nul7 Wrote:So did I. lol These 2 problems are probably linked in some way. I'll have to experiment some with it.
EDIT: I've been playing with this throughout the day and it seems to work flawlessly. Can you verify that you are using r282?
is it for sure r282 64bit and EMM_Extras_07_x64
I even created a separated folder and installed them.
The only difference is that I created my flag with my additional icon
here are the screenshots:
here is the error log, I only tried to update media - all movies - automatic - all info some times:
Title: Error
Message: There is an error in XML document (1, 2).
StackTrace: at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at System.Xml.Serialization.XmlSerializer.Deserialize(TextReader textReader)
at Ember_Media_Manager.Master.LoadMovieFromNFO(String sPath)
at Ember_Media_Manager.frmMain.bwLoadInfo_DoWork(Object sender, DoWorkEventArgs e)
Date/Time: 12-Jun-09 00:48:15
Title: Error
Title: Error
Date/Time: 12-Jun-09 00:48:23
Title: Error
at Ember_Media_Manager.frmMain.bwScraper_DoWork(Object sender, DoWorkEventArgs e)
Date/Time: 12-Jun-09 00:48:26
Title: Error
question:
why the first run are all green and bold and the second run are black?
if I re-scrape a single file:
now scans all the poster and pictures (previous reinstallation was not doing it)
but again the locked title is over written:
<?xml version="1.0" encoding="utf-8"?>
<movie xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<id>tt0212720</id>
<title>Artificial Intelligence: AI</title>
<originaltitle>Artificial Intelligence: AI</originaltitle>
Here is the original nfo
<Movie>
<title>A.I. Intelligenza artificiale</title>
</movie>
http://akas.imdb.com/title/tt0212720/
it should have worked fine.
log after scrape
Title: Error
Title: Error
Title: Error
Title: Error
Title: Error
Title: Error
Date/Time: 12-Jun-09 00:51:29
My 2c is that the nfo format blocks the automatic importfor some reason but not the scrape.
anyway here is the options
Last but not least I've noted that the scraper does not read correctly the IMDB code from the original NFO as it asks me to identify the movie (as my title is not the english one)
hoping this helps!
Mf
