I like the new icons...I think they look a little more sleek.
Just used this for a little bit to see what its going to be like - very impressed! Keep up the good work guys
New Episode animation added.
Before
You didn't know when you'd reached bottom of the list until it jumped back to the start.
After
Now you know when you're at the top or bottom of the list.
All thanks to JMarshall for adding the <movement></movement> tags.
PS You'll need a build higher than 23811 for this to work.
Hitcher Wrote:New Episode animation added.
Before
After
Excellent, this is what I was referring to before, I always loved the effect of the screen cap moving up and down, and didn't like it when completely static. Great compromise.
paularms Wrote:Please ditch the gloss. That seems really out of place. Did you also mute the saturation of the red? I liked the original, bolder icons.
Do you mean the original ones djh_ had in is mockups or the original ones that I'm replacing (the ones with the debossing)? And I was on the fence about the gloss, I just needed someone to throw something at me to knock me either which way.
Before
After
hmm I can't find a build higher than 23811 :S
ow wait.. there is one..
http://danielpatton.com/user-accounts/XBMC-updates/
is this the one you are using hitcher
I've downloaded the latest version and don't seem to have any studio flags any longer? I've switched the option in settings so I should be seeing this?
jaytyler Wrote:I've downloaded the latest version and don't seem to have any studio flags any longer? I've switched the option in settings so I should be seeing this?
Let me guess, you updated with git but didn't read the changelog or the first post in the thread...
Oh yeah, forgot about that.
This looks VERY promising!
Quick question: How to remove games/pictures etc. from the home-menu?
prebenhansen Wrote:This looks VERY promising!
Manually edit includes.xml or wait for the skin to be finished.
I have last nights build of XBMC and the latest alaska. The icons look the same as before, there are no studio flags or any flags of any kind. and paging back from movies goes through all them folder things of genra etc.
Looking great though, just saying is all.
