Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
so it says that the login issues have been fixed, but as of 2 days ago for some reason i can't log into youtube. It says Login failed - false.
i went into addons, and onto youtube, and it still shows version 2.7. I tred disabling and enabling but no luck. tried uninstalling but it says plugin used by themoviedb can't uninstall. I deleted it from the aplication support addons directory and tried re installing but again still shows 2.7. I've been using nightlies, and when i started having these login issues i even udated to the latest one from yesterday but no luck.
any way for me to force update to 2.8? I did go onto update in the youtube plugin info in addons. it says addon updated but still shows 2.7
Not sure whats going on anybody got any clues?
TobiasTheCommie Wrote:For Eden-pre:
Changelog 2.8.0
- Changed All videos now have a unique path from xbmc's perspective eventhough they're present in different folders.
- Changed Replaced the categories scraper with api calls
- Moved some functions from youtube utils to common so they can be shared between different plugins
- Fixed music artist and top hit's scraper
- Added play all option to youtube top 100
- Added setting to control playback of 3d anaglyph streams
- Changed downloader into a seperate service.
- Fixed login
For Dharma:
Changelog 2.1.3
- Fixed login.
We will no longer be providing zip files for our releases, since that has become unfeasible.
nmirza Wrote:so it says that the login issues have been fixed, but as of 2 days ago for some reason i can't log into youtube. It says Login failed - false.
You have to wait till our pull request is merged. I expect this to happen today, but it really is totally out of our hands at this point. So wait a bit.
i can not login for some reason, i dont know why, i even checked the troubleshooting and did what was said in there.
i installed From repository
this is my log:
http://pastebin.com/RGfSwC3p
meandor Wrote:i can not login for some reason, i dont know why, i even checked the troubleshooting and did what was said in there.
this is my log:
Fixed in the 2.8.0 release, wait for it to reach the repository then upgrade.
Thanks for fixing the login so quickly.
The updated version is now in the add-on repo.
I'm not seeing it yet.
i can't see it either.
I just updated to 2.8 from git (I'm running xbmc from git as well), I still seem to be getting the "Login false" error.
Tomasu Wrote:I just updated to 2.8 from git (I'm running xbmc from git as well), I still seem to be getting the "Login false" error.
You really shouldn't be upgading YouTube from git, it has quite a few dependencies that are required that you need to add manually as well.
I highly suggest you install youtube 2.8.0 from the addon-repository.
If you can't find 2.8.0 in the addon-repository, you need to update it.
If you are still having problems with login with 2.8.0 do this:
http://wiki.xbmc.org/index.php?title=Add..._debug_log
Login working, updating from rep. Thanks Smile
so I'm on 2.8.0 (the latest and greatest) ? on eden-pre and My Liked Videos says: No Results! and I know there should be 100's...
12:46:17 T:140292054988736   ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/?path=/root/liked&scraper=liked_videos&login=true&
12:46:17 T:140292054988736   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?path=/root/liked&scraper=liked_videos&login=true&) failed
Try logging out and logging back in.
If it still fails, debug log.
where's the logout option ? :p I must be blind, lol
Heh, change your login info to something that isn't valid. Press ok to close the settings and get logged out.
