rausch101 Wrote:I think there will be a group of developers. There are now.
Alaska is on GitHub as per the first post of this thread.
Cool!
Anyone up'd a copy anywhere other than GitHub - for non Github users
You don't have to be a github user, you can download an archived version of the skin right from the GitHub project page and it will be the most recent version.
logggio Wrote:Hey guys, i was just wondering if anyone was having any issues with Alaska on XBOX?
i've installed the latest nighty SVN on my laptop (windows 7) and my XBOX... Alaska works fine on Windows but fails to load the icons in the settings menu on my xbox and most of the fanart in the main menu boxes. Anyone having this issue?
This may have already been discussed, im not sure. But 56 pages of pointless babble and posts of photoshop mock-ups makes it hard to search through and find that little nugget.
Thanks in advance guys!
Cheers.
Yep can cofirm this - latest T3CH and alot of Alaska is missing on Xbox....
Geeba Wrote:Yep can cofirm this - latest T3CH and alot of Alaska is missing on Xbox....
can't say i've tried this yet but i'm planning on it soon. this is the alaska fork for use with plex. some stuff had to be changed because plex uses an older version of the skinning engine which i'm guessing the xbox does too? in any case, the stuff changed to work with plex may also make it compatible with the xbox. worth a shot.
http://github.com/gelsner/PlexAlaska
Marc
CF2009 Wrote:Video Bookmarks
I like that alot i really do lol and Children of men is a great movie.
jondr13 Wrote:Looks alot like Alaska to me.
Really? It looks nothing like Alaska to me, other than the light background.
This skin is great Hitcher! But ...
... can can't wait anymore, so when is it possible to download 'nightly builds' via Github!? The last one (Initial Release) is four days old.
Thanx
Efty
efty.edge Wrote:This skin is great Hitcher! But ...
Thanx
Efty
That's because it hasn't been worked on in four days by hitcher. Check the "Network", you will see others involved with the project too.
go hitcher... i'm happry that you are working on that project
looks very good ....
thanks to djh to do the "ground"work
If you would this skin to work more smoothly on xbox go into the media folder of the Alaska skin and open up the filter.png file in your favorite photoshop program and drop the resolution to 960x540 or lower also go into the media/list folder and do the same for vignette.png and vignette2.png.
