(2020-11-06, 02:35)mathu204 Wrote: [ -> ]Hey Hugo, might not be the right place to ask so if anyone tells me ill delete or stop asking here, im setting up library integration on a fresh build just in case i fuck stuff up and the watched statuses are syncing up, however i have a few questions. How much stuff do you have in your library cause I feel like my watchlist and current shows are not enough to fill up a library as big as netflix. I think im just gonna have to add a boat load of shows and movies that i dont even watch just to get it looking right u know what i mean.
My next question is how can i get widgets like Trending, Popular using my library? Like for example lets say i have hundred shows but the trending now widget from TMDB Helper has shows like Mandalorian, Queens Gambit, The Boys, Walking Dead, etc that i dont have in my library for whatever reason how can i get shows like that to show up? I guess I cant? and how can i even set up widgets like trending that would update with current times or whatever, without having to setup smart playlists and things like that; if i have to then ill look into it but im confused enough already with library integration haha
About 100 TV shows and 650 movies. Then I have the Netflix addon too and point a few widgets to some of their lists, like so.
Nothings stopping you from pointing your widgets to TMDB Helper, trakt lists or wherever you chose for your trending, popular etc. I saw there was an option in the TMDB addon to use local artwork and metadata for any shows you have in library. Anything not in your library is probably hit and miss whether you get all artwork and metadata. Library integration ensures you have the right artwork and metadata since it's all controlled by you and your scraper/artwork settings as well as ensuring speedy widgets (when your pointing them to your library). There's loads of build in smart playlists Cartman made. Making your own playlists is simple enough too.
(2020-11-06, 03:23)HugoL Wrote: [ -> ] (2020-11-06, 02:35)mathu204 Wrote: [ -> ]Hey Hugo, might not be the right place to ask so if anyone tells me ill delete or stop asking here, im setting up library integration on a fresh build just in case i fuck stuff up and the watched statuses are syncing up, however i have a few questions. How much stuff do you have in your library cause I feel like my watchlist and current shows are not enough to fill up a library as big as netflix. I think im just gonna have to add a boat load of shows and movies that i dont even watch just to get it looking right u know what i mean.
I have about 600 tv shows and about 1000 movies with 30 widgets. It's pretty close to Netflix the more you add the better the result.
The problem is the tmdb widgets don’t show the clear logos or ratings, if I use the use local library artwork setting would it make the clear logos show up too?
(2020-11-06, 03:57)mathu204 Wrote: [ -> ] (2020-11-06, 03:23)HugoL Wrote: [ -> ] (2020-11-06, 02:35)mathu204 Wrote: [ -> ]Hey Hugo, might not be the right place to ask so if anyone tells me ill delete or stop asking here, im setting up library integration on a fresh build just in case i fuck stuff up and the watched statuses are syncing up, however i have a few questions. How much stuff do you have in your library cause I feel like my watchlist and current shows are not enough to fill up a library as big as netflix. I think im just gonna have to add a boat load of shows and movies that i dont even watch just to get it looking right u know what i mean.
Yes 99% of all local library content artwork is supported through artwork beef. The few things it doesn't scrape you can add in yourself.
(2020-11-06, 04:27)cscott1 Wrote: [ -> ] (2020-11-06, 03:57)mathu204 Wrote: [ -> ] (2020-11-06, 03:23)HugoL Wrote: [ -> ]About 100 TV shows and 650 movies. Then I have the Netflix addon too and point a few widgets to some of their lists, like so.
Sorry I meant the missing ratings** I assume artwork can be plugged in
(2020-11-05, 22:22)HugoL Wrote: [ -> ] (2020-11-05, 22:07)Aaiemron Wrote: [ -> ] (2020-11-05, 21:54)HugoL Wrote: [ -> ]No you’re doing nothing wrong. No other homescreen layout is supported other than Netflix layout.
Oke. But when I leave the settings menu, I only have a black screen, no skin at all. The only thing I can do is press the S button tot go to the settings menu to change to another skin for example.
Ik have tried to install the skin several times, also on a fresh Kodi, but I can't get it done.
Ok but what’s this got to do with your homescreen layout?
Try going to configure shortcuts and use both the restore options under Reset Menu to Defaults.
Then go to Back up and Restore and use the Reset the Skin to defaults option.
Report back after this and let me know what systems you’ve tried this on.
Goodmorning and thank you. I finally got it working with the steps you told me.
After that I got a weird screen:
Than I had to push 5 times on the escape button.
The settings menu appeard.
Where is says: "Do it for me", I pushed twice on No and the magic happened.
Now I have also on a Mac your Mod skin and it looks amazing. Thanks again for helping me out
(2020-11-06, 03:33)cscott1 Wrote: [ -> ] (2020-11-06, 03:23)HugoL Wrote: [ -> ] (2020-11-06, 02:35)mathu204 Wrote: [ -> ]Hey Hugo, might not be the right place to ask so if anyone tells me ill delete or stop asking here, im setting up library integration on a fresh build just in case i fuck stuff up and the watched statuses are syncing up, however i have a few questions. How much stuff do you have in your library cause I feel like my watchlist and current shows are not enough to fill up a library as big as netflix. I think im just gonna have to add a boat load of shows and movies that i dont even watch just to get it looking right u know what i mean.
Well, My library have 4200 TV Shows , 12000 Movies . ( Not a single movies or shows ever produced which are not in my library ) with more then 70 Widgets , So my Catalogue is 100 % time better then ( Netflix , Hulu , Amazon and others combined ) 1950 to 2020 everything is there ( you name it ) .
Fun fact is All kind of Artworks, Ratings updated and I have better Playlists for widgets using Tags Like ( Super Abilities , Mental Asylum , Rape & Brutal , Time Travel , Parallel Universe etc ) using Library contents , Never missed Watched , In process Movies & TV Shows , Continued watching etc .
Titan Bingie with Library Contents is a Beast .
(2020-11-06, 08:34)nazim12 Wrote: [ -> ] (2020-11-06, 03:33)cscott1 Wrote: [ -> ] (2020-11-06, 03:23)HugoL Wrote: [ -> ]About 100 TV shows and 650 movies. Then I have the Netflix addon too and point a few widgets to some of their lists, like so.
I think they have local media. Your's I believe is not. You should have 1920 movies as well.
With all the testing I’ve been doing lately most of my widgets end up being default. I’m now permanently starting at the same default widgets and it looks so boring.
(2020-11-06, 11:02)AchillesPunks Wrote: [ -> ] (2020-11-06, 08:34)nazim12 Wrote: [ -> ] (2020-11-06, 03:33)cscott1 Wrote: [ -> ]I have about 600 tv shows and about 1000 movies with 30 widgets. It's pretty close to Netflix the more you add the better the result.
Seems to me like he has local artwork and local metadata using library integration tools.
Yes, I believe that is what that setting is used for. Not that I’ve tried since I don’t use TMDB helper.
But in theory, if your tmdb widget is currently showing a title that you also have in your library, it will use your metadata and artwork instead.
I'm having an odd behavior sense the update not sure if it is intended. On the home screen main spotlight the information dialog appears then disappears until I slide it over to more info where it appears then disappears again. Is there a setting somewhere I'm missing to to keep it static?
(2020-11-06, 15:17)cscott1 Wrote: [ -> ]I'm having an odd behavior sense the update not sure if it is intended. On the home screen main spotlight the information dialog appears then disappears until I slide it over to more info where it appears then disappears again. Is there a setting somewhere I'm missing to to keep it static?
That’s intended. It’s a slide animation so the plot disappears and the clearlogo slides down to rest on the buttons (just like Netflix’s spotlight) after several seconds on idle.
When not idle, it reappears. There is a small update already on GitHub that fixes a couple of things and also offers a setting to disable the animation. Feel free to grab it or maybe just wait a while since I’m also going to improve the spotlight diffuse a little too.
Hey my friend so i used library integration dont have a huge library yet but im working on it thank you for the advice. The resume points, season view, etc are all great i have 2 questions though outlined in the imgur post. one is the poster size inside my library view seems off like the space between posters seems bigger but im not sure could just be me reading into it wrong so let me know on that. Other is i still cant get the ratings to show up pls help
https://imgur.com/a/9yuGajZ
(2020-11-06, 16:39)mathu204 Wrote: [ -> ]Hey my friend so i used library integration dont have a huge library yet but im working on it thank you for the advice. The resume points, season view, etc are all great i have 2 questions though outlined in the imgur post. one is the poster size inside my library view seems off like the space between posters seems bigger but im not sure could just be me reading into it wrong so let me know on that. Other is i still cant get the ratings to show up pls help https://imgur.com/a/9yuGajZ
1. Poster size in your library looks correct. I think I told you previously, the poster size in library view is not the same as on Home screen. However, your resolution is still wrong. You need a 16:9 aspect ratio which you don't have and preferably resolution of 1920x1080p. What steps have you taken so far to try and fix this?
2. Looks like Achilles did something funky in the settings to remove the footer for spotlight content. I'm going to fix it now.
