Now I do have some questions and I hope you will be patient and hope that these arent too noobie type questions.
1. How do I get artist fanart now playing on home screen
2. On the recently added music widget when you press up it flips over but doesnt give me album info like the movies widget is this a bug or is it normal.(see pics attatched) https://www.dropbox.com/gallery/1358044/...x?h=d6cd0f
If normal could the widget be tweaked to show the album info? (Only if easy as I know youre hard pushed with all the hard work youve put in to this skin)
3. Aeon Nox isnt reading my cbr (comic) files, i've added them as a custom favorite (from file mode) and added them to comics on home screen .When opened it shows the relevant folders but on opening shows nothing (I havent got a clue why) Any help much appreciated
And finally THANKYOU for one of the best skins I have ever used ,the fluidity and eye-candy is second to none and have found no other skin that can compare to this skin , absolutely outstanding work.
1) home menu customizer --> click on any item --> set bg --> general bg settings
2) xbmc limitation, i´d love to be able to "fix" that, but not possible.
3) probably has nothing to do with the skin. is that file extension recognized by xbmc?
...and the remote problem will still happen occasionally for you if you didn´t make any code changes. will be fixed for next bugfix release.
If cbr files cant be used doesnt it make the comic section er difficult to use (I can open the files in file manager though cbr files being standard comic book file type?)
It did work in previous version ,any aeon nox/comic readers willing to input theories
I can't seem to find how to have my movies show folder.jpg instead of backdrop.jpg.
any help?
Since the forced update to 3.0 all the thumbs for my series have been replaced with banners resulting in a stretched and ugly look everywhere. Thumbs are like the shape of a dvd case. Banners are horizontal. Replacing them all back again is a painful process. I'm curious to know...
Why were they overwritten?
Why when i try and change them back again do I see banners AND thumbs when browsing now?
Is there a way to get my thumbs back in a less painful way?
No thumbs were replaced. You probably want to check 'use poster.jpg' in the media menu.
I have enable folder.jpg for album cover enabled, but all my movies have switched to backdrop.jpg after the update. Is there a way to switch to everyone without having to go to each movie individually?
When i do that then all the thumbs disappear and are replaced by the default - no image picture.
Tried restarting XBMC after changing to poster view and now the posters show.
Thanks, that's looking good again.
hi
i like new skin but I need little help
after update my settings are lost so need to renew it.
in older version I added this line to home.xls
<item id="666">
<label>Telewizja</label>
<onclick>XBMC.RunScript(C:\TV.py)</onclick>
<icon>special://skin/backgrounds/cyfra.jpg</icon>
<thumb></thumb>
<visible></visible>
</item>
and had Telewizja in main menu
but now I dont know where to paste it. Little help please. between which lines paste that Code? please
(2012-05-27, 19:30)rupertos Wrote: [ -> ]hi
<item id="666">
<thumb></thumb>
<visible></visible>
</item>
Please see
this thread for a reference to custom items
Would someone please let me know how to set the path to Comics in Aeon Nox 3.0?
I managed it with version 2.0 but I've either forgotten how or I've got my 'stupid head' on today.
Thanks for all past and future support
Steve
(2012-05-27, 16:39)bigbodiehard Wrote: [ -> ] (2012-05-27, 16:20)phil65 Wrote: [ -> ] (2012-05-27, 16:13)bigbodiehard Wrote: [ -> ]Tried it don't work but still a great feature. For the next release could you not just add the shortcuts to menu when you press m
no, we cannot define what key triggers which event. this is done by the keymaps.
you could remove the first line from the two i posted but this will start viewtype selection OR quicknav depending on what you used last.
No I Meant could you not replace this
With something like this
yes, agree that it would be a better layout, but something for 3.1/4.0.
add it to our github list if you do not want us to forget that
(2012-05-27, 18:31)Monkeypox Wrote: [ -> ]I have enable folder.jpg for album cover enabled, but all my movies have switched to backdrop.jpg after the update. Is there a way to switch to everyone without having to go to each movie individually?
We dont use any external art for movie thumbs, so I'm not sure what the question is.
(2012-05-27, 20:22)steshell Wrote: [ -> ]Would someone please let me know how to set the path to Comics in Aeon Nox 3.0?
Steve
Easiest would be to go to pictures add your comics there as source. Add it as favorite and set that as default action for opening comics. Afterwards you can remove the favourite and source in pictures.
Will be adjusted for 3.1.0 release (not for upcoming bugfixes release).
Is it possible to get dvd/blu-ray covers in the List view mode?
(2012-05-27, 20:50)Subways81 Wrote: [ -> ]Is it possible to get dvd/blu-ray covers in the List view mode?
no.
Hi there,
Fantastic skin, but im looking for some help on it. I've searched around, hoping that i would come across someone with a similar problem and i found this.
(2012-05-27, 20:50)Shinu Wrote: [ -> ]ok....
http://pastebin.com/Qjg5c9rK
i left it on for around 5 minutes when this poped up....
i dunno if u remember, but i got that same pop up somewhere else (can't exactly remember where Confused), but it seems to be related to the Metadata actors script. i temporarily removed the script and i was able to press escape to bypass the loading screen. maybe u can see why its happening to begin with.
For me, every time i startup XBMC with the Aeon Nox 3.0 skin i get this search box, the only way to close it so i can get XBMC to load up to the home screen is by pressing Esc a couple of time.
Is there any work around to this?
Cheers
