just updated to the build up on git, and now all the text under menu items in home are not visible:
actually if i look at the screenshot at a huge angle, you can barely read the text...its all white.
after checking all the color schemes, these ones work:
redslate
default
mosaic blue
the only one not working is the night mod...did a color tag change or something?
edit nevermind, I redownloaded the build, although this time from the mediafire link. after restarting xbmc, it now shows correctly. must not have overwritten a file the first time or something.
Hey just noticed that you have a image for the 'SDTV' source in the "Alaska/media/flags/Source" folder named 'sdtv.png', but found that its not included in the Includes_MediaFlags.xml file. any chance of adding it?
update:
i have updated the tags xml file to look like this. (it works and i was hopping you could add it to your code) cheers
Quote:<control type="image">
<include>PosterMediaFlagsVars2</include>
<texture fallback="flags/default.png">$INFO[Listitem.VideoCodec,flags/VideoCodec/,.png]</texture>
<visible>!substring(listitem.filename,hdtv) + !substring(listitem.filename,sdtv) + !substring(listitem.filename,dvd) + !substring(listitem.filename,bluray) + !substring(listitem.filename,blu-ray) + !substring(listitem.filename,bdrip) + !substring(listitem.filename,.iso,Right) + !substring(listitem.filename,.ifo,Right)</visible>
</control>
<texture>flags/Source/sdtv.png</texture>
<visible>substring(listitem.filename,sdtv)</visible>
</control>
Sorry for beeing a newbie, can anybody tell me how to make the small movie (on the left button after hitting ESC on keyboard) to become fullscreen again?
Tried to find it, but no luck.
Hitcher - thanks for all great work!
Hi Hitcher,
iIfound a bug in your latest Alaska Version. When i create a Set of Movies, like 'Lord of the Rings', i see one LOTR Entry in the Movie Overview. When i click this one, the Submenu opens with the three single Movies. So far so good ...
But when i mark every one of the three LOTR Movies as watched, the watched Status is not shown in the Main Overview.
Hope you know what i mean.
Go on ...
Efty
mamruoc Wrote:Sorry for beeing a newbie, can anybody tell me how to make the small movie (on the left button after hitting ESC on keyboard) to become fullscreen again?
@Hitcher - thanks for all great work!
TAB should do the trick ?
Just grabbed latest version from git and noticed 2 things changed.
When using Night the
- main menu text is now white which means it is not visible against white icon panel
- movies posters the non selected posters now seem to have a white defuse over them whereas they were dark before ( which looked better ).
MrTourettes Wrote:Just grabbed latest version from git and noticed 2 things changed.
go grab the media fire one...did you not spend 2 seconds reading my post 7 posts above yours on this very same page?
Evanrich Wrote:go grab the media fire one...did you not spend 2 seconds reading my post 2 posts above yours?
Yes I did but the mediafire one will be older and whats the point in going backwards
I had the version you are now runnign before and basically just did an update from latest in git. Now Hitch needs to know about changes anyway so might as well post findings as I go.
Also yes I did repost what you had already stated but nothing wrong with re-itterating something so he knows its not an isolated case.
chrisallen511 Wrote:Hey just noticed that you have a image for the 'SDTV' source in the "Alaska/media/flags/Source" folder named 'sdtv.png', but found that its not included in the Includes_MediaFlags.xml file. any chance of adding it?
update:
No problem, added.
efty.edge Wrote:Hi Hitcher,
Go on ...
Efty
How does this work with other skins because it sounds more like an XBMC issue to me?
This is how they look for me and I checked the colour files against the Git ones and they're the same.
Hitcher Wrote:This is how they look for me and I checked the colour files against the Git ones and they're the same.
I will have another look when I get home from office. I will delete my Alaska Contents and grab from git again. Will let you know if a clean git grab sorts it.
MrTourettes Wrote:I will have another look when I get home from office. I will delete my Alaska Contents and grab from git again. Will let you know if a clean git grab sorts it.
I think it was just something didn't get grabbed or overwritten, becuase I checked the git download again and it seems fine.
Evanrich Wrote:go grab the media fire one...did you not spend 2 seconds reading my post 7 posts above yours on this very same page?
or edit the night.xml in Alaska/colors, here is what I use:
<!-- Home 1 Colours -->
<color name="HomeFrameColor">ff004a69</color>
<color name="HomeFrameDiffuseColor">d7000000</color>
<color name="MainMenuLabel">FFFFFFFF</color>
Should do the trick nicely
