This is sick guys.
I can't seem to get it working though.
First on the source list it doesn't show all my EMM sources. I then populate my sources and choose the corresponding source from the drop down. I click OK and save everything. I come back and the populated sources are gone from the drop downs.
Any ideas? Reinstall EMM?
krypt2nite Wrote:This is sick guys.
Have you update over a previous versions? if so delete advancedsetiings.xml.. setting changed from old version you may having issue because of that.. if not please open a issue in tracker so we can follow it! (attach you advancedsettings.xml after configuring you xbmc host pls)
Sure thing man. I reinstalled a fresh EMM and added one single source and same issues.
Bug #546
Doesn't have anything to do with my EMM machine being 64bit WIN7 does it?
krypt2nite Wrote:Sure thing man. I reinstalled a fresh EMM and added one single source and same issues.
Bug #546
I'm working on it.. please follow the tracker
Hi Guys
Great programme
Finally got round to doing my tv shows, all seem ok, I seem to have a problem if I have two seasons. When I load in for example Calafornication, it shows me season 1 and season 2, however if I then try to rescrape to get the info,season 2 just disappears. All my files are in folder called TV Shows within that I have one folder for each TV show, I hav the latest version 1.2, any help appreciated, pretty sure it is something I'm doing
Paul
olympia Wrote:I am not sure I understand your first question. Just create a folder for them nad set up this folder also as a separate source.
It is not scanning the drive. You can only do this manually.
Edit: how on earth should Ember even detect which movie are on a DVD?
Thanks, but I can't even figure out how to scan the metadata. I was able to create the offline movie, but do I need to enter the metadata manually?
david81 Wrote:Loving the new Ember, but having one little issue that just cropped up. When I'm scraping TMDB for posters, I get plenty of choices that show "Multiple" sizes available, but I can only select "Medium". The others are grayed out.
Might this have anything to do with the announcement I got from TMDB the other day about changes to the site and API?
Is anyone else still seeing this? Thanks for the latest!
I would like to make a feature request. I know I'm suppose to at the ember web sight, but for some reason I'm an Invalid user.
Any way, I was wondering if it would be possible to edit multiple episodes at one time?
scrolling Wrote:I would like to make a feature request. I know I'm suppose to at the ember web sight, but for some reason I'm an Invalid user.
Can you indicate the username you tried to register with?
Paulkai Wrote:Hi Guys
Paul
so the paths look like:
\TV Shows\Californication\S01
\TV Shows\Californication\S02
I have my entire movies saved on a acer home server.
with all the old versions of the EMM I could manage this easily.
since the current version will be removed at the database-updating all the movies and I have to enter the path of the films from scratch.
what can it be?
System is:
Win7 Ultimate & Acer easystore h340 with Windows Home Server
greetz from germany
I am having a problem where Ember isn't finding media on any newly added sources since I upgraded to v1.2. I tried to find a log, but there only an old file in the log folder.
I've been trying to figure this out, but no luck, so i finally decided to ask for help.
EMM does not detecting my TV Shows (structure). I have
24
- Season 01
- 24.1x01.12.00.AM_1.00.AM.AC3.DVDRip
- 24.1x01.12.00.am_1.00.am.ac3.dvdrip_ws_xvid.avi
same thing for all the other shows, but it DOES detect all the shows just fine with this folder structure:
24
- Season 01
I DON'T want to move all episodes from their folders into one folder with all avis inside.
This just looks like if recursive scanning was on, it would work. Do I have to edit regex or am I doing something wrong?
(running ember 1.2, on win xp)
Thank you.
RockDawg Wrote:I am having a problem where Ember isn't finding media on any newly added sources since I upgraded to v1.2. I tried to find a log, but there only an old file in the log folder.
It's quite a few information to track it down.
