2009-10-21, 18:17
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
2009-10-21, 18:20
2009-10-21, 18:41
that is beautiful, keep up the great work and cant wait for the official release of this skin!
2009-10-21, 19:13
Wow, that looks awesome. Thank you for your work!
2009-10-21, 19:39
Could someone tell me how to prevent it going through genre folders etc when paging back from movies or tvshows, I remember this with aeon and there was an easy fix.
Cheers
Cheers
2009-10-21, 19:43
On the XBOX, the icons in the settings screen are not showing, and not all home screen button backgrounds are loaded (sometimes almost all of them, sometimes only one or two). Is this a known problem?
2009-10-21, 19:46
@jbor613
If by darker you meant less transparent then change the bolded value in Includes.xml:
Where end="80" the lower the number the more visible the fanart, myself I liked when it was less transparent and changed them to end="90"
Quote:<include name="Global_Filter">
<control type="image">
<include>Dimensions_Fullscreen</include>
<texture>backdrops/background.png</texture>
<animation effect="fade" start="100" end="80" time="400" condition="[!IsEmpty(ListItem.Property(Fanart_Image)) + !Window.Next(Home)]">Conditional</animation>
<animation effect="fade" start="100" end="80" time="400" condition="[Window.IsActive(2) + [substring(listitem.filenameandpath,jpg) | substring(listitem.filenameandpath,bmp) | substring(listitem.filenameandpath,png) | substring(listitem.filenameandpath,tif) | substring(listitem.filenameandpath,ico) | substring(listitem.filenameandpath,pcx) | substring(listitem.filenameandpath,tga)] + !Window.Next(Home)]">Conditional</animation>
</control>
<texture>backdrops/backgroundcolordiffuse.png</texture>
<colordiffuse>backgroundColor</colordiffuse>
</control>
</include>
2009-10-21, 19:50
@Bram77
did you lower the media\backdrops\backgroundcolordiffuse.png and media\backdrops\background.png to 960x540...I'm using an Alaska build from 10-5, then they we're using filter.png. Once I lowered filter.png to 960x540 that problem you described went away.
I'm planning on updating my Alaska XBOX build some time soon I let you know if I come accross your problem...
2009-10-21, 19:55
garyi Wrote:Could someone tell me how to prevent it going through genre folders etc when paging back from movies or tvshows, I remember this with aeon and there was an easy fix.Add ,return to which ever control you want it on.
Cheers
Bram77 Wrote:On the XBOX, the icons in the settings screen are not showing, and not all home screen button backgrounds are loaded (sometimes almost all of them, sometimes only one or two). Is this a known problem?Not tested it myself on the Xbox but you will need an fairly new version.
mcborzu Wrote:@jbor613I've changed it to "90" a few days ago.
2009-10-21, 20:24
mcborzu Wrote:@Bram77
Thanks, I will try that!
@hitcher: My XBOX XBMC build is never older then a few days
2009-10-21, 20:24
so it becomes previousmenu,return
2009-10-21, 20:57
Thanks guys - I wanted to make fanart just a little MORE visible. I love the simplicity of this skin, and the lightness is awesome, but some of the fanart I have, in my opinion, is just too good-looking to be that faded.
I'm going to try changing it now.
2009-10-21, 21:07
This is directed at the team behind the making of alaska. Is there some kind of written priority list of what's going to be made next? If so, it would be really nice if it were released and open for the community to look at
2009-10-21, 21:32
So I attempted to change the opacity of the background filter. I was in File view, and didn't see any change. But when I switched over to Poster or Fanart view, the background was completely gone.
I don't really mind that, because I don't use those views. But is there a way to change the opacity of the background in File view?
2009-10-21, 22:33
garyi Wrote:so it becomes previousmenu,returnhttp://github.com/HitcherUK/Alaska/commi...5d78cab9da
fillidill Wrote:This is directed at the team behind the making of alaska. Is there some kind of written priority list of what's going to be made next? If so, it would be really nice if it were released and open for the community to look atNothing written, we're doing things as we see fit.
jbor613 Wrote:So I attempted to change the opacity of the background filter. I was in File view, and didn't see any change. But when I switched over to Poster or Fanart view, the background was completely gone.I've completely changed the background for File (and List actually) so as to fade the lists out while at the same time keep the fanart evenly faded. To do this I made two textures, one that goes over the fanart and another that goes over the list, but with the same effect as the single texture.
You really don't need to be messing around with them though - just look for the <animation effect="fade" start="100" end="80" tags in those views and adjust the end figure.
