(2021-03-26, 00:41)AchillesPunks Wrote: [ -> ]I have uploaded the files for KODI MATRIX for download. There are still a few issues but we can use the skin just fine. Just download the zips I supplied and install in order, and replace your addon in the skin with the one I supplied. You need to extract the MatrixSkindSupport.zip, and install each zip inside individually.
The link is on the first page but I'll add it here as well.
P.S
This is for matrix & if you do not have matrix installed do not try this out.
https://github.com/AchillesPunks/MartixSkinSupport.git
Please how do I install this on 18.9?
(2021-03-26, 03:12)AchillesPunks Wrote: [ -> ]I made it a little easier to install just redownload, and extract the zip and install each zip 1-10
This may be a daft question but do I need to have Bingie added before I do this? I assumed not as I can't see a way to get the original skin from the BINGIE repo now, but having installed the 10 zips and replaced the xml in my Arctic Horizon addon file, I'm unable to get Bingie Mod to show up as a usable skin
(2021-03-26, 03:54)malikal Wrote: [ -> ] (2021-03-26, 00:41)AchillesPunks Wrote: [ -> ]I have uploaded the files for KODI MATRIX for download. There are still a few issues but we can use the skin just fine. Just download the zips I supplied and install in order, and replace your addon in the skin with the one I supplied. You need to extract the MatrixSkindSupport.zip, and install each zip inside individually.
P.S
You have to have Matrix installed. this is not for Leia
Hi, was hoping to use the skin to keep the original Titan skin going but I couldnt change the default menu options. Can this be re-enabled so it can be used like the very orignial Titan skin or titan Vanilla
Thanks heaps for your hard work, appreciated.
Hi
Just wanted to confirm the installation method/order for clean install on Kodi Matrix:
1. Install the BINGIE Repository
2. Install Titan Bingie Mod Matrix Skin and set as skin to use
3. Install Matrix Skin Support Zip files in order from 1 to 10
I take it we dont have to install the skin from from @
Cartman.dos then install the Titan Bingie Mod Matrix Skin?
