Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
ameinild Wrote:Bummer for this plugin: When you click "Now playing" in the menu from the youtube plugin, you go to the Now playing for music - which is most likely empty. Why not go to Now playing videos instead? This has worked in an earlier release! Smile
Hi this is a know error (a fixed was mentioned earlier in the thread) but we will push one out in a service release soon Smile
Vrok Wrote:Is there a way to queue and play all files from a youtube playlist using plugin:// paths?
I want to add my youtube music playlist to my favourites.
Also can I make my youtube playlist autoplay on XBMC startup and between anything else in the background?
Currently no, it is infact quite cumbersome, but i have created a patch for XBMC that implements this feature it just needs review from some xbmc folks:
http://trac.xbmc.org/ticket/10959
rufus99 Wrote:great addon!!!
it works fine and stable, but i have a question:
is there a possibility to start a youtube-video from a textfile with the link in it? i tested it with the .strm-filetype but it does not work.
that would be great to simply add some trailers without downloading.
---------- EDIT ----------
I Just tried this on my own machine, and it works almost perfectly the only thing thats missing is the video information from the video but otherwise everythings good Smile (for good measure i've included the file i used to test with, just rename it from .strm.txt to .strm)
HenrikDK Wrote:Currently no, it is infact quite cumbersome, but i have created a patch for XBMC that implements this feature it just needs review from some xbmc folks:
Yeah that's exactly what I want but probably with a shuffle parameter in there
Vrok Wrote:Yeah that's exactly what I want but probably with a shuffle parameter in there
shuffle parameter could probably be added Smile but in any case it's up to the devs to judge if the code is fit to be added in xbmc.
iswasdoes Wrote:Hello people.
I (and a few other peeps) are having an issue with the plugin, which I posted in this thread here http://forum.xbmc.org/showthread.php?tid=93226 - if any kind, wise and sage fellows could offer any advice...well, that'd be swell.
Hi, check my reply in the thread Smile
jurrabi Wrote:Quick question (for the translation)
What does "Refine to user" mean?
Can it be a typo?
I was tempted to understand "Refer to user" as in "recommend to user"... but I really don't know...
At one point someone wanted to limit a search to only search for videos from a certain user (mostly the UK's 4oD user that uploads alot of tv shows), so its probably more correct to say "limit search to user" or something Smile
Celox Wrote:i noticed xbmc crashing while trying to play a few youtube clips. also happend to me after a fresh restart.
here is the crashlog
http://pastebin.com/RG1fQmJ3
Platform: Linux (Ubuntu 10.04.2 LTS, 2.6.32-28-generic x86_64). Built on Feb 2 2011 (Git:83d67e4) (compiled using git sources)
XBMC Skin: skin.aeon65
if you guys need more info or tests im glad to be of any help! Smile
Hi Celox, we don't control video playback, we only serve up the url to xbmc, and from looking at your log:
22:57:18 T:140169389020928 M:2758860800   ERROR:  (VDPAU) Error: The display was pre-empted, or a fatal error occurred.(2) at VDPAU.cpp:1000
this seems like an VDPAU related issue. please report it to the xbmc dev's Smile
Godfazzer Wrote:How to make it play videos continuously from playlist?
1. Start playback of a video
2. Queue all the items you want to follow (usually by pressing 0 on the remote)
Basically this is alot more difficult/annoying than it should be, but we have submitted some patches for xbmc that should make it easier in the future (http://trac.xbmc.org/ticket/10959).
/Henrik DK
HenrikDK Wrote:---------- EDIT ----------
Yeah that is working now!
thank you a lot!
Hi everyone,
First of all, thank you for this great addon.
Now the question : would it be possible to have the "watch later" feed?
sregg Wrote:Hi everyone,
Hi sregg, as far as i know theres no api for this but I'll look into if its possible to scrape the information from youtube.
I am new to XBMC and python plugins. I was able to figure out how to call the Youtube plugin with the video id (page 33 of this thread). But when I do call the plugin I get the following error in the log.
Quote:14:03:37 T:5904 M:1049944064 ERROR: XFILE::CPluginDirectory::SetResolvedUrl - called with an invalid handle.
When I copy the link and paste it in Chrome browser, the file starts downloading with out any issues.
http://v12.lscache7.c.youtube.com/videoplayback?sparams=id,expire,ip,ipbits,itag,algorithm,burst,factor&fexp=901031&algorithm=throttle-factor&itag=35&ipbits=8&burst=40&sver=3&signature=668FFC4820CD591FB036B65774E418B2B8CD9170.4F9283F43884D0C0DC8CDF23BC2CCFE155749D0D&expire=1298340000&key=yt1&ip=71.0.0.0&factor=1.25&id=98559ca6e7a130cc
So why is XBMC not playing the link? Can you please help?
Also on a different note, how do I call the plugin with a playlist parameter? Currently my URL is of the format
http://www.youtube.com/p/0F50DD75842E0226?hl=en_US&fs=1
I am passing this to the API [/CODE] http://gdata.youtube.com/feeds/api/playlists/....[/CODE] to get the individual video ids and then calling the youtube plugin. I am hoping I can just call the plugin with the Playlistid. is that possible ? if so how? I did try changing the videoid to playlistid in the plugin call but I got an error.
any help on this is appreciated
4:02:50 T:7768 M:1053421568  NOTICE: [url]http://tamilkacheri.com/index.php?page=shows[/url]
14:02:53 T:7620 M:1050755072  NOTICE: -->Python Interpreter Initialized<--
14:02:53 T:7620 M:1050214400  NOTICE: Mode: 1
14:02:53 T:7620 M:1050214400  NOTICE: URL: [url]http://tamilkacheri.com/?page=view&id=2403[/url]
14:02:53 T:7620 M:1050214400  NOTICE: Name: Airtel Super S..
14:02:53 T:7620 M:1050214400  NOTICE: [url]http://tamilkacheri.com/?page=view&id=2403[/url]
14:03:35 T:5904 M:1052196864  NOTICE: -->Python Interpreter Initialized<--
14:03:35 T:5904 M:1052381184  NOTICE: YouTube-2.0.0 ARGV: ['plugin://plugin.video.youtube/', '-1', '?action=play_video&videoid=mFWcpuehMMw']
14:03:36 T:5904 M:1049694208  NOTICE: YouTube-2.0.0 construct_video_url : 'mFWcpuehMMw'
14:03:36 T:5904 M:1049694208  NOTICE: YouTube-2.0.0 _get_details: 'mFWcpuehMMw'
14:03:36 T:5904 M:1049694208  NOTICE: YouTube-2.0.0 fetching page : [url]http://gdata.youtube.com/feeds/api/videos/mFWcpuehMMw[/url]
14:03:36 T:5904 M:1049649152  NOTICE: YouTube-2.0.0 _getvideoinfo: 4013
14:03:36 T:5904 M:1049440256  NOTICE: plot updated
14:03:36 T:5904 M:1049440256  NOTICE: YouTube-2.0.0 _getvideoinfo done : 1
14:03:36 T:5904 M:1049440256  NOTICE: YouTube-2.0.0 _get_details done
14:03:36 T:5904 M:1049440256  NOTICE: YouTube-2.0.0 extractVariables : 'mFWcpuehMMw'
14:03:36 T:5904 M:1049440256  NOTICE: YouTube-2.0.0 fetching page : [url]http://www.youtube.com/watch?v=mFWcpuehMMw&safeSearch=none&hl=en_us[/url]
14:03:37 T:5904 M:1049960448  NOTICE: YouTube-2.0.0 extractVariables done
14:03:37 T:5904 M:1049960448  NOTICE: YouTube-2.0.0 construct_video_url: stream_map : False
14:03:37 T:5904 M:1049960448  NOTICE: YouTube-2.0.0 construct_video_url: non stream map
14:03:37 T:5904 M:1049960448  NOTICE: YouTube-2.0.0 construct_video_url done
14:03:37 T:5904 M:1049944064  NOTICE: YouTube-2.0.0 - Playing video: ATSS 1 - mFWcpuehMMw - [url]http://v12.lscache7.c.youtube.com/videoplayback?sparams=id,expire,ip,ipbits,itag,algorithm,burst,factor&fexp=901031&algorithm=throttle-factor&itag=35&ipbits=8&burst=40&sver=3&signature=668FFC4820CD591FB036B65774E418B2B8CD9170.4F9283F43884D0C0DC8CDF23BC2CCFE155749D0D&expire=1298340000&key=yt1&ip=71.0.0.0&factor=1.25&id=98559ca6e7a130cc[/url] | Mozilla/5.0 (Windows; U; Windows NT 6.1; en-GB; rv:1.9.2.8) Gecko/20100722 Firefox/3.6.8
14:04:16 T:7852 M:1057636352  NOTICE: Storing total System Uptime
14:04:16 T:7852 M:1057636352  NOTICE: Saving settings
Hola,
I did a Search in the thread and didn't find any post about subtitles support in the Youtube Addon.
Is there any way to see youtube videos with subtitles (cc)?
Gracias.
watanave Wrote:Hola,
Gracias.
Hi, I will look into this, but I'm kinda doubting its possible as i don't know what subtitle format YouTube uses or if XBMC will even allow me to add it. But anyways I will give it a look see Wink
